Go Back  R/C Tech Forums > General Forums > 3D Printing Forum
12v power supply cover >
Like Tree4Likes
  • 2 Post By mo
  • 1 Post By Madulla
  • 1 Post By Madulla
Old 08-23-2019, 06:16 AM
jonski's Avatar
Trader Rating: 322 (99%+)
Default 12v power supply cover
Anyone have an .stl file for the protective cover for the 12v power supplies? Broke mine and can't find one online to buy. Something like the one in the picture.
jonski is offline
Old 08-25-2019, 06:32 PM
That's going to vary pretty wildly depending which power supply yours was made from. There's a few files on thingiverse, or learn to use fusion 360 and design one specific to yours.
anthonyscardina is online now
Old 08-26-2019, 12:32 PM
mo
mo's Avatar
I made one for a friends RL power supply a while back since RL was less than helpfull getting him a new one. I just put it up on thingiverse so you can see if it will work for you.
https://www.thingiverse.com/thing:3830861
jonski and two shoes like this.
mo is offline
Old 08-26-2019, 12:35 PM
jonski's Avatar
Thanks...I will print one out and try it.
jonski is offline
Old 09-11-2019, 07:01 PM
Madulla's Avatar
Worked out great for me. Thanks!!!!
two shoes likes this.
Madulla is offline
Old 09-26-2019, 12:56 PM
Looks good. Where did you get the connectors?
FlatSix914 is offline
Old 09-26-2019, 07:59 PM
Madulla's Avatar
Hobbyking 4mm bullet
Madulla is offline
Old 09-26-2019, 08:00 PM
Madulla's Avatar
The cover is for the 750W supply. Now I need a cover for the 850W which is a little bigger
Madulla is offline
Old 10-24-2019, 09:50 AM
Wow, it would be awesome if someone made these for the standard DIY HP server supplies as well!
the_real_hova is offline
Old 10-28-2019, 05:01 AM
Trader Rating: 35 (100%+)
That's what these are
xjwolfpacker is offline
Old 10-28-2019, 12:26 PM
Madulla's Avatar
Figured out for a 850W PS I just add 5mm to the X/Y Axis to make it a little longer.
Madulla is offline
Old 10-28-2019, 05:43 PM
Wow, I had no idea, thank you! I think I'll give this a try!
Old 11-18-2019, 12:23 PM
evhexrc's Avatar
Are these just glued onto the psu? How are they mounted? If glued, what kind of glue is used? I'd like to design a cover for myself without destroying the stock one.
evhexrc is offline
Old 11-18-2019, 05:47 PM
Madulla's Avatar
Press fit. The file is so exact it just pops right on
Juniorabca likes this.
Madulla is offline
Old 11-19-2019, 06:44 AM
evhexrc's Avatar
Thanks. I’m designing my own. I’ll ask RL Power how they fasten it and what they use.
evhexrc is offline
