Go Back   R/C Tech Forums > International Forums > Australian Racing > Venom Group Australia
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rate Thread
Old 08-24-2009, 05:33 PM   #1
Shop Owner
Venom Australia's Avatar
Default Venom Power
VEN-15084 Venom Hard Case Lipo 7.4v 5000mah
Available Now - Contact your local hobbyshop
Configuration: 2S
Weight: 277g
Dimensions: 25 x 46.5 x 137.8 mm
Charge Rate: 3C (15A)
Continuous Discharge: 40C
Min Discharge Volts per Pack: 6.0V
Max Burst Rate: 80C
Max Volts per Cell: 4.2V
Max Volts per Pack: 8.4V
Venom Australia is offline   Reply With Quote
Old 08-24-2009, 05:44 PM   #2
Shop Owner
VEN-15081 Venom Hard Case Lipo 7.4v 3800mah
Configuration: 2S
Weight: 233g
Dimensions: 23.3 x 46.75 x 137.8 mm
Charge Rate: 5C (19A)
Continuous Discharge: 35C
Max Burst Rate: 45C
Old 08-24-2009, 07:00 PM   #3
Shop Owner
VEN-15083 Venom Hard Case Lipo 7.4v 4200mah Saddle
Configuration: 2S
Weight: 260g
Dimensions: 23 x 46.2 x 69 mm
Charge Rate: 5C (21A)
Continuous Discharge: 30C
Max Burst Rate: 40C
Old 08-24-2009, 07:02 PM   #4
Shop Owner
VEN-15082 Venom Hard Case Lipo 7.4v 6000mah Saddle
Configuration: 3P2S
Weight: 360g
Dimensions: 31 x 46 x 69 mm
Charge Rate: 5C (30A)
Max Burst Rate: 40C
Old 08-24-2009, 10:43 PM   #5
Shop Owner
VEN-0657AU Venom Pro Charger with Power Supply
If you have been searching for just one RC battery charger to handle all of your charging needs, look no further than the Venom Multi Function Pro Charger. This charger is available in both DC and AC/DC power configurations so there are no limitations. This machine can handle charging, discharging, balancing (LiPO/LiON/LiFE cells), cycling and more.
If you have multiple kinds of RC vehicles and other battery charging needs, the Pro Charger is able to service multiple types of batteries. Many RC enthusiasts have to use a special LiPO charger, a separate RC charger for each type of battery and manage all of the plugs and cords. The Venom Multi Function Pro Charger handles five different kinds of batteries in just one machine; NiCD, NiMH, LiPO, LiON/LiFE and Lead Acid batteries.
LiPO and LiON and LIFE batteries can have multiple cells depending on the size of the battery and need special handling to fully charge them. The Venom Pro Charger can handle 1 to 6 cell LiPO, LiON/LiFE at a time and a whopping one to fifteen cells for NiCD and NiMH batteries.
This system allows users to define charge rates from 0.1 amps to 5.0 amps depending on what they need. The Venom Multi Function Pro Charger also allows the user to create up to ten different charger profiles with a USB PC connection. If you use more than one RC car battery charger you can integrate all your power needs into one keeping track of each profile separately. To handle all the different kinds of vehicles there are six different power plugs; the new Traxxas® High Current Connector (TRX Plug)s, Tamiya, Alligator Clip, Futaba, Glow Igniter and JST plug.
The Chargers easy to use features include; Charging, Discharging, Cycling, Balancing (LiPO/LiION/LiFE cells), User definable charge rates from 0.1 amps to 5.0 amps, USB PC Linkability, Temperature Probe and 10 User-Defined Charger Profiles. Comes with six different charging plugs including the new Traxxas High Current Connector. Finally, an R/C battery charger that is as dedicated to performance as you are.
Old 08-26-2009, 04:25 PM   #6
Shop Owner
VEN-1339 Venom 120 amp Pro Brushless V2 ESC
The Venom 120 amp Pro Brushless ESC is compatible with all sensored and sensorless brushless motors. This ESC truly is an all encompassing Electronic Speed Control. With the included programming card, you can adjust eleven individual parameters including Forward/Brake, Forward/Reverse, Drag, Initial and Maximum Brake Force, Low Voltage Cut-Off, Start Mode, Maximum Reverse Force, Throttle Neutral Range, Motor Timing, Motor Type and Over-Heat Protection. The Venom 120 amp Pro Brushless ESC features a high efficiency cooling system that includes an aluminum heat sink and cooling fan to keep operating temperatures in check,. Pre wired with 14 gauge wire to ensure minimal power loss and a compact footprint of 43mm x 36mm makes the Venom? 120 amp Pro Brushless ESC a perfect choice for all of your On and Off-Road applications.
Specifications:
Length: 43mm
Width: 36mm
Height: 33mm without fan
Weight: 65g without wires
Continuous Current: 120A
Burst Current: 760A
Resistance: 0.0003 ohm
Suitable Model: 1/8, 1/10, 1/12 ON/OFF Road
Suitable Brushless Motor: 3.5T and Up
Battery: 4-9 cells NIMH or 2-3 Cell LiPo
BEC Output: 5.75V/2A
Motor Type: Sensorless / Sensored Brushless
Old 08-27-2009, 06:33 PM   #7
Shop Owner
Venom V540 Brushless Motor
Venom 540 Brushless Motors were designed with performance in mind. Compatible with today's most popular sensored brushless speed control systems, including LRP, Novak & our Venom Pro ESC. The new motors feature CNC machined aluminum cans with ventilated front end bells, dual ball bearings and integrated cooling fans for high efficiency cooling. All Venom 540motors have Sintered Magnets, Adjustable Timing, Easy Solder Wire Terminals and are fully rebuildable. Motors are also locally approved in stock, superstock and modified classes.
Available in:
VEN-1325 = 3.5T
VEN-1326 = 4.5T
VEN-1327 = 5.5T
VEN-1328 = 6.5T
VEN-1329 = 7.5T
VEN-1330 = 8.5T
VEN-1331 = 9.5T
VEN-1332 = 10.5T
VEN-1333 = 13.5T
VEN-1338 = 17.5T
VEN-1351 = 18.5T
TBA = 21.5T
Old 10-27-2009, 09:55 PM   #8
Shop Owner
VEN-0660AU Venom Pro Charger with 12.5 Amps Power Supply
If you want something abit more to handle all of your charging needs, look no further than the Venom Multi Function Pro Charger Plus. This charger works on both DC and AC/DC power configurations so there are no limitations. This machine can handle charging, discharging, balancing (LiPO/LiON/LiFE cells), cycling and more.
If you have multiple kinds of RC vehicles and other battery charging needs, the Pro Charger Plus is able to service multiple types of batteries. Many RC enthusiasts have to use a special LiPO charger, a separate RC charger for each type of battery and manage all of the plugs and cords. The Venom Pro Charger Plus handles five different kinds of batteries in just one machine; NiCD, NiMH, LiPO, LiON/LiFE and Lead Acid batteries.
LiPO and LiON and LIFE batteries can have multiple cells depending on the size of the battery and need special handling to fully charge them. The Venom Pro Charger Plus can handle 1 to 8 cell LiPO, LiON/LiFE at a time and a whopping one to 27 cells for NiCD and NiMH batteries.
This system allows users to define charge rates from 0.1 amps to 7.0 amps depending on what they need. The Venom Multi Function Pro Charger also allows the user to create up to ten different charger profiles with a USB PC connection. If you use more than one RC car battery charger you can integrate all your power needs into one keeping track of each profile separately. To handle all the different kinds of vehicles there are six different power plugs; the new Traxxas® High Current Connector (TRX Plug)s, Tamiya, Alligator Clip, Futaba, Glow Igniter and JST plug.
The Chargers easy to use features include; Charging, Discharging upto 5 amps, Cycling, Balancing (LiPO/LiION/LiFE cells), User definable charge rates from 0.1 amps to 7.0 amps, USB PC Linkability, Temperature Probe and 10 User-Defined Charger Profiles. Comes with six different charging plugs including the new Traxxas High Current Connector. Finally, an R/C battery charger that is as dedicated to performance as you are.
Forum Jump
U.S. Vintage Trans-Am Racing ApexSpeed Electric On-Road 6706 Today 04:18 PM
Tamiya DF-03 type tom_chang79 Electric Off-Road 858 11-03-2009 02:32 AM
The Big Locked Thread donitaROSE Manila Racers 36432 10-11-2009 10:18 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45770 09-09-2009 07:19 AM
WTB Brushless TRUGGY REVO LOSI ??? Paypal Ready vantagerevo R/C Items: Wanted to Buy 7 01-09-2009 09:41 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
