Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree7Likes
Old 05-03-2013, 08:17 AM   #496
Rumor has it that the new Kill Shot motor doesn't fit the assoc or the T4 car.
Is this true ??
Apparently the motor screw holes don't line up ??
Jackson RC Raceway, Home of the 2011 Paved On Road Nats!
Horsham RC Raceway,Home of the 2013 and 2015 Carpet On Road Nats!
Awesomatix USA/ Side Piece Racing / TQ Wire / CR Graphics / R1 Wurks / LRP /Jackson RC Raceway / Horsham RC Raceway/Brownies Hobbies
Al Sodano is offline   Reply With Quote
Old 05-03-2013, 11:11 AM   #497
Apparently you need to just rotate the motor plate
Old 05-08-2013, 02:34 PM   #498
i just bought a Revtech 17.5 spec motor, and I am looking for the recommended max temp for this motor.
Shock Tower is offline   Reply With Quote
Old 05-08-2013, 03:03 PM   #499
Autocratic's Avatar
Trader Rating: 26 (100%+)
In general you want to be no more than 150F, give or take a few degrees. Some motors run hotter than others, and vis versa. That number should be pretty good to start with.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 05-12-2013, 08:36 PM   #500
mazmo's Avatar
Just bought Killshot 17.5 motor with hi-torque rotor.
Does anyone have a set-up for TC boosted class?
Tuning notes that came with the motor suggests 0-20 deg endbell timing + max 40 deg on ESC (seems low for boosted).
Cheers
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 05-25-2013, 07:23 PM   #501
Has anyone ever tried the revtech with a high RPM rotor?
Just curious since I just bought a killshot rpm and put the HT rotor in it from my revtech and rpm rotor from killshot to revtech.
BTW both 17.5T, thanks
JOE SI is offline   Reply With Quote
Old 05-25-2013, 07:59 PM   #502
Don't go over 160-170F but every now and then if you see 180F it's not going to kill you but change gearing if you see that number
Old 05-28-2013, 10:32 PM   #503
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
What is a good drag brake set points for the new Killshots? Also for a regular Revtech? Im using a rs pro!
Josh-n-ya is offline   Reply With Quote
Old 05-28-2013, 10:36 PM   #504
HighLife420's Avatar
Trader Rating: 49 (100%+)
Send a message via ICQ to HighLife420 Send a message via AIM to HighLife420 Send a message via MSN to HighLife420 Send a message via Yahoo to HighLife420 Send a message via Skype™ to HighLife420
Anyone have a 4800 can answer something for me, does it come with some sort of sleeve to make the rotor shaft 5mm?
Dominic "Dom" Chin
TLR 22 (Tekin RS Pro, LRP X12 7.5t, Savox 1258TG)
MIP Pro4mance SCTE (Tekin RX8, Tekin Pro4 4600kv, JR Z9100s)
Ko Propo Eurus (EX10) Limited Edition
HighLife420 is offline   Reply With Quote
Old 06-25-2013, 01:33 AM   #505
idbdoug's Avatar
Trader Rating: 33 (100%+)
D3.5 17.5 back on ROAR's approval list July 1 2013
idbdoug
idbdoug is offline   Reply With Quote
Old 11-13-2013, 01:31 PM   #506
Hi I have a revtech 17.5. I use this motor in my Sakura Zero on carpet. I want to know what fdr to run for boost. I am using a Speed Passion Reventon Pro Esc, and need some help with FDR and ESC settings.
JustynKace is offline   Reply With Quote
Old 11-13-2013, 02:15 PM   #507
Jerz616's Avatar
Which revtech? The new killshot or the older RSeries. If it's the older revtech them they don't seem to like boost too much. If it's the killshot then which one, torque or rpm? I ran my killshot HT stator with a HT rotor at about a 4.0 fdr with 30* boost. Motor came off at 135*.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-13-2013, 06:12 PM   #508
It is the old R series motor with the 12.5 HT turquoise rotor. I just rebuilt the motor with new ceramic bearings, shimmed the rotor as close to the sensor board as I could get, and a new sensor board. Right now I have the motor at the stock timing, and I will start at 50% Hybrid boost on my SP Reventon Pro. But I am not sure where to start on the FDR. My local track is very tech with a 40' straight.
Old 11-14-2013, 10:21 AM   #509
Jerz616's Avatar
I would be careful boosting thst motor. But prob start somewhere in the mid 5-6 range to be safe and just start checking temps.
Ryan Gracey
XRAY XB8'14
Old 11-14-2013, 11:41 AM   #510
Ok thanks. I will start at 5.57 FDR and try that. Do you know how much timing one mark on the endbell is? And how much timing is the stock setting? Thanks for all the info.
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
