Bumps and Jumps 2010 - 2011 season
#1771
#1773
Alright if Hass and Medina are running E-scale sign me up! New car should be here tomorrow so I should be good to go!!LOL If I can make it down.. Gota talk with the Boss.
#1774
The more E-Scales the better!
Jason, I'm running a 1700kv motor with a 19t pinion. I would think 18t would be a good starting point with a 1900kv motor. I have a spare body but it depends on the batteries you are using. Are they hard case?
Blue JConcepts 7s are good but I think Bar Codes would be a little better. M3 Inside Jobs work too.
Couple tips on building RC8s
1 sand the diff cups so they are true and less prone to leak. I ran mostly 5-5-3 or 4-4-2 indoors this season.
2 take your time with the front steering knuckle bushings. The top is different than the bottom and make sure they are 'keyed' in.
3 Put a little black automotive RTV under the center diff riser to secure it perminantly in place. It makes it easy to rem/reset diffs and do pinion changes.
#1775
#1776
#1777
I guess Ed , Travis and I aren't enough competition?!? Or maybe you just want it to be at least 5 against 1 on the Hyper!
#1778
I'm going to try bow-tie m2's
#1779
#1780
#1781
I have my e scale all ready to go for sunday!
#1782
#1783
FUNCTION FROM
Do you have yours ready to go? There's room for it in the "also ran" category, along with all the other AE's
#1784
#1785
Tech Legend
Trader Rating: 51 (100%+)
