Go Back   R/C Tech Forums > General Forums > Web Links
Old 01-24-2012, 02:44 AM   #1
bradley henry's Avatar
Default Upgrading the bazooka bt9.5
Well can't find anything on this., my (HSP bazooka bt9.5 ) has a ( xk 3665 Turnigy )2400 kv coupled with a 80a ESC a little clunky but hay for the money I ain't complaining . I would like more top end as it has tones of toque . changing the pinion will do this , but just don't like the moter . Has any one got suggestions around 3000kv combo . or what ever I'm running twin lipo 25c -30c 3600 turnigy I suspect . And have ordered 2 nano tech 30c -60c lipos
HSP BAZOOKA-- LOSI STRIKE-- REX EX PRO-- GV MONSTER --STADIUM BLIT'S-- FULL 7 INCHES..
bradley henry is offline   Reply With Quote
Old 12-04-2012, 06:35 PM   #2
hi i own a hsp planet runnig 4s turnigy batts, 3000kv and hobywing 80amp esc. if i were you dont go for the 3000kv as it outputs 50 400rpm while people say it will overheat if it goes beyond 40, 000rpm beyond my setup. im now looking to downgrade the motor the bt9.5 2400kv or 2200kv turnigy motors for a cool setup and for more top speed i will prob use 17-20t pinions
(by the way the 1 8 hsp use mod 1 pinions and check the motor shaft diameter to suit the pinion to it. those turnigy motors are 5mm and our spur gear is mod 1, so look out for that when finding pinions). 3000kv with 4s, under 3000kv for cooler setup
so just get a pinion easy!!
HSP PLANET
3000KV 4S TURNGI BATTS, TOWARD PRO MG996R (MODDED 15KG), FULL UPGRADED BALL BEARINGS.THEROTICAL TOP SPEED ON CURRENT SETUP: 98.4KM/H
DOWNGRADING MOTOR FOR LOWER TEMPS AND TORQUE
Ayden is offline   Reply With Quote
