XRAY & HUDY New Releases
#67
Hi Ari,
Any idea when the 52mm ECS driveshafts will be available. Tried ordering through my LHS but it's on backorder. Any shops that may have them in stock in QLD?
Cheers
Cheers
#69
Thanks Ari.
#72
XRAY XB808E Pinion Gears
High-performance XB808E pinion gears, manufactured from special
steel for toughness and durability with precise tolerances and assures
unparalleled concentricity. Precision-cut teeth with chamfered edges.
Run-in for smooth operation. Include M4x4 set screws.
•high-performance
•specially-formulated steel for toughness and durability
•precision tolerances
•unparalleled concentricity
•precision-cut teeth with chamfered edges
•run-in for smooth operation
In stock now.
•high-performance
In stock now.
#73
#338716 Brass 1-Piece Engine Mount
XRAY optional Brass Engine Mount for NT1 provides solid engine mounting
and easy adjustment.
The Monoblock Engine Mount is recommended for all conditions. The
Monoblock design provides a stiffer design than the standard single engine
mounts but is still a bit more flexible than the Multi-Flex™ 1-Piece Engine
Mounting System (#338712). The engine area of the car and the area
between engine and 2-speed is reinforced but the flex of the chassis is still
available. The reinforced area of the chassis between the engine and 2-
speed gears reduces the chance of spur gear breakage or stripping.
CNC-machined from premium brass material. Precision machined with
highest tolerances using premium fully-automatic German CNC-machines.
Ultra-strong construction provides very long life and durability in even the
most extreme racing conditions. The weight of the monoblock from brass
material is 53.5g and is heavier by 26g then standard monoblock. Thanks
to this extra weight, car has more incorner steering and not so much extra
weight is needed.
•Solid engine mounting
•Easy adjustment
•Stiffer design yet more flexible than the Multi-Flex™ 1-Piece Engine
•Mounting System (#338712)
•Reduced chance of spur gear breakage/stripping
•CNC-machined from premium brass material
•Precision machined with highest tolerances
•Ultra-strong construction provides very long life and durability in
even the most extreme racing conditions.
•Brass material is heavier by 26g then standard monoblock
•More in-corner steering
weight is needed.
•Easy adjustment
#74
#303061 LiPo Chassis Graphite Motor Guard
CNC-machined graphite motor guard for LiPo chassis protects the motor
endbell from collisions. Includes mounting hardware.
The high-grade, custom-manufactured carbon graphite is specially
produced based on XRAY’s own recipe and specifications.
•CNC-machined
•high-quality graphite
•protects the motor endbell
•includes mounting hardware
In stock now.
•CNC-machined
In stock now.
#75
#338690 Fuel Tank Capacity Sticker (4)
Fuel level indicator for XRAY fuel tank in the form of a white transparent
die-cut sticker. Displays fuel measurement in 5cl increments. Set of 4.
Apply stickers to appropriate location on radio plate beside fuel tank.
When car is lifted by rear (nose to ground) the stickers will quickly show
you the amount of fuel remaining.
•fuel level indicator for XRAY fuel tank
•white transparent die-cut sticker
•displays fuel measurement in 5cl increments
•set of 4
In stock now.
•set of 4
In stock now.
