Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-29-2009, 11:18 PM   #16996
Rockpyle's Avatar
Trader Rating: 23 (100%+)
Originally Posted by SRW141 View Post
Rocky- A,B,C is left to right. Just like you thought. With the holes in the tabs. You can solder wires on the top or you push the wires through the holes from the piniion side and the solder to the tab.
Hope this helps. If you need something else just ask.
Thanks, I didnt want to screw up my new motor.
I will be using it tomorrow night in 17.R touring car on carpet.
Rockpyle is offline   Reply With Quote
Old 04-30-2009, 03:18 AM   #16997
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey John,
Glad you feelin better. Get well soon and take it easy
Originally Posted by John Tag View Post
Hey Alex...
Both 3800s are same size...
Hey all...
Yea I feel a ton better internally now. Just need to heal my open wounds from surgery. They removed staples monday and that went well for most part. I had 1 section they left open as fluid was building up,Monday they had to open 1 more small section also to help drain fluid. That helps the healing process. I now have 2 open wounds one 3" other 1-1/2 ", Those are open that are packed with gauze and changed daily. They will take 2-3 more weeks to heal naturally. So for now my wife stuff's me after my shower. Not a pleasant thing but all part the healing process. Hopefully I will be back to some light travel soon.....
All orders have been shipped
Im placing next batch duos on Pre-order for next shippment, dealer is in process of move and should be 2-3 weeks. We are also expecting new 40C IP next 2 weeks.....
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 05-02-2009, 05:10 PM   #16998
John Tag's Avatar
Trader Rating: 42 (100%+)
WoW.. After a few weeks I was finally feeling well enough today to get out of the house for some personal fun time. I went racing and was able to set TQ before the rains came at our Touring track in Easley SC. Felt real good to be out in the fresh air today. Still very sore,But making great progress.......
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 05-02-2009, 05:33 PM   #16999
nashrcracer's Avatar
R/C Tech Charter Subscriber
good to hear your out and about again John. take it easy you don't want the stress of TQing to rupture anything again!
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 05-02-2009, 10:15 PM   #17000
Still Bill's Avatar
Hi John,
Is the embedded advance timing of the Trintiy Duo 13.5 I got from you set at 30 degrees?
I am trying to figure out something related to how it interacts with my LRP SPX speedo (set at 8 punch).
Inquiring minds want to know...
Glad you are feeling better.
Thanks.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-03-2009, 04:37 AM   #17001
John Tag's Avatar
Originally Posted by Still Bill View Post
Hi John,
Thanks.
Bill
Hey Bill....
Motor sent out was set at low timming 10*. Being most racer's now days are running Tekin and LRP speedos with high timming advance in speedo . Low 10* is best spot to run on a DUO based motor. With SPX I would run profile #7 and a 5.0 gear ratio to start. If you turn endbell counter clock wise center hole is 20* and all way counter clockwise is 30*.
Hope this helps
Old 05-03-2009, 08:02 AM   #17002
Still Bill's Avatar
Hey Bill....
Hope this helps
John,
With the profile #8, I am now running 5.2-5.4 gearing. Will try #7 with 5.0 gearing today because I have been on #8 settings since installing SPX's on my cars.
FYI...Pretty much all of this is leading up to me running 13.5 at the Reedy in a few weeks. And I do have a 13.5 motor order in to you.
Many thanks.
Bill
Old 05-03-2009, 08:08 AM   #17003
tazz888's Avatar
Trader Rating: 22 (100%+)
Hey guys,
Just picked up a mint RDX (not a phi) in trade with all the goodies for rubber tire on carpet. Anyone have a good starting set up to run on brand new CRC carpet w/lipo? This car is going to hold me over until I get my Xray...
Ron DePoto
Express Motorsports
Pin Shop Hobbies
tazz888 is offline   Reply With Quote
Old 05-03-2009, 08:15 AM   #17004
Still Bill's Avatar
Originally Posted by tazz888 View Post
Hey guys,
Does if have the center steering mod? Or the two parallel steering levers?
Headed off to the track.
Bill
Old 05-03-2009, 08:23 AM   #17005
tazz888's Avatar
Bill
Stock steering setup. I'm an Xray guy so the Corally is like a forign language to me....
Ron DePoto
Express Motorsports
Pin Shop Hobbies
Old 05-03-2009, 12:57 PM   #17006
Send a message via MSN to Jaz406
Hey guys,
So your rdx has the standard length front shocks and tower? if so then
Front
17lb front with 40 wt. I ran 3 hole Tamiya pistons but a large two hole corally will work too.
middle or outside upper shock mount. outer lower shock mount.
second to the shortest upper inner camber link.
Medium front roll centers
4* caster blocks
.5* toe out
-1 degree camber
Rear
14lb spring with 25 wt oil. tamiya 3 hole or Corally large two hole.
outer upper and lower shock mounts.
Medium length camber link. upper row second from outside both inner and outer locations.
Medium high rear roll center. 2* rear toe total.
-2 degree camber
That's about all i can remember, lol
Jaz406 is offline   Reply With Quote
Old 05-03-2009, 01:13 PM   #17007
tazz888's Avatar
Thanks for the info.
Any idea if the Specialized lipo tray for the Phi will work on the RDX?
Ron DePoto
Express Motorsports
Pin Shop Hobbies
Old 05-03-2009, 01:42 PM   #17008
wyd
Tech Legend
wyd's Avatar
Send a message via AIM to wyd
Hey Tag when are you going to plan another trip Frederick? Want to make sure I have my car ready by then. I hope to be up and running in the next 2 weeks. Can't wait. If your not coming up soon I will send you Paypal for that motor on Friday. Wanted to wait til you got up and going again before I took care of that order.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-04-2009, 09:34 AM   #17009
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Hey John, PM sent!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 05-04-2009, 03:11 PM   #17010
Rockpyle's Avatar
Hey Bill....
Hope this helps
Is this the same for the 17.5? So the first is 10 degrees not 0?
Thanks,
Rocky
Express Motorsports Shoot Out John Tag Racing Forum 171 10-28-2011 05:47 AM
2008 Express Motorsports ON Road Championships John Tag Racing Forum 51 07-20-2008 06:18 AM
F/S eXpress Motorsports Team GP3700's Kletke R/C Items: For Sale/Trade 4 06-15-2008 02:56 PM
Express motorsports IB4200 batteries... BRAND NEW samstheman2 R/C Items: For Sale/Trade 16 11-14-2007 02:58 PM
eXpress Motorsports - IB3600s CHEAP!!! Jon Williams R/C Items: For Sale/Trade 0 07-21-2005 04:59 PM
