Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 03-07-2011, 04:48 PM   #1561
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by DirtRacer68 View Post
Does anyone else run a 17.5 Murf Dogg motor? This past weekend I ran 81/28 with 0 deg motor timing and 45 deg in the speedo. I barely had enough juice (5000mah pack) to finish the 10 minute A main and the motor came off the track at 123 deg. I guess my questions are, is my gearing ok with the motor temp? and if so, should I adjust the gearing and how much?
Gearing should be more like 22 or 23 with that 81 spur gear. Not sure what RPM range you run or if you set it but I know 4500 low rpm and the high should be 11,300. Its a good starting spot. If anything lower the RPM range to 3900 low and then the high aroun 9600 or whatever the highest setting that is shown in the high end. Start with stock timing on the Murf Dog or maybe plus 5 degrees but I wouldn't go more than that. Cheat timing at 40 degrees to start and maybe 45 max. Start power set on high.
ST Racing Concepts (STRC)
Old 03-07-2011, 04:48 PM   #1562
pswag115's Avatar
I'm running my smurf @ 19/81 o degree on can, 40 in mmp 3500-9700 ish. Runs with anybody on the back strait. Temps @ 140-150 in main. less than 2000 Mah put back in packs. Running TP 65C 5300s. Cant think of any more info to share, now let the blue sc10 by u in the main on sat and we can call it even. Cant wait for Sat, got a new toy!
I hid some guys keys at Motorama.
Durango DESC410R, FF03 Pro 17.5, Mugen MBX6 E
Brushless Revo, SC10 FT 17.5
Jammin SCR10, XXX-T, XXX-SCT Stock Spec
pitstophobbies.net
pswag115 is offline   Reply With Quote
Old 03-07-2011, 05:13 PM   #1563
DirtRacer68's Avatar
I know what you're saying, I just can't seem to get the motor temp over 100 deg and with the 0 deg timing on the can, heat is important to get it running strong. I came down last Tuesday and tried different gearing, motor timing, speedo setups, without avail. Also, why is it that everywhere you look it states for a 17.5 motor the ideal Final Drive Ratio should be 7.5?
AE FT SC5M W/LRP SXX TC Ver.2, LRP X12 8.5
AE FT T5M W/LRP SXX TC Ver.2, Orion VST Pro 7.5
Bumps & Jumps, G's R/C Raceway, Pit Stop Hobbies
DirtRacer68 is offline   Reply With Quote
Old 03-07-2011, 05:17 PM   #1564
Eric, I appreciate the advice but I couldn't get those temps until I was in the 20's on the pinion. As for letting the blue truck by, I did that enough years ago at Kranzels
Old 03-07-2011, 05:23 PM   #1565
Krazykeith's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to Krazykeith
anybody know the name of the closest hotel near bumps?
Krazykeith is offline   Reply With Quote
Old 03-07-2011, 05:45 PM   #1566
ets
ets's Avatar
damn keith u campin out?
ets is offline   Reply With Quote
Old 03-07-2011, 05:49 PM   #1567
Krazykeith's Avatar
Yes I am...Gonna need all the practice and setup time I can get.
Old 03-07-2011, 05:49 PM   #1568
jac9's Avatar
Trader Rating: 16 (100%+)
Post up in his thread asking him what to do he will put you in the right direction, I had great luck with my murfdogg 17.5 boosted in touring car it was ballistic.
Thanks to Bumps and Jumps RC, Bullet Motorworks
jac9 is offline   Reply With Quote
Old 03-07-2011, 05:51 PM   #1569
jac9's Avatar
Super 8 is the close one but its not very nice to say the least! I always stay at the Best Western right by he turnpike and it's super nice. And if you tell them you coming in for Bumps they usually give a better price.
Old 03-07-2011, 05:52 PM   #1570
jac9's Avatar
Congrats to Ed Toth on his run in E-scale this past weekend! from what I can see Mike owes you an apple!!LOL
Old 03-07-2011, 05:52 PM   #1571
Who?
Old 03-07-2011, 05:54 PM   #1572
jac9's Avatar
Who?
Hold on for a second and I willget you the info. HIs name is Matt Murphy you should remember him he is a hugh Dirtoval guy. He used to race for CDK and raced trucks and edm at the open wheel alot.
Old 03-07-2011, 05:56 PM   #1573
jac9's Avatar
Who?
I see you already posted he will get back to you shortly I'm sure. If not go to dirtoval.com and look for SilverBullet thats his screen name there. He run the Best of the West racing series for dirt oval.
Old 03-07-2011, 06:04 PM   #1574
Ok, thanks
Old 03-07-2011, 07:12 PM   #1575
wyd
Tech Legend
wyd's Avatar
7.5 ratio would work for alot of 17.5 motors but with no boost from the speedo. They would run that ratio just running timing on the motor.
Heat on the motor is just a gauge. If its fast it honestly don't matter what the temp is as long as its under 175 degrees.
