BACK TO THE BEGINNING AT TRACKSIDE
#61
Quick list of classes,
Stock Truck - rubber tire only, stock motor, stock body, can run 6" long side dam, battery centered in chassis.
Mod Truck - rubber tire only, 19t or 4300 BL motor, stock body, can run 6" long side dam, battery centered in chassis.
Modifieds - off-road buggy, rubber tire only, 19t or 4300 BL motor, 2" spoiler, McAllister IMCA modified body, w/3"x6" side dam, or Custom Works Narrow Probe w/no side dams, battery centered in chassis.
Sportsman - 4wd sedan chassis, stock motor, '55-'57 type body, foam tires allowed. No offset or aftermarket chassis. No spoilers or side dams.
Late Model - 4wd sedan chassis, 19t or 4300 BL motor,No offset or aftermarket chassis, McAllister Dirt Oval Late Model bodies, 205mm max., foam tires allowed. 2" rear spoiler, No side dams.
Outlaw Sprint - Any motor, battery centered in chassis, foam tires allowed.
All classes 6 cell, no lipo.
We're using Custom Works side dam lexan.
#62
thanx hollywood. now ive really gotta find the time to get over there to race. times a little cramped tho. darn 3 jobs and school!
#63
Questions For Hollywood
OUTLAW Sprint
Does this mean you can run a brushless and Lipo? What sprints cars are you going to stock?
Stock Truck
Is there a web site that I can look up the side dams you are allowing to run and how they are installed? When you say rubber tires what type are you talking about.
I am asking these questions because I have never did this type of racing before and I would like to look up more info before I go and buy this stuff. Thanks for you help with this.
Stock Truck
#64
Stock Truck - rubber tire, stock motor, stock body, can run 6" long side dam, battery centered in chassis.
Mod Truck - rubber tire, 19t or 4300 BL motor, stock body, can run 6" long side dam, battery centered in chassis.
Modifieds - off-road buggy, rubber tire, 19t or 4300 BL motor, 2" spoiler, McAllister IMCA modified body, w/3"x6" side dam, or Custom Works Narrow Probe w/no side dams, battery centered in chassis.
Late Model - 4wd sedan chassis, 19t or 4300 BL motor, McAllister Dirt Oval Late Model bodies, 205mm max., foam tires allowed. 2" rear spoiler, No side dams.
All classes 6 cell
All classes 6 cell
#65
Originally Posted by GSP
OUTLAW Sprint
All classes 6 cell
Stock Truck
You don't have to run the side dam if you don't want too. I haven't been running one on my truck, and I'm not having any handling troubles at all. However, I'm not too sure about a website with pictures, but you might want to try dirtoval.com
The tires that we run at Trackside are Losi pink taper pins, with Trinity grey bomb 1 inserts. You can try other tires, but trust me, you will go back to the pink taper pins quickly.
Originally Posted by Racin4Fun
quick question on the 4wd tc late model class, you list no offset or aftermarket chassis for sportsman but not late model? does this mean you can run a oval conversion on your touring car in late model or are we just running a stock chassis?
Guys, tomorrow night is the first night of racing dirt oval at Trackside in a very long time. The rules that we have in place are an attempt to make this as fun, and inviting as possible. We know full well that there are going to be questionable cars, and "kinks" in the race program, especially tomorrow night. Just bear with us, we hope to have a fun and exciting night non-the-less.
#66
BuckMan Thanks
Thanks for the info on the tires and what you are doing with your truck. On the tires are you removing all of the pins and running a slick type of tire or running the tires as is out of the package?
Is dirt oval just a summer thing or will Trackside run this in the winter months?
#67
Normaly for the thrucks if you run a side dam. Usually from the back of the cab to the tail gate and oing up as high as the roof is good enough. it's there to keep the truck from fish tailing. although side dams look ugly you would not beleive how stable the cars can get with them. I had attached a picture to see how they mount
#69
for instence if the track is sticky and has little to no dust a slick is perfect but if the track is dusty and dry full pin is good
trackside mit run the oval in the winter if there is enof intrest in it in the summer
#71
4 hours until green flag!
#75
YES
