Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 10-15-2007, 04:25 PM   #1426
d4man's Avatar
Gixx, I want a full explanation on why you weren't at McCullough's on Saturday
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 10-15-2007, 04:57 PM   #1427
jallshouse's Avatar
Send a message via Yahoo to jallshouse
i need some help from you li-po guys....i went to charge my orion 4800 tonight and this is the error i got from my ice charger:
output voltage is lower than the selected cells or voltages, please select the proper cells or voltages
not sure whats up here....charger is set up for 4800 li-po, and charging is set to 4.8 amps.....any ideas, i dont wanna blow [email protected]*t up just yet?
...oh yeah, i even adjusted the amps all the way down to .01 trying random numbers in between with no success
jallshouse is offline   Reply With Quote
Old 10-15-2007, 05:13 PM   #1428
Default li-po
Jeremy,
First check to see if you have any voltage with a meter at the + and - ports.
I think McGhee had a problem similar to that. He discharge it to low and it was hard to get it back up an he still thinks he messed it up.
I have heard of the wires coming off inside the pack from a hard hit.
C.R.
lovell is offline   Reply With Quote
Old 10-15-2007, 05:14 PM   #1429
jallshouse's Avatar
Originally Posted by lovell View Post
Jeremy,
C.R.
thanks C.R. i will check it out.....sounds like the pack may be junk huh?
Old 10-15-2007, 05:14 PM   #1430
Jim
I got the maxamps lipo today and I feel the 7.5 will be enough for inside and outside. It pulls the front wheels at will with no added weight on black top with pink slicks. The truck weights 62.6 oz. with only 1 oz in the rear but it might come out also.
C.R.
Old 10-15-2007, 05:19 PM   #1431
Jeremy
I talked to Mike Sunday and he said that Travis with his 3200 would out motor him with all same electronics except for the battery. Mike thinks the battery is bad but I am not the expert on lipo's. Did the pack take a good hit?
Old 10-15-2007, 05:23 PM   #1432
jallshouse's Avatar
Jeremy
no hard hit....i ran it not this past friday but the friday before, and it was sittin in the car doin nothin, i turned it on tonight to play around with the speed control profiles....i turned the switch on, turned the wheels to the left then the right just to make sure i had power and the thing just faded to nothing instantly.\
oh yeah, i bought the battery used (supposed to be slightly used) it didnt seem to have much punch or runtime from what everyone talked about, maybe it was junk from the beginning
Old 10-15-2007, 05:38 PM   #1433
MacTheKnife's Avatar
[QUOTE=jallshouse;3768437]no hard hit....i ran it not this past friday but the friday before, and it was sittin in the car doin nothin
J, did u leave it plugged in, if so it may have discharged to an unsafe level and wolnt take a charge.
Mac
MacTheKnife is offline   Reply With Quote
Old 10-15-2007, 05:39 PM   #1434
jallshouse's Avatar
[QUOTE=MacTheKnife;3768485]
Mac
yup...oops, didnt think about that one is it junk?
Old 10-15-2007, 05:54 PM   #1435
morris's Avatar
Trader Rating: 40 (100%+)
[QUOTE=jallshouse;3768496]
jeremy,
yea that sucks ass.......
morris is offline   Reply With Quote
Old 10-15-2007, 06:32 PM   #1436
Jeremy two things:
1. You might of bought an abused battery
2. Leaving it plugged in is not a good thing just like Steve said. Even with the switch off the current still 'bleeds' through it.
Old 10-15-2007, 07:05 PM   #1437
pipester's Avatar
Mac
Mac , You drunk or just learning to type ??
pipester is offline   Reply With Quote
Old 10-15-2007, 07:18 PM   #1438
pipester's Avatar
Jim
C.R.
CR , sounds good . I think that's the route i will be going vary shortly ! all i will have to do is refoam the pinks and i'll be ready to go ! BTW Check your pm's !
Old 10-15-2007, 07:25 PM   #1439
jim my pm's are empty. if you sent something try again
Old 10-16-2007, 02:45 PM   #1440
Send a message via Yahoo to goinbrokeracin
Anybody running 4cell stock Nascar this week? I was contemplating coming up if I can get my car finished and was wondering if anybody will be there to race against. Thanks.
goinbrokeracin is offline   Reply With Quote
ALTOONA RACEWAY 1/10 SCALE ELECTRIC TROPHY RACE gixxerman Racing Forum 2 08-13-2008 03:17 PM
R/C Pilots Welsome at the Altoona Raceway - Altoona, PA Reznor88 RC Flight 0 01-14-2008 06:11 PM
SPECIAL EVENTS COMING AT THE ALTOONA RACEWAY - ALTOONA, PA Reznor88 Racing Forum 1 01-14-2008 06:10 PM
SPECIAL EVENTS COMING AT THE ALTOONA RACEWAY - ALTOONA, PA Reznor88 Electric On-Road 0 01-06-2008 05:27 PM
altoona raceway morris Racing Forum 0 05-26-2007 09:13 PM
