Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 07-29-2009, 04:43 PM   #1
Armaan's Avatar
Trader Rating: 49 (100%+)
Default WCRC (West Coast Raceway) Setup Thread - 1/8 4WD Buggy | 1/10 SC Truck | 1/10 Buggy
This thread will serve as a guide for various classes running at WCRC and will benefit those who plan on visiting the track for the first time.
1/8 4WD Buggy
Chassis: Associated RC8/Tekno
Tires: Pro-Line Holeshot M3 Compound F&R
Motor: Tekin RX8 1900KV
ESC: Tekin Dual Mode
Battery: Max Amps 18.5v 5000 mAH
1/10 SC Truck
Chassis: Associated SC10
Tires: Pro-Line Holeshot M3 F, Pro-Line Edge R
Motor: Castle/Mamba/Neu 17.5
ESC: Castle
Battery: Reedy 7.4 4000 mAH
1/10 2WD Buggy
Chassis: Losi XXX CR
Tires: Losi Eclypse
Motor: Losi Xcelorin
ESC: Losi
Battery: MaxAmps 7.4v 4000 mAH
(above are only examples, not actual setups)
Armaan is offline   Reply With Quote
Old 07-30-2009, 03:17 AM   #2
chonchachencho's Avatar
1/10 SC Truck
Tires: Bow-tie M3 rear, stock front
Motor: LRP stock spec 13.5
ESC: LRP
Battery: Orion 3600, 25c
Chassis: stock
wheel base: medium long
Diff oil: 3000 wt
Shock oil rear/spring: 27.5/silver
shock oil front/spring: 35/ gold
shock pistons/spacers front: 2/5*
shock pistons/spacers rear: 2/3*
front caster block spacers to the bottom*
ride height rear: dog bones slightly below level
ride height front: arms slightly below level
camber front: -2
camber rear: -2
zero toe in front
slipper: about 5 feet or less
3/4 oz led weights in servo area*
2/4 oz led weights in rear
i struggle with traction rolling at west coast so the * indicate what has helped me decrease the amount of rolls i do during a race. ha ha
Adrian Ramos
IBEW-SPEEDTECH RC
chonchachencho is offline   Reply With Quote
Old 07-31-2009, 05:07 PM   #3
someone try my set up!!
Adrian Ramos
IBEW-SPEEDTECH RC
Old 08-01-2009, 04:00 AM   #4
DannyS's Avatar
Send a message via Yahoo to DannyS
I just ran my Hyper 9 tonight with the tekin 8 system, futaba servo, and 25c 4200 and ran for about 16 minutes. I'm using pink compount Hot Bodies tires. I'll get you the name of the tire soon. Josh Alton ran the same tire as myself. I TQd but he ended up getting the best of me. It's a great tire and compound. I'm sure others will work very well too. Let me know if this helps out. I never knew how fun 1/8th scale was. I'm rebuilding all my 1/10th scale AE cars and going to run them but I'm mad because I can't beat Jeramy Kortz lap time of 23.4. The closes I got in racing was 23.6. I'll get there and give him a run for his money.
Danny Stojakovic
West Coast Raceway & Hobbies
Off Road Club Racing Wednesdays @ 7pm & Saturdays @ 6pm
714.739.4298
DannyS is offline   Reply With Quote
Old 08-03-2009, 04:13 PM   #5
ckaspar's Avatar
After seeing you run on Sunday I am going to have to give that a try! You were hauling Ace!
Chris Kaspar
West Coast R/C Raceway and Hobby Garage--www.westcoastrcraceway.com
RnCPhotography--www.rncfoto.com
ckaspar is offline   Reply With Quote
Old 08-03-2009, 05:54 PM   #6
Armaan's Avatar
Thanks bud, I think they are the Hot Bodies Megabite: http://www.hotbodiesonline.com/products/en/67781.html
Old 08-04-2009, 11:44 AM   #7
louis flood's Avatar
Send a message via AIM to louis flood
yep those are them we have them in stock in the hobby shop
powered by venom-group , atomik and evolution sports in Redlands CA paintball airsoft and R/C (909)792-9898
my rides atomik v2mr ae b44.2 tlr 8ight 2.0
louis flood is offline   Reply With Quote
Old 08-05-2009, 10:50 PM   #8
Armaan's Avatar
What do you all recommend for motor/ESC/battery for 1/8 Electric? I saw some guys running the Castle setup (green motor sticks out like a sore thumb).
Which motor/ESC did Josh Alton and Danny run?
Thanks in advance!
Old 08-06-2009, 10:09 AM   #9
Default battery
u know that a good subject ,could we get some info 1/8 e ...what are you guys using and what battery are working . i just got a 2650 mm system and dropped in a caster conversion mugen . it came with 2 battery trays to balance the chasiss and i'm confused on what battery to get to make this thing hall-ass. can u fell my pain!!
isuzuguy is offline   Reply With Quote
Old 08-06-2009, 12:51 PM   #10
Armaan's Avatar
Yeah, some of the guys were running 3s setups, though 4s would be more economical long term, especially if you run 2s in the 1/10 2WD and 1/10 2WD Truck class.
Anyone have advice on motor/ESC/battery combos for 1/10 2WD truck? Deciding against 1/8 4WD Electric due to the cost (the TEKIN RX8 runs $300 and an entire 1/10 2WD setup would run $350, which includes the truck/buggy).
Old 08-10-2009, 11:20 AM   #11
brian losey's Avatar
Default slash
got a question can i run a sealed diff in spec slash, currently stuffing it with grease. my setup. 19/90 pinion/spur. currently traxxas tires all around. shocks-50 wt frnt-40 wt rr. 1 limiter in frnt shock, 2 limiters in rr shock(1 is allready in there) front and rear shocks all the way out. currently using 5100 nimh packs, hard to keep up in acceleration, speed is ok though.will try going back to 18/86.will try bringing the shock back in a hole or two on the rear.keep experimenting until i find an excellent setup.if anyone needs help i'll try to help.
team terribles answear-rc,torco fuel,fastlane graphix,caster racing products,maxamps,clockwork racing engines,and bcg industries.
brian losey is offline   Reply With Quote
Old 11-05-2009, 03:06 PM   #12
Armaan's Avatar
Bumping this up for WCRC's grand re-opening!!
