Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 07-14-2010, 01:29 PM   #286
Landscaper's Avatar
How long are your 1/8 Nitro buggy,truggy A-mains 20-30 min?
Mugen Mbx7, Mugen Mbx7E
Sweep Racing Tires
http://www.roarracing.com/
Landscaper is offline   Reply With Quote
Old 07-14-2010, 02:02 PM   #287
ww29's Avatar
Trader Rating: 15 (100%+)
they have been 12 minutes
ww29 is offline   Reply With Quote
Old 07-14-2010, 02:42 PM   #288
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by ALF420 View Post
The surface looks GREAT just didn't see that 80ft elevation change or the stairs or the Daytona turn that guys have been telling me about so they have 2 tracks and the video ONLY show the SC track if you have any of the 1/8 scale post them up THANKS
That video is the 1/8 scale track, it's just not that great of a video where you can see the actual size. All lanes on track are 12 ft wide. G's are 10ft. Not sure what yours are. They normally practice on Tuesday nights, so if you have extra time, it might be worth your trip to check it out. Those lap times are a running at full throttle on 65% of the track too. It's that big that you can run full throttle through most the track and I am not talking about gearing down either and doing it. Also notice that the camera is zoomed in most of the time to even get the vehicles in some sort of view.
jmackani is offline   Reply With Quote
Old 07-14-2010, 04:07 PM   #289
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to T. Herwig
Here's a video...stock short course class. The quality is pretty bad, as well as the filming. It'd be better on the stand, but during the races, especially the past weekend of racing, it was very packed. Anyway, here it is. I'll get the other videos up... Including: Mod SCT, Truggy, and Buggy mains.
+ YouTube Video
Tyler Herwig
Tekno RC teknorc.com ∙ JConcepts jconcepts.net ∙ Spider Hobbies spiderhobbies.com ∙ SMC smc-racing.net ∙ Upgrade RC upgrade-rc.com ∙ Kustom RC Graphics kustomrcgraphics.com
T. Herwig is offline   Reply With Quote
Old 07-14-2010, 04:28 PM   #290
ww29's Avatar
thanks for filming and putting the videos up
Old 07-14-2010, 04:37 PM   #291
Landscaper's Avatar
Thanks any chance on getting them up to min of 15 minutes?
Sweep Racing Tires
Old 07-14-2010, 04:40 PM   #292
goehm's Avatar
Trader Rating: 44 (100%+)
Default Question about SC Stock
Hey guys - now that the RTR brushless kits are out I'm closer to finally buying some gear! I have some questions about your SC stock class ... is it spec? Do you care about battery / motor as long as it's either out of an RTR truck or 17.5 turn?
What do you think about the following to get me rolling:
Team Associated SC10 2WD Brushless Race Truck Kit
- Probably will buy ball diff upgrade.. does this matter for your stock class?
(2) ZIPPY Flightmax 4000mAh 2S 25C LiPo Batteries (4000mAg 25C ok? what are the popular battery types??)
Hyperion EOS 0606I AC/DC Charger
Also - what tires do ya'll run typically? Goose Bump?
Thanks for any tips/input - Gary
goehm is offline   Reply With Quote
Old 07-14-2010, 05:05 PM   #293
T. Herwig's Avatar
Hmm, i'm not sure about your SC10. What turn will the motor be out of the box? If it is infact, 17.5t, I don't think they'd have a problem letting you run in spec class. However, if it's faster, you'll probably be placed in the Mod class. As for popular battery types, you're right on. Anything from Hobbyking is generally really popular. They're simply, affordable, and effective! If you run in stock class, you must use stock tires. They can be from any kit, as long as they come in the box. I used to race spec short course, and I recommend the Slash tires, as they are the best all around tire. However, they use a 12mmm hex, and the SC10 uses a pin. You may be a bit limited there in stock class. However, if you jump up to mod, I recommend either AKA Enduros, or Proline Calibers in the M3 compound. Don't bother with super soft when it's this warm out in the summer. It will result in premature tire wear. Soft will be just fine. Any questions? Let me know
Tyler Herwig
Old 07-14-2010, 05:40 PM   #294
goehm's Avatar
Thanks for the info! Motor out of the box? Good question - all I can see is that it's a 'Reedy 3300kV Brushless motor', model ASC916. Haven't found turn equivalents in my web searches...
Spec SHOULD be easy, because if it comes in the RTR box it should be good to go. Right? But when the box CHANGES (when they went brushless) - it got a little more confusing for me. UGgh. Hopefully the ASC916 is a 17.5T brushless equivalent??
Old 07-14-2010, 05:45 PM   #295
T. Herwig's Avatar
Well, since it is 3300kv, that would be faster than a stock motor. I'm not to familiar with 1/10 scale stuff, but I owned a VXL motor (3500kv) and that was much, much faster than a stock SCT. Normally, if you bought the original SC10, with the Reedy 17T ( Correct me if I am wrong) you'd be good in stock class. However, this motor is a good deal faster, and I believe due to this, you would be placed in mod class.
Tyler Herwig
Old 07-14-2010, 05:49 PM   #296
jmackani's Avatar
I have seen 17.5 run in the associated and they are far from spec. A 21.5 is equivalent to the stock motors from our testing this past winter. If you follow the same rules as G's the ball diff is not allowed there. The ball diff is a significant performance advantage the actually helps with rear traction.
Old 07-14-2010, 06:04 PM   #297
thebatman's Avatar
Here are the current rules for Stock Short Course that are listed on our website. These are subject to change as we see how things develop but for now this is what you can go by.
1/10 Scale Short Course 2WD "Stock"
Limited to the stock motor from any brand of 2WD Short Course truck OR any brand of ROAR APPROVED "spec" 17.5 turn brushless motor and ESC. Limit of 7cell NIMH/NICD or 2S LIPO battery. Aftermarket tires and RPM parts are allowed.
thebatman is offline   Reply With Quote
Old 07-14-2010, 06:31 PM   #298
thebatman's Avatar
+ YouTube Video
Thanks for working on the videos! Any video is usually better than no video. I've added this one to the Videos page of the FTRC site and will add the others once you have them uploaded.
Old 07-14-2010, 06:33 PM   #299
ww29's Avatar
goehm use the enduros soft on your sc10
Old 07-14-2010, 06:39 PM   #300
T. Herwig's Avatar
Here is mod short course 4x4. Uploading Truggy now, and then buggy.
+ YouTube Video
Tyler Herwig
