Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 02-28-2010, 02:58 AM   #436
crymynal's Avatar
Originally Posted by bando711 View Post
NEWS FLASH!! I broke something on my Slash today.......and Anthony's.
Yeah, HE broke something on HIS slash today.......and Anthony's.
I did not break my Slash....Ken broke my Slash!!!!
Anthony Ince
Race Director: The Hill, BBSCT, and any others we come up with
Team Terribles Regional Team Organizer/Japan
TEAMS: Team Terribles, Team P.O.R.N. (www.pacificoffroadnitro.4t.com)
RACERS: Caster Fusion, Tamiya TA-05R, TA-05, M-03M, Caster K8-T, and many more!!!
crymynal is offline   Reply With Quote
Old 02-28-2010, 03:04 AM   #437
bando711's Avatar
Beat the hell out of them all day and their fine..........kick it one time and it breaks...........I really feel bad
Ken - Caster Racing 2011, Team Driver, Okinawa, Japan
K8T Pro Truggy, Werks .21B5
ZX1.5R Werks .21B5
EX-1.5R Pro, MMM 1800KV
bando711 is offline   Reply With Quote
Old 03-01-2010, 06:58 PM   #438
YDBD's Avatar
Send a message via MSN to YDBD
Ken did a good job of kicking some slash...he was into breaking things that day...
speaking of breaking Paulie is breaking a record of no shows to any track. Apparently he just like the mini z stuff now and will be listing the rest of the stuff as slightly used and under tested in the japan update....
In thinking about the glitching of the transponders...these might help out...
http://www.amainhobbies.com/product_...tage-Protector
But in more thinking, I don't think I am at full throttle at that point in the track, more like coasting or hitting the brakes, so hitting the brakes would cause mucho radio interference at least on the Fusion, but not on the K8T...
Jon
RC and Beer Brewer
the only way to DUI!
YDBD is offline   Reply With Quote
Old 03-01-2010, 08:10 PM   #439
YDBD's Avatar
Rob on your chassis-maybe add a little ride height too or I'll swap out some springs that are a bit stiffer so it won't let you chassis bottom out when landing. I lost my chassis brace screw in the last run, but only bent it slightly as it's 7075 vs. 6061 alum.
Jon
RC and Beer Brewer
Old 03-02-2010, 03:18 AM   #440
bando711's Avatar
A little hint for you guys that are about to get your Caster buggy. Our track is a bit rough and will take a toll on your chassis, we have some rocks that reach out and leave some nice gouges. In a perfect world with a smooth track the ideal setup is to run your a-arms level to the ground, this keeps a lower CG and she will not roll so easy.........but it's not a perfect world. I am running 20mm clips in the rear shocks and 15mm in the front. My Fusion sits a bit high but it does help to minamize the damage. I have not had any issues with the buggy wanting to roll or flip in the corners, we do not have anything I would consider a high speed corner, as a matter of fact even with this setup it corners better than any buggy I have ever driven. Just something to keep in mind as you setup your buggies for "THE HILL"
ZX1.5R Werks .21B5
Old 03-02-2010, 04:10 AM   #441
chemfrk's Avatar
Jon and Ken,
Great and thanks for the advice,
I am in the process of reworking the entire car to tighten, smooth and ponder the entire car,
until my driving abilities improve and my style progresses past go straight really fast..... slow way down, turn go straight really fast,,, jump, crash, turn..
more suspension may just be the thing I need to save the car and to assist in improving my driving abilities.
I will say the servo made a huge difference, I am becoming more comfortable with the car and the help you have all goven has been incredible.
Thanks again,,,
Rob
Robert
Caster Fusion EX-1
Slash
XTM Mammoth
Tamiya TT-01E
chemfrk is offline   Reply With Quote
Old 03-02-2010, 04:24 AM   #442
I'm just waiting for parts to arrive to make my full scale assault on all fronts.
- Paulie
pgeldz is offline   Reply With Quote
Old 03-02-2010, 04:32 AM   #443
bando711's Avatar
Glad the servo helped, practice is the key, don't worry about being fast just focus on clean laps and the lap times will start to come down. Once we get the stand......hint hint.......it will much easier to run the far side of the track.
ZX1.5R Werks .21B5
Old 03-02-2010, 06:04 AM   #444
Murdadock's Avatar
Send a message via Skype™ to Murdadock
Dude, I have totally been thinking the same thing about the DB-01 (and Igys comments about it being an off-road track). Especially after rain, the track is rough and alot of my issues were the rocks throwing the buggy around. I think I will try running it up a few notches next time.
Jason
Caster EX-1
DB01 Durga, Firestorm Fix (Flux)
Axial Scorpion, TRXS Slash
TA-05 (Sticking w/ Beginner Class BTW)
Murdadock is offline   Reply With Quote
Old 03-02-2010, 06:24 AM   #445
Mr. Bojangles's Avatar
Trader Rating: 14 (100%+)
how big are your shock bodies on the caster buggies, and what oil are you guys running in your shocks?
Josh
TEAM BOJANGLES RACING
Ascendancy Racing
Z01-T JG O'Donnell SS.21 Powered---FOR SALE
HPI Blitz
Mr. Bojangles is offline   Reply With Quote
Old 03-02-2010, 07:03 AM   #446
bando711's Avatar
They are 17mm diameter bodies and the caps are 20mm. I am running 50wt all the way around, a little heavy for a buggy but I will keep it there as long as there is the flat landing zone on the triple, it seems to help some.
ZX1.5R Werks .21B5
Old 03-02-2010, 04:59 PM   #447
bando711's Avatar
Just some info on adjusting your servo saver on the Fusion (or anything else), Robert, didn't check yours the other day but it looked a little loose comparing it to mine.
A good way to check the tension on your servo saver is to turn on the power to the servos and grab the front wheels and try to move them from side to side like they would move if they were being turned by the remote. If you will watch the servo saver while doing this you will understand what it does and how it does it. If the wheels are fairly easy to move with the power turned on then your saver is probably too soft and needs the spring tension increased by tightening down the collar. Just make sure to tighten it enough it takes "medium" force to engage it. With stronger servos with metal gears they should take the strain of a saver a little on the snug side and you will see MUCH improvement in steering response all around especially in high speed corners.
Hope this helps.
ZX1.5R Werks .21B5
Old 03-03-2010, 09:04 PM   #448
bando711's Avatar
Kinda quiet of the forum.......... I plan on being @ "THE HILL" all day Sunday. Anyone else?
ZX1.5R Werks .21B5
Old 03-03-2010, 09:17 PM   #449
YDBD's Avatar
possibly Saturday AND Sunday....is there an elevation change yet???
oh, Igy, you can stay on the ground, you need some handicap...
Jon
RC and Beer Brewer
Old 03-03-2010, 10:43 PM   #450
Well, I might bring the 10th scale stuff out. I got half the parts I needed to finish the 8th scales, but the other half just shipped yesterday, and First Class mail at that (not Priority). So we'll see what's what when it all shakes out.
I'm finishing up 4 Mini-Z bodies at the moment (my Mini-Z parts did arrive), so I plan o nthrowing down the gauntlet to Kenji pretty soon to challenge his record for the MR-03 chassis.
How's the weather look for this weekend, and do we have a drivers' stand yet?
- Paulie
Courtney Marine Corps Base Off-Road Track Okinawa Japan YDBD Track Locator Forum 922 03-20-2010 02:53 AM
Tags
japan off-road, okinawa military rc, okinawa off-road, okinawa rc, remote control okinawa
