Can somebody help me
Im so sorry for posting this but I need some help somehow related to r/c you see i need a radio transmitter, a simple one, and the real issue is that i have to plug it to a bite switch with an 2.5mm stereo output the transmitter just needs to give the on and off signal if somebody can help me i would appreciate i know is not the propper forum but I googled rc transmitter forum and this one popped up if this thread is too off topic feel free to delete it.
thanks
thanks
thanks
thanks
most current gear runs in the 2.4ghz range so you could probably receive it fairly easily. prior gear used fm/am in the 75mhz range and had crystals.
fm transmitters are reasonably easy to build with $10 worth of parts at radio shack if you have some ability and it would give you the push button type of effect you are looking to design.
