M&M Hobbies 1/12 talk
Old 11-15-2010, 05:18 PM
Trader Rating: 8 (90%+)
Default M&M Hobbies 1/12 talk
So lets get some talk about 1/12 going on. We can share setup advice and so on...
I will have my car thursday, I have just purchased a Hotbodies 12x from a guy in Dallas. It has been modified to run tubes and a center shock instead of the friction dampner disk.
I think we should run 17.5 with no dynamic timing. later on when our skill level and we aquire more racers for the class maybe we could also have a turbo class. Whats everyone elses take on the situation?
Tha Skinny is offline
Old 11-15-2010, 06:10 PM
Jimmy Avila's Avatar
Trader Rating: 81 (100%+)
I just picked up a fujin 211go from Danny so I might be running it this Thursday along with my Rc18r in the run whatcha brung class. I'm so pumped!
Jimmy Avila is offline
Old 11-15-2010, 06:44 PM
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Spec timing class is a really good idea. Especially as it doesn't sound like anyone knows what the traction will be like for a 12th.
I'll be there this weekend with a GenXL
AWD
andrewdoherty is offline
Old 11-15-2010, 07:04 PM
I picked up some 25 and 35 shore tires yesterday while I was at Mikes. They will probobly run down pretty quick but ah well..lol
Old 11-15-2010, 08:55 PM
I would start with pink rears and purple fronts. If you need more steering move up in the following order for more steering and less rear bite
Pink/Lilac
Pink/Double Pink
Pink/Magenta
Pink/Pink
Magenta/Lilac
Magenta/Double Pink
Magenta/Magenta
Double Pink/Lilac
Double Pink/Double Pink
tha Beast's Avatar
Trader Rating: 100 (99%+)
when we ran 12th at M&M before i ran 88 spur and 4o-41 pinion it was plenty fast and the tires we all used to use was jaco dbl pink fronts and pink rears they seemed to work the best out there
tha Beast is offline
Old 11-16-2010, 08:35 AM
danthrc's Avatar
The track surface is so new that we don't have to spray it with sugar but when we did, I ran Magenta all the way around and the car was on rails.
Without spraying it this weekend you will need to sauce the tires pretty good and you will have grip. I ran mine last week with compound on the rears only and it was stuck.
danthrc is offline
