how did your ae sc10 turn out?
mine turned out like crap. the sides were 1 inch longer than the body and their is a 1 inch gap on the front hood. just curious if anyone else had this problem or maybe they sent me a wrong cut setup.
Hey Byohnd,
I’m really sorry that you are having problems with your skin. Can I please have your name and your order number so I can look future into your order. Thank you!
13349, started on my other one i got. it was for the b4.1 bulldog body..looks like this one is even worse didnt even get anything for on the wing.
The piece you have on the fender is supposed to move towards the center hood piece so the two strait lines line up.I can see how the main side wrap is under your fender piece.Also there is a headlight section that looks like a hockey stick that covers from mid front fender around to the front grill.
In regards to the sides they work best when you start at the front and work your way back making sure to heat with a hairdryer on low to help it conform to the curves.If you miss this step it will pull off the lower curves. The wrap will have some excess that needs to be trimmed when you cut out the body.hope this helps.
i had those fender parts likes your at first, but only the inside lined up. the door part wasnt even close, the blue drip is half a drip off when you do it that way. mine did not come with a front section for the headlight area. i bought wraps from upgrade before for the e-scale and they had fit very well.
got the bulldog buggy wrap figured out. looks like i got a bad body or they changed the style some. found another one at a hobby shope and it fit fine on that one, just no wing wrap
hmm, so they have them for the 22, and the 44.1 but not the 4.1 ... almost makes sense. oh well, i am over it, it is what it is.
Hey Byohnd
Someone from Upgrade RC has tired contacting you regarding your order 13349. Please give them a call at your earliest convenience to resolve any issues that you might have with your order. Thank you!
