Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 02-06-2010, 02:16 AM   #226
Send a message via Yahoo to murrayusmc
Default Just Got to Okinawa
I just got to okinawa yesterday. Im on Kinser. Want to know when you guys are running. Is there a schedule. Also I run Mugen. where can I go for Parts? Are there local hobby shops on or off base? Thanks for the help.
murrayusmc is offline   Reply With Quote
Old 02-06-2010, 03:53 AM   #227
YDBD's Avatar
Send a message via MSN to YDBD
Heya Murray!
Welcome to Okinawa, it's usually not this cold!
Guys usually run Sat and Sun AM till early afternoon. Some may be out there Monday as it's a down day for superbowl...
RC Paradise at Navel Kadena past Kadena Air Base on 58 carries some Mugen parts. They are your best bet for most of your stuff.
Don't know if your getting a car, but you can catch the green line to Foster and bus or cab it to Navel Kadena. And you can green line to Courtney tho its a ways.
Jon
RC and Beer Brewer
the only way to DUI!
YDBD is offline   Reply With Quote
Old 02-06-2010, 06:32 AM   #228
crymynal's Avatar
Welcome Murray. I work on Kinser. So you may see me during the week.
Anthony Ince
Race Director: The Hill, BBSCT, and any others we come up with
Team Terribles Regional Team Organizer/Japan
TEAMS: Team Terribles, Team P.O.R.N. (www.pacificoffroadnitro.4t.com)
RACERS: Caster Fusion, Tamiya TA-05R, TA-05, M-03M, Caster K8-T, and many more!!!
crymynal is offline   Reply With Quote
Old 02-06-2010, 10:23 PM   #229
Welcome Murray.
There are 4 main hobby shops off base.
Siro - Located in Naha, mostly an on-road touring car shop. Sells Tamiya, Yokomo, Kyosho Mini-Z, Active Hobby, Futaba, and Ko-Propo, plus a bunch of odds and ends like Square, etc. Limited off-road items.
RC Paradise - Located in Naval Kadena, full service shop that sells just about everything.
X-Hobby - Located on Hwy 58 just past Camp Foster going towards Naha. Mostly a wharehouse for Active Hobby Products, but does sell limited items, and I do mean limited. I go there for nitro fuel, as they are usually the only ones on the island that sell Klotz fuel (which I like a little better than the Cosmo sold everywhere else)
T-Slide - Located out Gate 2 on Kadena. Almost exclusively an R/C drift shop. Can order anything though.
Again, welcome.
- Paulie
pgeldz is offline   Reply With Quote
Old 02-06-2010, 10:32 PM   #230
Well, since the weather is officially bunk, I decided to get down to business with the fleet.
First to go under the knife was the D8. Stripped it down to get to all the diffs, and went with the Vorza set up (5/5/2). Changed out the motor and installed the fully modifed Massive Mods Go Tech 3 port. It was already broken in, and tuned in Australia using my fuel, glow plug, and pipe set-up, so it should be pretty close and require no break in whatsoever. We'll see.
The Vorza is up next. Need to change the ESC programing, and build the 112mm shocks for testing.
After that, the DB01 will get the shock treatment, as I broke a shaft last time out. I'll go ahead and just re-build them all while I'm at it.
Then finally, will be the EVO 5 MS. The highly programmable Tekin RS ESC is installed and I got a set-up from the man himself, Randy Pike (head guy at Tekin). Need to download the Vegas 2.0 software and load his set up for a base setting. I'll see how it goes from there once I get the chance to test at Yomitan (if it ever stops raining).
- Paulie
Old 02-07-2010, 01:12 AM   #231
bando711's Avatar
........this rain has got to quit, I am to the point I am doing work on the Slash, we all know how much I love that truck. Everything else is good to go, Fusion EX-1 is ready to test a new setup, made some adjustments to the ESC to dial out some initial power, can't stand Paulie whining cause he can't keep up on the straight. re-did the shocks and trying some medium springs and adjusted for more droop front and rear. DB-01 is fitted with a wing........and a crappy paint job.....and the Mamba Max is setup, should be a good starting point. I hope the next time out it jumps a little better.
The Baja got the 'Killer RC" cutoff switch installed........5 minutes to install, 2 hours of teardown to access. Finally got the Baja tuned after break-in, I'm sure the neighbors just love me!!
Still waiting on the new Truggy, it better come in on Tuesday, I have no more RC work to do and I'm not bonding with my wife all week.
Anybody use the ABS function on their Transmitter, is it compatable with a brushless system? Having a hard time getting the 1/8 buggy stopped after the straight away, just looking at options.
Ken - Caster Racing 2011, Team Driver, Okinawa, Japan
K8T Pro Truggy, Werks .21B5
ZX1.5R Werks .21B5
EX-1.5R Pro, MMM 1800KV
bando711 is offline   Reply With Quote
Old 02-07-2010, 02:22 AM   #232
Well, considering you had it 100% limited last time, I don't see how you'd be able to dial any more out of it, ha ha ha. I gotz somthing for ya next time though
As for the ABS, usually it's for servo'd brakes, but I don't see why it wouldn't work with the ESC. It's basically like a rapid on/off switch, so it should work.
Let us know how you make out...
- Paulie
Old 02-07-2010, 04:28 AM   #233
P00DLE's Avatar
Send a message via Yahoo to P00DLE
You guys are not the only ones building and rebuilding. The dirt/mud is a PITA to remove from a Blitz.
Anyways, I'm trying to install a used Spektrum rx (3500) in my crawler but the guy didn't send the bind plug. Does anyone have a bind plug I can borrow?? I know they're cheap, but so am I.
And yes, I've tried making one, but I can't get it to work either.
Scott
HPI, Tamiya(s) and a rock racer in the works
P00DLE is offline   Reply With Quote
Old 02-07-2010, 04:34 AM   #234
Sorry Scott, I'm a Futaba guy myself. Maybe Ken has one. I know he ran Spektrum at one point...
- Paulie
Old 02-07-2010, 01:38 PM   #235
bando711's Avatar
I just did this the other day, take an old servo wire and twist the neg and pos leads together, works like a champ.
HOW TO BIND
1. With the power off, plug the bind plug into the BAT port.
2. Power on the receiver by connecting the battery to any unused port. The blue LED should be blinking.
3. Position the throttle stick in the desired fail-safe position (normally low throttle).
4. Press and hold the bind button on back of the transmitter while turning on the transmitter. The button should
flash for about 5 seconds, then both LED’s (transmitter and receiver) will go solid green.
Important: Remove the bind plug after binding.
ZX1.5R Werks .21B5
Old 02-07-2010, 03:43 PM   #236
P00DLE's Avatar
Alright, thanks. I'll try this once the superbowl is over.
Well, I couldn't wait so I hooked everything up then hit the power switch to my ESC and
POOF!!! and a thick cloud of white smoke.... Cheap ESC anyways!!
Now this gives me the chance to upgrade to the Novak ESC.
Thanks Ken!! Seriously Thanks
Scott
Old 02-07-2010, 04:59 PM   #237
crymynal's Avatar
I bet it works like a champ! ROFLMAO
The bind plugs I have (I'll give you one next time, just ask) link the two outer wires. That should be the neg and signal wires.
Anthony Ince
Old 02-07-2010, 05:18 PM   #238
P00DLE's Avatar
I'm glad somebody is enjoying themselves at my dispense.
Well, I'm not one to take failure so I'm going to try to hook this thing up to my Blitz... Hopefully no smoke this time.
SUCCESS!!! Now the Blitz is on 2.4 ghz
Thanks Ken for the right instructions and Anthony for the right placement.
I always succeed at bringing one on board, but taking another one out!
Scott
Old 02-08-2010, 01:31 AM   #239
HASTINGSRJ's Avatar
I am on Kinser as well, we may have to get together next weekend and run our cars.....I just got fuel today, charging batteries now....too late now to run it, hopefully tomorrow. I work at the chowhall here on Kinser, I am there every day (only SSgt in cooks whites).....
I finally caught xhobby open....I went looking for another shop around Kadena today but didnt find it....
Rob
traxxas revo 2.5r to a 3.3.
traxxas slash 2wd
HASTINGSRJ is offline   Reply With Quote
Old 02-08-2010, 02:03 AM   #240
bando711's Avatar
Scott, I for one am not laughing, I may be full of shit but I don't normally give bad advice. I was in a rush when I typed it out, my bad. If you did smoke the stock ESC let me know how much it is to replace.
shame on you Anthony
ZX1.5R Werks .21B5
Courtney Marine Corps Base Off-Road Track Okinawa Japan YDBD Track Locator Forum 922 03-20-2010 02:53 AM
Tags
japan off-road, okinawa military rc, okinawa off-road, okinawa rc, remote control okinawa
