Go Back   R/C Tech Forums > General Forums > Web Links
Old 11-24-2013, 05:38 PM   #1
Mowingrass's Avatar
Trader Rating: 19 (100%+)
Thumbs up How to unglue/reuse tires
Hope this can help sombody ive gotten all these tips from others mostly but yeah
http://youtu.be/0yY8-U2eLvM
Mugen mbx6e|d8t hobbywing spektrum turnigy
Youtube tonymowingrass
Mowingrass is offline   Reply With Quote
Old 11-24-2013, 06:38 PM   #2
Suspended
Trader Rating: 1 (67%+)
I have tried every method on the internet, if you have the acetone that is the easiest Next is bowling them but the last is the baking just because it smells shit!
Hot Bodies Racing, Proline Racing, Byron Fuels, and Radio Post
-Hot Bodies D8 Hara Edition, and D8 Truggy
-B5 and b4.2
rcgarrettp9 is offline   Reply With Quote
Old 11-28-2013, 07:51 PM   #3
Thanks for the tips
KProc is offline   Reply With Quote
Old 11-28-2013, 08:18 PM   #4
Trader Rating: 520 (100%+)
I have been removing 1/10 scale tires and reusing them and the wheels for quite awhile, and honestly nothing beats a really good job at gluing them. For me, the best trick is using just enough glue to hold them on, and not getting it down on the flat part of the wheel where it really is hard to undo. I try and just glue the top inner, and top edge where it is tough, but still possible to pull them free if needed. You will need to keep an eye if they start to let go occasionally. After removal I soak the wheels in an acetone bath for a few hours to sometimes overnight. Then clean and reuse...1/8 wheels usually are more difficult, and usually aren't in good enough shape to reuse from my experience...
flame56mx is offline   Reply With Quote
Old 12-23-2013, 07:05 PM   #5
Suspended
I like the acetone method but sitting them on something above the liquid. doing this saves the expensive closed cell foams but the downside is it takes a few days to release the glue. the vapors will work just takes longer. but you also save a lot of acetone.
if you want to test your rims and see if you can use this method put a little acetone on a rag and wipe it on the inside of your rim. if the spot feels soft or sticky after a few seconds it will probably melt the rim.
mtpocketsracing is offline   Reply With Quote
Old 03-18-2014, 07:57 PM   #6
Suspended
good suggestions, i'll try next time
Mark Loft is offline   Reply With Quote
Old 12-24-2014, 11:54 AM   #7
I have found that baking them works the best. I have an old toaster oven that I keep in the garage so it doesn't stink up the house. 300 degrees for 18 minutes and the wheels pop right out. Just make sure to wear gloves because they will be hot.
Deadfrog Racing is offline   Reply With Quote
Old 12-27-2014, 04:54 PM   #8
you mean driving the car untill the tires become unglued and fall off is no longer a relevant method
stampede 2wd hobbyking x car 120a esc, neewer 550 4 pole 4300kv motor,turnigy nano tech shorty 2s lipo 4200mah 65c, random crappy rtr controller,soon to be turnigy 15.5kg/cm .16s servo-brushless tmaxx turnigy 160a sensorless esc, turnigy 4 pole 1/8 scale 2100kv motor, some brand lipo from hobbyking 4s 4000mah 30-40c, turnigy 12.5kg/cm servo same controller and receiver, brushless emaxx tranny, hpi sprint 69 mustang body
rc car freak is offline   Reply With Quote
Old 12-28-2014, 07:42 AM   #9
ThePanda's Avatar
Trader Rating: 64 (100%+)
Acetone does funny things to clay compounds... Goes from this O to this o
ThePanda is offline   Reply With Quote
Old 02-21-2015, 11:21 PM   #10
WOW nice tips! Unglue will not difficult for me anymore.
thebuyer is offline   Reply With Quote
