RCPRO ON-ROAD NATIONAL CHAMPIONSHIP
#16
Roger
#17
This newly added event will kick off RCPRO's return to the On-Road racing scene. Attached is the flyer on the event and the rest of the information can be found on;
Make you plans for this BIG event at the premier RC racing facility in Porter, TX.
See you at the finish line,
Roger
My son & I are looking forward to it
Brian all I can say is I agree SWEEEEEET!!!!
Looking forward to racing with you again Shawn
+100%
Gonna be fun
Thanks for investing the time Roger and Jeremy we GT Racers appreciate you being fair and honest, see you at the races
#21
#26
Hey Bassman, and all other IGT racers.
I have the IGT rules posted on the web site. FYI - I also corrected the flyer to reflect the new dates. Take a look.
Thanks for your patience,
Roger
Roger
#29
1/8 GT rules and flyer for RCPRO Nationals
Roger, BIG Thank you for the 1/8 GT rules.
1/8th IGT Rules:
These rules pertain to the 1/8 off-road based vehicles that feature on-road passenger and road racing body shells.
•IGT cars must be based on current production buggy/truck chassis, drivetrain and suspension components.
•Shaft drive only.
•Non-adjustable centrifugal clutches only – no Centax or adjustable clutches.
•Rubber tires only, no foam tires. Tires cannot extend beyond the body and fender flares may not be added to accommodate larger tires.
•No dish wheels – a minimum of 50-percent of the wheel face must be open.
•17mm hex hubs only – no quick-change hubs.
•Any commercially available “GT/GTP” racecar style/type body. The engine’s cooling head fins can not be exposed from top or sides of body. Rear wing and/or spoiler/flap must be attached to the actual body. (No chassis mounted or “Buggy/Truggy” type wing mounts).
•Maximum of two mechanical disc brakes, which must be mounted to the center. driveshafts/outdrives. No pressurized or electronic braking systems are permitted.
•Maximum of two-speeds – centrifugal, automatic transmissions only.
•Any nitro engine is allowed up to and including .28 engines.
•150cc fuel tank limit.
Read more: http://infernogt.proboards.com/index...#ixzz1ncIYp4Fg
1/8th IGT Rules:
•Shaft drive only.
