Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 08-06-2007, 05:18 PM   #631
pipester's Avatar
brian , thanks for the hook up on the parts !! man if you didn't show i couldn't have raced (the little bit i did do !) THANKS MAN !!!!!!
Ed do ya have to teese me like that with that link to kranzels ?? man if toona did somthing like that this winter , i'd be in for sure !! hell as cool as that looked i'd probably give up dirt all together ............ well ok i lied on the last little part , but that track looked like a frikin blast !!
pipester is offline   Reply With Quote
Old 08-06-2007, 05:30 PM   #632
gdux's Avatar
Default cash race
Thanks Doug, Chuck and the rest of the Altoona crew, We had a good time Sunday even with the rain shortened event.I wish we could've come down Saturday.We plan on coming to the next one too. But next time we plan on coming for the weekend so we can get some more track time before the Mains
Ed that 1/18track ia exactly what we used to race on when i first began back in the early 90's all carpet with wood and other various things under it for obstacles.It was great no dirt only carpet fuzz and the surface was always the same.
Old G
gdux is offline   Reply With Quote
Old 08-06-2007, 05:31 PM   #633
brian roeder's Avatar
Jim, not a problem glad to help.iam checking on what might be wrong with that motor i will let you know what i find out.
brian roeder is offline   Reply With Quote
Old 08-06-2007, 07:44 PM   #634
pipester's Avatar
Default crf news
brian , i have a thread started on here for info too , so far nothing . thanks for still looking into it for me . I will be waiting to see if you find anything . I do think i am going to replace the crank bearings and try that . other than the front crank bearing leaking , i am lost ! the thing that has me puzzled is that i've had engines in the past that pissed out the front bearing and had no issues with the tune going all over the map because of it .
Old 08-07-2007, 07:19 AM   #635
d4man's Avatar
Jim, I have a thought on that engine. I heard somewhere the carb's on those engines are very inconsistent. I thought I heard somewhere that you could put an OS carb on it and fix it. Of course, I could be wrong.
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 08-07-2007, 07:25 AM   #636
iCeNuTz's Avatar
OS Carbs fixed problems with the Traxxa's engines. Snorton had to do it to his. It would suck to buy one of those and it still not work.
iCeNuTz
I like chili
iCeNuTz is offline   Reply With Quote
Old 08-07-2007, 07:29 AM   #637
d4man's Avatar
Hmmm, maybe someone will pop in with the correct answer on which OS carb fits that engine.......I thought I heard that is an awesome engine, just the carb is junk......
Old 08-07-2007, 01:07 PM   #638
d4man i had problems with my carb on my original wasp the LSN oring was messed up si i ran an os carb on it until i got an old picco carb needle and i think the os carb you had to adjust the settings greater than the wasp carb. but that is with the wasp(original) iam tring to get my new CRF then i will let you know, maybe the rotary carb will be better than the slide.
jim if you want i have the adapter and a os carb we can try.
Old 08-07-2007, 01:30 PM   #639
morris's Avatar
Trader Rating: 40 (100%+)
roeder,
youre cars looked really good....wish mine were the same....will have to get together sometime and race again..............
morris is offline   Reply With Quote
Old 08-07-2007, 02:21 PM   #640
pipester's Avatar
forman , that was my other thought , that the carb was at fault . its either the carb or a damn air leak . it just gets an inconsistant lean hesitation whenever it feels like it . nothing seems to really set it off , it just happens...............whenever [email protected]#%#^ $#%$#*
brian , if you have a carb and adapter i would be happy to try it ! any thing to get the answer before i throw money away and don't find the problem ! I want to figure this damn thing out ! not just because it's retarted fast but for my own knowlege too . I am leaving for vacation this sat and should be back in time for the race the week after . is the os carb you have a rotery or slide ?? the truck is set up for a rotery right now but could be changed back for a slide if need be .
Thanks , Jim
Old 08-07-2007, 04:06 PM   #641
Jim it's a 10er rotary.
Old 08-07-2007, 07:54 PM   #642
d4man's Avatar
Jim, this may or may not apply to you. My buddy was having a similar problem with his high dollar big HP engine in his 1/8th scale. After all the trouble shooting he did, it ended up being a lean bog. I read your other threads on the issue and maybe, just for the hell of it, turn that HSN out 2 turns and see if that helps. I'm thinking maybe your LSN is rich, and your HSN is lean. After you fix the leaky bearing of course......
Old 08-08-2007, 10:08 AM   #643
gdux's Avatar
Default Engine problems.
Young Dux
Old 08-08-2007, 10:30 AM   #644
d4man's Avatar
Ridgeway had the problem over the winter, and into the springtime. He was going to do this, do that, buy new fuel, etc etc. I told him to "Talk to Doug" before he does anything. Like I said, it ended up being 2 full turns in on the Lean side.
Does your engine have a fine adjustment screw on the HSN?? I think I was mistaken by saying that engine's carb is junk. I think they have changed that. Hey, what the hell, it cant hurt to try "2 hours" or 2 full turns out.
Do that AFTER you fix the front leaky bearing!!!!
Old 08-08-2007, 11:27 AM   #645
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Are the results gonna be posted from summer classic weekend?
rallyebmx is offline   Reply With Quote
ALTOONA RACEWAY 1/10 SCALE ELECTRIC TROPHY RACE gixxerman Racing Forum 2 08-13-2008 03:17 PM
R/C Pilots Welsome at the Altoona Raceway - Altoona, PA Reznor88 RC Flight 0 01-14-2008 06:11 PM
SPECIAL EVENTS COMING AT THE ALTOONA RACEWAY - ALTOONA, PA Reznor88 Racing Forum 1 01-14-2008 06:10 PM
SPECIAL EVENTS COMING AT THE ALTOONA RACEWAY - ALTOONA, PA Reznor88 Electric On-Road 0 01-06-2008 05:27 PM
altoona raceway morris Racing Forum 0 05-26-2007 09:13 PM
