Go Back   R/C Tech Forums > General Forums > Track Locator Forum
Old 07-16-2007, 07:25 PM   #466
Jeremy, I thought about it but I bought 4 sets of tires instead. Are you running a li-po, if so which one and what voltage regulator are you using?
Do you have a problem getting the car to rotate, if so, I tried a couple things out recently and all I can say is Wow! I first went to 56(Drilled) -27.5 in the rear shocks, I epoxied the holes shut and drilled in between the epoxied holes with a 56 bit. This supported the rear end a little better. Second I went to 1-a rear camber, didn't allow the rear to roll as much, gave a little less rear side bite. Last, I moved the rear hubs forward .030, which was the biggest feeling change I made.
C.R.
lovell is offline   Reply With Quote
Old 07-16-2007, 07:27 PM   #467
d4man's Avatar
Sneek peek at this weekends track
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 07-16-2007, 07:28 PM   #468
Dave, I will be happy if I make the B-main. The competion will be crazy. I think the c-main will be it for me, my confidence is not all that great now a days.
Old 07-16-2007, 07:30 PM   #469
d4man's Avatar
Dude, you're solid B material
Old 07-16-2007, 07:32 PM   #470
jallshouse's Avatar
Send a message via Yahoo to jallshouse
C.R.
I havent got up enough nearve to try the LiPo thing yet considering i manage to blow up NiMH batteries at times, but they sound awsome for the runtime advantage.
My car seems to rotate ok, but i am gonna try some of that to see what it does. The hardest part for me was to get the car "freed up" in the turns. I went to the Mugen +2MM hubs and that made a big differance for me. Also the 2degree anti-sqat/2degree rear tow plate worked well for me too. I put the M2C one on and i like the way the car feels with it alot better than the standard Losi plate
jallshouse is offline   Reply With Quote
Old 07-16-2007, 07:36 PM   #471
Jeremy I took my 2mm hubs off and it made my car seem more planted. The 2mm hubs made my car feel 'numb'. I have been looking at the m2c plates but didn't make the plunge yet.
Old 07-17-2007, 06:04 AM   #472
fastestcat's Avatar
looks like a friday evening/night test and tune trucks, tt01, minis.. etc
im sure a few races will breakout
fastestcat is offline   Reply With Quote
Old 07-17-2007, 10:52 AM   #473
NeverATiteLine's Avatar
Send a message via AIM to NeverATiteLine Send a message via Yahoo to NeverATiteLine
Default got nitro?
nitro or not ready for nitro yet??
NeverATiteLine is offline   Reply With Quote
Old 07-17-2007, 11:10 AM   #474
fastestcat's Avatar
you can try nitro...
Old 07-17-2007, 11:42 AM   #475
morris's Avatar
Trader Rating: 40 (100%+)
any pics of the oval soon?
mcculloughs track looks tight....
morris is offline   Reply With Quote
Old 07-17-2007, 01:54 PM   #476
jac9's Avatar
Trader Rating: 16 (100%+)
Had a Great time at the HARDING RACEWAY on Sunday evening want to thank Dan and Travis for laying down the smooth surface. And Dan for inviting us over.
I think this track needs a nickname like the "BULLRING". It was Loads of fun!!
Can't what to come out and play again maybe next weekend.We'll see.
Lap times in the high 3 second range with stock 6cell in 1/10 truck.
We run two races one with TT01 for 5min run with Dan taking the win with 53 Excitement filled laps.
And 1/10 stock truck With Gearld putting a whooping on Dan and I with 55 laps.
Later
Jeff
jac9 is offline   Reply With Quote
Old 07-17-2007, 02:30 PM   #477
fastestcat's Avatar
jeff
i have a few dirt latemodel bodies coming for TT01... if they work out ill get a few more...ED did you hear TT01................. will we have tires for friday???
Old 07-17-2007, 02:59 PM   #478
Lux Graphics's Avatar
What time Friday night? I need to get away from these paint fumes. . .
-Chris
www.luxgraphics.com
Lux Graphics is offline   Reply With Quote
Old 07-17-2007, 06:13 PM   #479
morris's Avatar
im down for a little oval action...sounds like alot of fun....
then again any racing sounds like alot of fun....lol
where is the track located at?
matt
Old 07-18-2007, 12:30 PM   #480
iCeNuTz's Avatar
OK, Nitrohouse is HORRIBLE! Please do not order from them unless you speak Stupidish.
I ordered online, they called because they messed up my credit card number, I gave them my correct number, they messed it up again, I called and gave them the correct number again! I called to double check the status today and after the guy asked me for my info 3 times and then waited for 5 minutes on hold, I found out my order still has not been sent.
Horrible!
iCeNuTz
I like chili
iCeNuTz is offline   Reply With Quote
ALTOONA RACEWAY 1/10 SCALE ELECTRIC TROPHY RACE gixxerman Racing Forum 2 08-13-2008 03:17 PM
R/C Pilots Welsome at the Altoona Raceway - Altoona, PA Reznor88 RC Flight 0 01-14-2008 06:11 PM
SPECIAL EVENTS COMING AT THE ALTOONA RACEWAY - ALTOONA, PA Reznor88 Racing Forum 1 01-14-2008 06:10 PM
SPECIAL EVENTS COMING AT THE ALTOONA RACEWAY - ALTOONA, PA Reznor88 Electric On-Road 0 01-06-2008 05:27 PM
altoona raceway morris Racing Forum 0 05-26-2007 09:13 PM
