Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 05-20-2012, 03:42 PM   #2011
JarheadRCGuy's Avatar
Send a message via AIM to JarheadRCGuy Send a message via Yahoo to JarheadRCGuy
Yeah, I was waiting to get my batteries once I got over here, and now that I am here the USPS is trying to hold me back form running my buggy! Every LHS I have been to has either itty bitty LiPos, or none at all. And if you are looking for a servo that will steer a 1/8 buggy around....don't bother - just go online.... :-(
Tango Down Grafix | Tweeked Monkey Racing | Team Terribles
What? You're upset that the track is blown out? Guess what? It's called OFFROAD FOR A REASON!
JarheadRCGuy is offline   Reply With Quote
Old 05-20-2012, 06:51 PM   #2012
So where abouts is everyone located? I'm at Foster.
Old 05-20-2012, 11:17 PM   #2013
claycity's Avatar
All your battery needs from hobbyking and have it delivered to someone who lives off-base.
Igy sorry about RCP on Sunday i worked 13 days straight 12 hours a day i had finally caught up with sleep when you had called, but had to go to work that night at 2300
Y.M.H. Racing
"IF WE DIDN'T RACE, SOMEONE ELSE WOULD BE LAST"
Build it idiot proof and the village builds a better idiot.
THE HILL AT COURTNEY IS NOW AT http://www.2kboffroad.com/themudpit
claycity is offline   Reply With Quote
Old 05-21-2012, 04:19 PM   #2014
In that sense, Clay; would you be willing to be my recipeint for out in town deliveries?
Old 05-21-2012, 05:23 PM   #2015
YDBD's Avatar
Send a message via MSN to YDBD
can do too, if you need batteries now I have a few you can borrow or purchase. I have 4 4000mah 30c with deans and 4 5000 40c with pole plugs and deans adapters.
Jon
RC and Beer Brewer
the only way to DUI!
YDBD is offline   Reply With Quote
Old 05-22-2012, 03:56 AM   #2016
raycerZ's Avatar
Jon, is there still racing at Blues Bay?
raycerZ is offline   Reply With Quote
Old 05-22-2012, 04:00 AM   #2017
raycerZ's Avatar
Got any like these for sale?
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Old 05-23-2012, 02:36 AM   #2018
crymynal's Avatar
Greg....the timing system is by KO Propo. I think the model number is TD-1. You can pick up the transponders at Siro for about Y1600 or ask RCP to order them for you. There are three types of transponders, easily identified by their color (blue, green, and black). All three work with the system.
What else did you want to know about it?
Anthony Ince
Race Director: The Hill, BBSCT, and any others we come up with
Team Terribles Regional Team Organizer/Japan
TEAMS: Team Terribles, Team P.O.R.N. (www.pacificoffroadnitro.4t.com)
RACERS: Caster Fusion, Tamiya TA-05R, TA-05, M-03M, Caster K8-T, and many more!!!
crymynal is offline   Reply With Quote
Old 05-23-2012, 03:12 AM   #2019
claycity's Avatar
where can you get one my friend back home built a track wants one how much are they?
Y.M.H. Racing
Old 05-23-2012, 05:28 AM   #2020
claycity's Avatar
Well I hack it and wow what a shit load of options it has now
and here they are
This is a preliminary manual for alternative firmware for FlySky FS-GT3B/C radio
and clones. This manual is written as differences to original firmware.
This firmware is completely written from scratch and is not compatible with the
original Flysky firmware. It is distributed with NO-WARRANTY.
All of the model setups saved by original firmware will be erased!!!
You can backup your original firmware and config, use tabs "PROGRAM MEMORY" and
"DATA MEMORY" in STVP to read it from radio a save it to disk.
Flashing firmware
- uset STVP (ST Visual Programmer)
- select "PROGRAM MEMORY" tab
- load firmware "gt3b-VERSION.s19"
- program it with "Program -> Address Range..."
- set "Start @" to "8000"
- set "End @" to "E70F" (it is possible to find place where zeroes
will start and use last non-zero address)
- press "OK"
- if "Program -> Current tab" will be used, all models stored at FLASH
will be erased
Global characteristics:
- 63 model memories, first 8 in EEPROM, rest in FLASH
> numbers 10-19 will show with Right-Arrow
> numbers 20-29 will show with Left-Arrow
> numbers 30-39 will show with Left+Right-Arrows
> numbers 40-79 will show like 0-39 with additional Percent symbol
- added Subtrims
- added SaveAs to save model config to another memory location
- added Global Setup menu to change function features, including backlight time,
battery low voltage, etc.
- dead zone for steering and throttle
- added key mapping specific for each model memory
- calibrate menu will be automatically invoked after first power-on with
this firmware, so 6 menu items will start to blink
- when radio is powered on with steering/throttle not in dead center,
it beeps 3 times if poweron not-centered warning is allowed
- added inactivity alarm
- added settable servo speed
- added 4WS, DIG, MultiPosition functions
- added timers (up, down, lap, lap count)
Buttons:
- it is now possible to differentiate between long press (>1 second) to
normal button press (short) and it will be recognized like "ENTER-long"
- Trims, DualRate and other popup informations
> now shows changed value only temporaly (5 seconds or till another
key press), values are saved to EEPROm automatically when it disappears
> when autorepeat disabled on trims (default), reset trim to 0
by pressing both trim keys together for long
(eg. TRIM_LEFT-long + TRIM_RIGHT-long and similar for channel 2 trim)
> while value is showed, it is possible to change it with rotate
encoder also
> when value set to reset_value (usualy 0), longer beep sounds to
attention to it and short pause is intruduced to ignore keys
Main screens:
- changeable by rotate encoder:
model name
battery voltage
timer1 - ENTER and ENTER-long operates this timer, not standard menu
timer2 - ENTER and ENTER-long operates this timer, not standard menu
Standard menu:
- swapped behaviour of ENTER and END when editing items, ENTER now select
next value and END (+ ENTER-long) will end editing items
- ENTER-long on ABS will leave menu also (as BACK)
- Trims are now only for steering and throttle
> trim move center position without moving endpoint positions
- Expo
> value for channel 2 is splitted to forward and back and is indicated
by arrows
> positive values are those You want to use like at Spektrum radios
- DualRate
by arrows
- SaveAs
> choose menu MODEL and press ENTER-long
> menu MODEL will blink
> choose memory position where to save model config
> press ENTER/BACK to save it
- Model number of channels and Model reset
> choose menu NAME and press ENTER-long
> menu NAME will blink
> choose "C" for number of model channels or "r" for model reset
- reset will show NO/YES
- Subtrims
> subtrim moves center position together with endpoint positions
> choose menu TRIM and press ENTER-long
> menu TRIM will blink
> set subtrims for each channel
- channel speed
> choose menu D/R and press ENTER-long
> menu D/R will blink
> select channel
> for channels 1 and 2 (steering and throttle)
- turn wheel left to show left arrow
- this represents Turn speed or throttle speed
- turn wheel right to show right arrow
- this represents Return speed or
"throttle speed only for forward" (OFF/ON)
> select required speed 1...100%
- 100% means no delay
- 1% means above 4s delay end to end
- directly setting channel value of channels 3..8
> values for 4WS and DIG channels cannot be changed
> this can be used instead of mapping some key to appropriate function
> choose menu EXPO and press ENTER-long
> menu EXPO will blink
> select channel and press ENTER
> select value in range -100..100 and press enter
- mixes 4WS, DIG, throttle brake cut-off (for boats with forward-only
throttle), Multi-Position (to set arbitrary up to 8 positions),
brake channel (to send brake side of throttle to extra channel)
> choose menu EPOINT and press ENTER-long
> menu EPOINT will blink
> select one of mixes 4WS (4), DIG (d), brake cut-off (b),
multi-position (P), brake channel (8)
for mixes 4WS, DIG:
> press ENTER and choose channel for this mix or OFF
- for dual-ESC steering (boat, tank, ...) select DIG channel 1 and
with steering D/R reduce required ESC travel (at 100% it will go to
contra to allow steering at place)
> press ENTER and set mix in range -100...0...100 %
0% is default and means both channels have same max steering/throttle
100% means 100% reduce on rear steering/throttle (eg. no steering)
-100% means 100% reduce on front steering/throttle (eg. no steering)
> for 4WS press ENTER and select crab (CR1) or no-crab (CR0)
for Multi-Position:
> there are 4 Multi-Positions identified by numbers 1..4, they have
8/6/4/4 positions
> press ENTER and choose channel for this function or OFF
- channel can be "D" also, which means map to DIG function
> press ENTER and set channel value for first position
> press ENTER and set channel value for second position or END
> ... up to eight position
for brake cut-off:
> press ENTER and choose OFF or CUT
for brake channel:
> press ENTER and choose channel fro brake or OFF
- Key mapping specific for each model:
> choose menu REV and press ENTER-long
> menu REV will blink
> choose trims (id: 1 2 3 d) or other keys (CH3: C, Back: b, End: E) or
if trim is OFF, then also trim keys (id 1 2 3 d with left/right arrow)
> press ENTER and modify first setting
> press ENTER and modify next setting
steps of settings of trims (1 2 3 and D/R):
- sequence:
function -> buttons -> step -> reverse -> opposite_reset -> previous_val -> rotate
- function: selected function listed at the end of manual
- B buttons:
MO - momentary, hold left/right trim key to get end values,
when nothing pressed, servo is at center
NL - no long keys, long press is the same as short press
AR - autorepeat is on
RS - long press of one of trim keys will reset to
centre/reset value
EN - long press of trim key will set to coresponding end value
- step: select trim step for one trim key press (1, 2, ... 100, 200),
not available when buttons MO or fuction is list of items (multi-position)
is identified by symbol "V"
- RE reverse:
0 - no change
1 - swap left/right trim keys
- OR opposite_reset: not available when buttons MO
0 - no change
1 - when trim key is pressed and value is at opposite
side of center/reset, set value to centre/reset,
- PV previous_val: available only when buttons MO or fuction is list of
0 - no change
1 - instead of setting value to centre/reset when key is released,
it is set to previous value, which was active before key press
- RO rotate: available only if fuction is list of items (multi-position)
0 - no rotate
1 - rotate from max item to first item and back
steps of setting of keys (C b E 1< 1> 2< 2> 3< 3> d< d>):
- sequence:
function -> momentary -> reverse -> prev_val -> function_long -> reverse_long -> prev_val_long
- MO momentary: only available for 2-state functions (channel, ...)
0 - switch, key press will switch something (channel value, ...)
1 - momentary, value change will be active only while key is pressed
- RE reverse: only available for 2-state functions
0 - normal, no-press or default value is left endpoint
1 - reverse, no-press or default value is right endpoint
- PV prev_val: only available for 2-state functions
0 - key release or OFF state sets value to left endpoint (noREV)
1 - key release or OFF state sets value to value active before
key press or ON state
- function_long: function applied when long press of key happens,
choose from the same list as function,
identified by "V" symbol
- reverse_long: same as "reverse" + "V" symbol
- prev_val_long: same as "prev_val" + "V" symbol
steps of settings of ch3 potentiometer (if enabled at global config):
- sequence:
function -> reverse
- RE reverse:
0 - no change
1 - swap left/right sides
Operating timers:
- select timer1 or timer2 main screen with rotate encoder
- timer1 is identified by left arrow, timer2 by right arrow
- lap count is written to 3char LCD place
- timer value is writen to 7seg + 3char LCD place in format:
0000 - MMSS minutes, seconds
0000 % - SSHH seconds, hundredths (0.01 seconds)
- press ENTER to set timer params, use it as usual menu:
H set throttle trigger start OFF/ON
timer will start after
throttle forward applied
A set alarm 0..255
in laps for lap counter
in minutes for others
P set timer type:
OFF timer is off
UP up timer
TxS start/pause timer
TxR stop + reset timer
DWN down timer
TxR stop + reset timer and save rest time
to lap times
when alarmed at time 0, starts counting
up with "V" symbol blinking
LAP lap timer - 100 lap times are saved
TxS record lap time, show it for 3s blinking
and during this time presses are ignored
to eliminate double click
when timer not running, start timer
when timer alarmed, stop timer and save
lap time
TxR stop timer
LPC lap counter - till 255 laps
TxS increment lap counter, minimum 3 seconds
between presses are required to eliminate
double click
TxR zero lap counter
- pres ENTER-long to show saved lap times (only for LAP and DWN timers):
> It is possible to see lap number (indicated by 'L' at 7seg number)
or time showed as other timer values. Press ENTER to switch between
lap number and time value
> use rotate encoder to switch between lap numbers or lap times
> there are special lap number identificators also at 3char display:
- Txx - total time, 'xx' is number of laps
- Axx - average time, 'xx' is number of laps
- RES - pres ENTER and lap times will be erased, it is also
displayed when showing lap time
Calibrate menu:
- enter it by wheel right-turn and ENTER-long
- 6 menu items starts to blink (+ 2 arrows if CH3 is potentiometer)
- use END or ROTATE to change channels
- there is also channel 3 representing CH3 button (for those who will do
some 3-position switch/potentiometer modification)
> There is 1K resistor connected between CH3 button and +5V, so
simply connecting linear potentiometer instead of CH3 button
will not work. Usefull results can be done with logarithmic
potentiometer 10K which has 1K at half of turn. Or eliminate
internal resistor to +5V, connect potentiometer between +5V
and GND and potentiometer output instead of CH3 button.
- there is also channal 4 representing battery voltage
- calibrate as usual (for channel 1/2 left+mid+right and ENTER)
> calibrated value will disappear from menu
> it is not needed to calibrate all values
- calibrate CH3 potentiometer (if selected at global config)
> only left + right positions
- calibrate battery (it will not be probably needed to use this)
> select channel 4
> press ENTER
> set your current battery voltage (measure it by voltmeter)
> press ENTER to save it or END to no-save
- press BACK-long or ENTER-long to end calibrate menu and save values
Key-test menu:
- enter it by wheel left-turn and ENTER-long
- if ENTER-long keep pressed, all segments on display will stay on till
ENTER is released
- now check keys by pressing them short or long
- if keys long pressed, an "L" symbol will appear left to displayed key symbols
- press BACK-long or ENTER-long to end key-test menu
Global setup menu:
- enter it by ENTER-long
- now menu items MODEL and NAME will start blinking
- select requested item by ROTATE and press ENTER
- use ROTATE to change value and press ENTER to end value changing
- press BACK or END or ENTER-long to end global setup menu,
values will be saved to EEPROM
- selected menu items are indicated by following symbols:
F firmware version (this of course cannot be changed :-)
L backlight time 5s,10s...10m...MAX
I inactivity alarm OFF,1m...10m
LOW POWER! battery low voltage 2.0...10.5V
C default number of channels 2..8
E maximum allowed endpoint value 100...150%
DANGER - values greater than 120% can damage
your servo or will not be possible
to transmit to receiver because of
2.4GHz HF module limitation
This danger zone will be indicated with a flashing
'%' symbol for values greater than 120%
A analog settings, dead zones, ADC samples used
steering dead zone S00..S50
throttle dead zone T00..T50
number of ADC values A_4/A_1
b beeps
key beep K_N/K_Y
value at center/reset beep V_N/V_Y
poweron beep P_N/P_Y
poweron not-centered warn C_N/C_Y
d long press key delay 100...1000 miliseconds
H setting of hardware features
reverse rotate encoder E_N/E_R (Normal/Reverse) - for GT3C
ch3 is potentiometer P3N/P3Y (No/Yes)
select ppm sync/frame PTS/PTF (constant SYNC/frame length)
select ppm length Lxx - 3-18ms for constant SYNC length
9-24ms for constant frame length
r global or all models reset
all configs (global+model) G_N/G_Y (No/Yes)
all models M_N/M_Y (No/Yes
o lock keys till ENTER-long No/Yes
Return to original (and modified) firmware:
- flash original firmware
- delete whole EEPROM (tab DATA MEMORY in STVP and write those empty zeroes)
or return back your saved config (also tab DATA MEMORY in STVP, read
your saved config from disk and write it to radio)
- calibrate steering and throttle (not needed when You returned back saved
config)
Functions assignable to trims:
OFF - nothing, it is possible to assign each button individualy
as key
TR1, TR2 - trim of channel 1/2
DRS, DRF, DRB - dualrate of steering/forward/back
EXS, EXF, EXB - expo of steering/forward/back
CHn - change channel "n" value in range -100...100
STn - subtrim of channel "n"
SST - steering speed turn 1...100%
SSR - steering speed return 1...100%
CSn - channel speed for channel "n" 1...100%
4WS - 4 wheel steering mix -100...100%
DIG - DIG throttle mix -100...100%
MP1 - Multi-Position 1, switches position up/down
MP2 - Multi-Position 2, switches position up/down
MP3 - Multi-Position 3, switches position up/down
MP4 - Multi-Position 4, switches position up/down
Functions assignable to keys:
OFF - nothing
CHn - switch channel "n" value from one end value to opposite end
value. There is special handling for CH3 button. When using
3-position switch instead of CH3 button and momentary is
selected for this button, then centre 3-pos value will also
be detected and set to servo (use 1K resistor to GND to get
middle state)
CnR - reset value of channel "n" to centre
4WS - switch crab (CRB) no-crab (NOC) for 4 wheel steering
DIG - switch DIG mix between -100 and 100 (more useable when using
return to previous val key setting)
DGR - reset DIG mix to centre
MP1 - Multi-Position 1, switches position up (at END back to 1.)
MR1 - Multi-Position 1 Reset, switches position to first one
MP2 - Multi-Position 2, switches position up (at END back to 1.)
MR2 - Multi-Position 2 Reset, switches position to first one
MP3 - Multi-Position 3, switches position up (at END back to 1.)
MR3 - Multi-Position 3 Reset, switches position to first one
MP4 - Multi-Position 4, switches position up (at END back to 1.)
MR4 - Multi-Position 4 Reset, switches position to first one
T1S - start/pause timer1
T1R - stop + reset timer1
T2S - start/pause timer2
T2R - stop + reset timer2
BRK - switch on full brake, this overrides throttle position
BLS - battery low shutup, stop beeping, predefined to END-long
Y.M.H. Racing
Old 05-24-2012, 12:34 AM   #2021
Courtney Saturday 0900. If it rains I will be @ RCP @ 1100.
Got my batteries from Hobbypartz today.
igyrigged is offline   Reply With Quote
Old 05-24-2012, 03:03 PM   #2022
I'm going to try and make it up there, if nothing more, just to meet some new faces and what not.
Old 05-24-2012, 06:40 PM   #2023
I've got a Tekin RX8 2650kV setup in my MBX6 Eco, and was wondering if this LiPo would be a good candidate for it? (I'm still kind of confused on all the LiPo terminoligy and what not)
I'd appreciate your input. Thanks!
Old 05-24-2012, 07:01 PM   #2024
YDBD's Avatar
That is a 3 cell 11.1 volt lipo, for you MBX6 you probably need a 14.8 volt, which is a 4 cell (3.7V per cell). You can get two 2 cells and wire them together too...
Jon
RC and Beer Brewer
Old 05-24-2012, 09:58 PM   #2025
See, that's where I'm confused....I've heard get a 3s, and just about the same amount of people have told me to get a 4s....AARRGGHH!! So damn confusing!
Courtney Marine Corps Base Off-Road Track Okinawa Japan YDBD Track Locator Forum 922 03-20-2010 02:53 AM
Tags
japan off-road, okinawa military rc, okinawa off-road, okinawa rc, remote control okinawa
