New RC WebApp
#16
Bump for an update. Check it out.
Android users, I know that you can't use the drop down menus yet.
I am working on a work around for that.
iPhone users should have problems.
Tracks tab has a map as long as you allow me to see your location.
#17
Well, we seem to be up and running again 100%.
Now to continue on with actual work.
if you all would check the page and make sure things are still lining up for you.
If you have any input at all on how things work/look, let me know - this is all a test project for some larger things to come at work. I don't care to attempt to add any features I can.
I realized I am limited to about 3 tabs on the top before they run off the screen of my phone (I assume its the same for others). So I am not set on that interface, suggestions are welcomed/encouraged/appreciated.
At some point in time I will be adding user accounts and user accessible setup sheets. That's a big step though and a lot of work. For right now I want the gearing to work. I will let track owners add there tracks to my database in the next few weeks. (Art doesn't have to worry about Karns, it already exists )
Thanks guys for help and input.
#19
Admittedly most of this thread is over my head, so this may already exist or just be dumb, but . . . since your doing the gps/nav for the tracks how about putting the lhs's on there as well?
#20
And I'll go ahead and throw the link out publicly :
www.theredwire.org
If you have issues PM me or email
kcarpenter528@ gmail dot com
#22
#23
Updated, combo boxes are working now. Drive ratios should work tonight with a limited set of data.
Working on building up the database still.
