R1 Wurks brushless motors
#451
I had the same sensor board problem. I emailed them through www.r1wurks.com. They responded little slow but they changed the sensor board under warranty. It took some times but they have a great customer service. Just wait.....
#453
Is it easy to change the sensor location on the board? I tested a motor and the timing came back as A:32 B:40 C:40
#455
How does the version 15 to version 16 r1 13.5 compare?
#456
#457
Do many people run the 1700 rotor indoors?
#459
Did u feel an improvement over the standard rotor? Thanks
#463
I am a bit confused about the timing.
I have a 25.5 V16 and from what I have read, I should put the timing at 30 degrees. Correct me if I am wrong.
and this timing where should I read it? on the can, on the motor analyser or on a motolyser?
P.S. I run on a carpet track 80X40 with an F1
#465
For the 21.5 motor, how many amps should the motor draw max?
