Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 09-17-2011, 07:20 AM   #1
Default New Indoor Oval &Offoad track in Versailles OH
Hey coming in November there will be a new indoor High bank dirt oval and offroad track this is a new building with the track cut into the ground indoors.
More info to come ckeck out [URL="unclewesrcspeedway.com
uncle wes is offline   Reply With Quote
Old 09-19-2011, 05:49 AM   #2
Default pic of new oval and offraod track
check out the new track pic go to unclewesrcspeedway.com
Old 09-19-2011, 06:07 AM   #3
Default bmi karts NEW INDOOR RC TRACK
769 E MAIN ST VERSAILLES OH 45380 NEW DRIT OVAL AND OFFROAD TRACK THIS IS A NEW BUILDING WITH THE BEST THAT IS OUT THERE , WITH HEAT ,POWER ,FOOD ,GAME ROOM CLEAN BATHROOMS
RACING ON SATURDAY AT 1 PM DOOR OPENS AT 9 THERE WILL BE AMB LAP COUNTER FOR MOR INFO CALL 937-676-2826
Old 09-19-2011, 07:57 AM   #4
Default video
There is a video on unclercspeedway of the track whe i was running a 1/10 late model slider you can see the 6 six foot fans on the end of building with one on the other end yes this will sweet running offroad and oval in this new track .This is a clay track with high bite .will be fast and fun to run
Old 09-20-2011, 04:07 AM   #5
Default Nice Track
Wow ....That place is huge .....
Bob Hubbard is offline   Reply With Quote
Old 09-20-2011, 04:11 AM   #6
Default New Track
Could you walk the track with a wheel tape & give us the run line ..... inside thru the corners & out to the middle down the straights ..... Looks like it could be 200 ft run line from the video
Old 09-20-2011, 04:56 PM   #7
Default track
i am going to the track 9/21/2011 and will let you know
Old 09-21-2011, 06:14 AM   #8
Thumbs up run line
Thats cool ....
Old 09-21-2011, 05:26 PM   #9
Default Dimensions of new Track
The dimensions of the oval track is 180 x100 & offroad track is 140x 60
Old 09-22-2011, 04:13 AM   #10
Default New Track
Very Nice ..... Is the off road track goin to be in the middle of the oval ?
Old 09-22-2011, 05:07 AM   #11
Default offroad track
yes the offroad will be in the center of the oval
Old 09-23-2011, 08:45 AM   #12
Default BMI INDOOR SPEEDWAY
HERE THE NAME OF THE NEW TRACK
BMI INDOOR SPEEDWAY
FRIST INDOOR RC RACE NOVEMBER 12 2011
GATE OPENS AT 9 RACE STARTS AT 1 PM
Old 09-24-2011, 10:03 AM   #13
rayhoe1's Avatar
road trip man ohio is getting some nice dirt ovals
rayhoe1 is offline   Reply With Quote
Old 09-28-2011, 08:07 AM   #14
Default 1/10 TH SCALE 2 WD CLASS
1/10th Scale 2wd Classes
All 2WD Classes: All entries must be 2wd and rear wheel drive only. For turn marshal safety all cars must have a front bumper that is made of a shock absorbing material e.g. nylon, delrin, plastic, kydex etc. Front bumpers must be mounted in such a way that they will contact an object prior to any other portion of the car in a front impact. All cars must have 4-wheel independent suspension. No straight axle cars allowed, single speed transmissions only. All EDM bodies, sprint car bodies and cages must resemble contemporary full scale cars racing in “World of Outlaws” and “DIRT” sanctioned events. All corners of bodies and wings must be rounded for safety. No silicone or rubber capped tires allowed.
Wheelbase: 9.500” min, 11.500" max
Maximum width: 10.000” (foam tires), 10.250" (rubber tires)
Stock and Limited Nitro Classes
Radio use is limited to 2 channels only i.e., no wings adjustable from radio, no front brakes allowed.
Tires
Tire rules will be determined by track surface and race organizers. General tire choices will be between either foam tires or rubber tires however a SPEC tire rule may be implemented if desired. Any tire additives that are used must be wiped clean from the tires before any races or practice sessions.
Foam Tires:
Max wheel diameter: 2.0”
Max front tire and wheel width: 1.1”
Max rear tire and wheel width: 1.5”
Buggy Tires:
Max wheel diameter: 2.2” front and rear
Max wheel width: 1.750” rear, 1.000” front
Max tire width: 1.850” rear, 1.250” front
Chassis Specifications:
All height measurements are from bottom of chassis unless otherwise noted.
Late Models
Old 10-01-2011, 02:33 PM   #15
Default TEST AND TUNE
TEST AND TUNE IS 10/22/2011 AT 9 AM TILL 1 PM BOTH TRACKS WILL BE LAYED OUT TO RUN ON .
