Bumps and Jumps 2010 - 2011 season
#467
Tech Legend
Trader Rating: 51 (100%+)
If you have a Castle MMP and you run your Slash I will dial you right in with the right gearing. Just have Bill setup your motor like he did for me and I will have you geared right.
#468
Hey guys,
I'm looking forward to another indoor season at Bumps this winter. I'm thinking of trying 1/10 scale buggy. My question is what would be a good class to get into? I know that 4wd would be easier but I would also like to improve my driving. I already have a mmp and lipo's, I just need a motor and a buggy. I'd prefer to get a used roller plus spares if possible, just in case I might not like it which I doubt I will So any suggestions would be greatly appreciated. BTW is there normal racing this sunday and what is the turnout for ebuggy?
Thanks!
Tom
Thanks!
Tom
#469
Tech Legend
Hey guys,
Thanks!
Tom
Thanks!
Tom
#470
#471
Hey guys,
Thanks!
Tom
Thanks!
Tom
Tom, I would stick with 2wd, most guys are running the B4 or new B4.1. If you have a 13.5 or 10.5 motor that would be perfect. You may need to take the fan of the MMP but they unplug so your goood to go. As far as I know it a normal race this sunday but I think it will be a good turnout.
Jeff
#472
If i bring a mod truck & not enough show up for a class ... will i be able to race in another class? I don't care which one.
I know i know, i'm in a class of my own.
JohnG
JohnG
#473
#474
Tech Legend
I can't even tell you how much timing is setup in the motor because I don't know if the motor has numbers on it like the Tekins have on the can. I know whats in my speedo but the actual motor. You can look at if you like. I just run whats sent to me when I order a new motor.
#475
Also if you're going for the points series .. a points race has already been run but you do get one throwout (someone correct me if wrong?). If you miss another pts race you'll start putting yourself behind.
I plan to get schooled again this Sunday. Goal is to only get lapped once in the A this time.. Baby steps..
#476
I'm not 100% on that. Not even sure what the actually come with. I know Bill at Full Throttle zapped the magnets heavily and the magnetic field when up a ton from when he got the OEM cans from Trinity. The LRP X-12 motor I ran in my touring car was alot harder to turn over than my Trinity DUO2 is.
#477
If you run 2wd mod buggy the turnout is normally 15 plus and growing. The next biggest class is 17.5 SCT. These are and will be the two largest classes all year. Electric buggy as in 1/8th scale is dead at the moment and would suggest that only as a 2nd class since we are not getting a turnout in that class.
Jeff
Jeff
Jeff,
Thanks! I knew that bumps had a good selection of losi and AE. So should I look into a AE then. I want to have a good selection of parts and help available. I don't have a motor, so look into either a 13 or 10.5? Is there a popular motor of choice?
#478
Tech Legend
The lines on the can are in 4 deg increments. I was looking at roar rules and there isn't anything really stating rotor diameter...hmmm. I guess you would probably lose some rpm and gain some torque and efficiency with a larger rotor. I don't need any more bottom end so i guess i will stick with what i got.
#479
Tech Legend
Wyd, what is considered mod for that class? As far as equipment? I was going to run my ebuggy this sunday and bring my slash. Is there really no one else show up with those? I'm surprised there isn't a decent showing. Thanks for the help.
Jeff,
Jeff,
#480
Hey, thinking of coming and racing some offroad with you guys tomorrow. I have the RTR SC10 Brushless. Is this legal for the spec class? Didn't seem like the rules page was clear on that (or I can't read).
Thanks.
EDIT: Read through this thread. Looks like I'm in 17.5 class (and I need some tires...)
Thanks.
