Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 03-03-2011, 03:15 AM   #1501
KG74's Avatar
+1, u can't fix stupid! It's the one disease there's no pill or cure for
-Ken Garner-
Team Associated/Reedy/Fat Head Designs/KJ Designs
KG74 is offline   Reply With Quote
Old 03-03-2011, 03:31 AM   #1502
Russ G.'s Avatar
Trader Rating: 95 (100%+)
Originally Posted by Fred Perkins View Post
SERPENT RULESSSSSSSS!!!
Yeah I'll be there!!!
Awesome Fred.
Originally Posted by Cappy View Post
Yea...I Dunno !! Im not going if your gonna be there !!
Boy dont start, just get your lazy butt up there and stop holding hands through the shopping malls on Sunday. Its race day!
Jay where u at?
Russ G. is offline   Reply With Quote
Old 03-03-2011, 09:02 AM   #1503
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by wyd View Post
I worked on the Tekin some tonight since I have then 212 software. Its a little faster with the my Viper motor in it but with a Trinity Duo3 17.5 it will be faster for him yet. If he had a MMP in I can make him faster yet but I just don't have as much knowledge with the Tekin so it will take me more time.
Hell I want my Slash back.
Would you mind sharing where you're at with the Tekin settings? Would really appreciate it! I'm getting close but get such little track time at Bumps. I have the 212 software, but the Duo2 and a XXX-SCT .. I just get such little time at the track, especially bumps.
You running any endbell timing? I saw some setups had a small amount of endbell timing - I guess to help from the 0-5k or so RPM range - and then the ESC boost kicks in to add from that start range through 20k or so. And then it seems you're supposed to set the timing (though it's ignored in sensored mode) to 100 percent in the event the sensor wire comes off. That way you can keep running and not go into limp mode..
goehm is offline   Reply With Quote
Old 03-03-2011, 10:04 AM   #1504
Trader Rating: 23 (100%+)
This is what i ran my tekin at:
timing profile c1 or c2
forward only
sensored only
push control off
reverse speed 0
neutral width 3
throttle min. 10 (higher#= more punch)
advance 0 (if a sensor wire comes off you will know it right away)
boost 50* end rpm 18,000
start rpm i think was 5,280 (5,000-5,500)
turbo 0
mechanical timing +8* (duo 2 timing marks are in 4* increments)
Gear at or around 84/20-21 for xxx(2.43:1) and 81/21(2.6:1)
should come off around 110* in 10 min. main.
Mike C is offline   Reply With Quote
Old 03-03-2011, 10:25 AM   #1505
pswag115's Avatar
Who's this Mike C guy? Everyone knows Luck is the setup guy!
I hid some guys keys at Motorama.
Durango DESC410R, FF03 Pro 17.5, Mugen MBX6 E
Brushless Revo, SC10 FT 17.5
Jammin SCR10, XXX-T, XXX-SCT Stock Spec
pitstophobbies.net
pswag115 is offline   Reply With Quote
Old 03-03-2011, 10:50 AM   #1506
goehm's Avatar
forward only
sensored only
push control off
reverse speed 0
neutral width 3
turbo 0
Awesome - Thanks. If you're at the electric race on Mar 11 I'll cover your lunch!
Old 03-03-2011, 11:11 AM   #1507
Trader Rating: 42 (100%+)
Yeah ok pete
bumpsandjumpsrc.com
Scale Speed - High Performance Dirt Oval
ShtLuck is offline   Reply With Quote
Old 03-03-2011, 12:32 PM   #1508
Cappy's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Russ G. View Post
Awesome Fred.
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 03-03-2011, 01:50 PM   #1509
goehm's Avatar
For XFactory AND Tekin??
Old 03-03-2011, 01:53 PM   #1510
I can set you up with a shipping label that will make both of those way faster....
bumpsandjumpsrc.com
Old 03-03-2011, 02:55 PM   #1511
pswag115's Avatar
I cant think of a brand he has not owned in the last year, serpent maybe!
pitstophobbies.net
Old 03-03-2011, 03:45 PM   #1512
If I get the nitro 8th bug that is a likely option though...
bumpsandjumpsrc.com
Old 03-03-2011, 03:55 PM   #1513
jaybird's Avatar
Jay where u at?
man i gota take a break....motoroma hurt my pocket
plus they changed my hrs at work ....but that is why i can't make opening day on april 1st at vineland that really sucks ...unless i can someone to change days with me but i dought it
Jay Miller
Dover,De
jaybird is offline   Reply With Quote
Old 03-03-2011, 04:19 PM   #1514
Hey you have my permission to put your ads on my thread. I'm not going to wine or cry about it. Actually, it promotes the hobby! So, if your that upset about promoting it and you feel threatened then remove it. Actually the name was a track here in the 80's, in fact that might just be where the name came from........huh Not intended to take racers, just let them know about a track here in pa.
HotRod Hobbies is offline   Reply With Quote
Old 03-03-2011, 06:40 PM   #1515
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
forward only
sensored only
push control off
reverse speed 0
neutral width 3
turbo 0
Use Mikes settings. I don't know much about 212 other than I have it on my computer incase someone needs it. I don't know exactly how everything kicks in on the Tekin yet. Timing Profile I had Frank at 3 because I didn't know what the others actually changed. I need to go onto Tekins site and do some reading.
My RPM range on Fransk is very close to what Mike posted so at least I was close one something. For a non Tekin user I had Franks truck pretty good and that was with my Viper motor in. He is going to put in a Duo3.
ST Racing Concepts (STRC)
