Hi fellow racers
Rich Clarke I and Co. have been in cahoots for some time dreaming up the following format to help clubs work together, which in turn makes for more racing and carry on the 'FUN FACTOR' in our great sport.
We think this should help our sport and clubs grow, let us have your constructive thoughts please.
We are proud to anounce that Much-More Racing will again be our sponsors for the coming series
You will be able to book both series via
Central Booking as from the 1st August 2009
MM-Rug Racers 2009/10 & MM-Eversley Winter Carpet Series
Classes available to enter are:
TC1 Modified: No motor limit, 5 cells sub-c, 1400g min weight including personal transponder, or any commercially available 6.5 BL motor with lipo, 1450g min weight including personal transponder, excluding handout transponders.
TC2 Pro Stock: 19T rebuild able stock motors (commercially available 19T spec motors), or brushless 10.5. Weight 1450g minimum including personal transponders, excluding handout transponders.
TC3 Stock Class: 27T rebuild able stock motors, commercially available 27T spec motors, or brushless 13.5 Weight 1450g minimum including personal transponders, excluding handout transponders.
Rules:
Control Tires NEW Pre-Glued, MM Sweep 32.
Batteries As set by the current BRCA standards for sub-c cells. All entrants using 6 cell sub-c size cells or a hard cased 7.4 LiPo, with 5300Mah maximum capacity, all cells or packs to be commercially available. LiPo batteries must be charged to OEM standards. All cars ready to be put on the grid will never have lipos with a voltage higher than 8.45V. Random checks will be conducted during the meeting at pitting stations and on the grids. Failure to comply with this rule will result in removal from the meeting and all remaining rounds of both MM Eversley and MM Rug Racers with no refunds on entry fees paid.
Motors All motors must be commercially available. No specials, no hybrids. BL motors can be sensored or sensorless, but only 13.5T, 10.5T or 6.5T. Motors do not have to be on the BRCA approved lists, and can be any make and model that is commercially available.
Body Shells Body shells to be touring car type (190mm)
Additives TBC
Entry fees TBA shortly
Entry fees for MM-RR & MM-EWS will be £9.00 per person per meeting per series. Under 14s will be £7.00 but will have to pay full price when booking in via CB, but will be refunded the £2.00 on race day.
Race Day Format for MM-Rug Racers:Practice TC1 will be provided a 10minute practise, TC2/TC3 will be provided a 15minute practise. All practise slots will be advised of start times by race control. Individual lap numbers will be monitored in order to achieve far time allocations for all entrants.
Qualifying 3 off, 5 minute timed runs with fastest FTD time applied for finals position.
Finals 3 off, 5 minute timed finals with best 2 results counted. I event of a tiebreak, the 3rd final result will count followed by FTD position.
Doors open at 7.30am and we must be out of the hall by 6pm
Practise will start at 8.00
Drivers Briefing will be 8.50 and racing will begin 9am.
Track will be a minimum of 30mtrs x 16mtrs with pitting space provided at trackside. There is limited power so please bring 12 volts in a plastic container
MM Raffles with prizes to be held at all rounds of each championship.
Race Day Format for MM-Eversley Winter SeriesPractice TC1 will be provided a 10minute practise, TC2/TC3 will be provided a 15minute practise. All practise slots will be advised of start times by race control. Individual lap numbers will be monitored in order to achieve far time allocations for all entrants.
Doors open at 8.30am and we must be out of the hall by 7pm
Practise will start at 9am.
Drivers Briefing will be 9.50 and racing will begin 10am.
Track will be a minimum of 30mtrs x 16mtrs with pitting space provided at trackside and on viewing balcony. There is limited power so please bring 12 volts in a plastic container
Inter-Series Championship (ISC)
A separate championship that will run from the results gained at both race series. Entry to the ISC is automatic at NO extra cost once you have completed the minimum number of rounds from both MM-Rug Racers (3 off min ) and MM-Eversley (3 off min). Entrants are permitted to enter 1 class only. An end of series awards presentation to be held at whichever meeting hosts the last round will present the winners of all race classes with the “Master of Series” shields.
All rules for the ISC will be as detailed for both series
Cheers Malc/Rich and Co
