Cool Can Fan Talk
#139
Do you plug it to receiver's ch.3 or batt ? What about glitching issues ?
#140
#141
Originally Posted by HarshGuy
I use the "batt" plug for my orion personal lap counter, so I redid my personal transponder connection and ran the double wires (I have the dual one) in together with that connector, works fine, no glitching or missed lap issues at all.
Your right about NOT getting glitchiing with the CCF plugged into the recieiver. But I have personally found that wiring the CCF to the battery wires via the speedo if this is possible, as this way, the fan stays on while you are marshaing, and when returning to your pit the motor will be cool enough to work on.
TCCFM
Attention
We now use genuine carbon fibre collars on the CCF's that require them instead of the aluminum type, ie Yokomo BD,CGM, Corally RDX, Associated TC3/TC4, X-ray Cyclone, Tamiya MSX,
#143
Hi
When making a pattern fron David Spashets MSX i Managed to utilise the screw to the left side of the motor and the 2nd screw to the right of the motor. The CCF will require 2, carbon fibre collars to raise it above the motor. Hope this helps you to understand how it will be mounted.
TCCFM
TCCFM
#145
Originally Posted by 1fastdude
I have been using one and believe me...........it's awesome. Perfect fit, cools the motor, very little battery usage. Can't beat it.
cheers for that vote of confidence dude
#146
#147
Originally Posted by pops
I have the Yoke BD and would like to get carbon fiber collars to replace the aluminum type. How can we do this?
#148
#149
Originally Posted by Matt Howard
Ha Ha, you're out of luck. I ordered one last night and I'll get all the cool new stuff to make it look super trick and you have the old outdated one that still uses aluminum
Did you order it directly from us? if you did, I have NO order from you that I can see
TCCFM
#150
Hi Matt
TCCFM
TCCFM
