Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 12-13-2012, 11:21 PM   #481
http://www.liverc.com/news/announcem...r_controversy/
Here's where I found the info! I'm not starting anything so don't get yours panties in a bunch!! I just bought the motor and went through a little controversy myself because I have beat the local hot shot at my track and I was accused of cheating because I had the motor! So I was hearing rumors and decided to come on hear and ask the question!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 12-13-2012, 11:24 PM   #482
The jan 1 2013 was a rumor so sorry for posting that but the rest was just asking what's going on with the motor!!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
Old 12-22-2012, 07:25 PM   #483
kevntri's Avatar
Trader Rating: 36 (100%+)
Does anyone know the D3.5 front plate part number?
I can't locate it and I stripped out a mount hole
Team Tekin, Pro-Line Racing, MIP-Moore's Ideal Products, Exotek Racing
kevntri is offline   Reply With Quote
Old 12-22-2012, 07:39 PM   #484
Jerz616's Avatar
Trader Rating: 49 (100%+)
TEP1076.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-31-2012, 11:01 PM   #485
How does gearing compare between a Revtech and D3.5 21.5 for 0 timing? I've just switched to a D3.5 and was surprised to find I had to increase my gear ratio from 2.3 to 2.7 with reduced endbell timing and still running higher temps than before. Is this what others are finding?
J-PaP is offline   Reply With Quote
Old 12-31-2012, 11:13 PM   #486
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Did they both have same rotor? Maybe the older motor made more torque so it ran cooler?
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 12-31-2012, 11:20 PM   #487
Same standard rotor.
Old 01-01-2013, 09:31 AM   #488
Default D3.5 timing and ESC boost
hi,
I got a D3.5 4.5T which I used for 1/12 pancar with a Hobbywing 1S ESC.
I typically use a rollout of 45mm and experimenting with motor timing and ESC boost setting.
Current, i will set the motoring timing to max and adjust the boost setting from 0 to 5. Does it make sense this way ? if I should set boost to a known value and adjust the motor timing instead.
ongbenghui is offline   Reply With Quote
Old 01-01-2013, 10:32 AM   #489
LonnyJ1950's Avatar
Generally I set the motor timing to 0 and use the boost for timing. Adding motor timing adds heat so be careful!!
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-03-2013, 07:52 AM   #490
Thanks for the advise. Will try that out. I do noticed that the motor doesn't really get too hot, but it is the ESC that is usually warmer. Hope it is not a concern.
Old 01-17-2013, 11:02 AM   #491
tessty71's Avatar
Trader Rating: 16 (100%+)
KSG SCX / C&M Mortorsports
Point R/C Raceway
tessty71 is offline   Reply With Quote
Old 01-18-2013, 12:47 PM   #492
Well looks like my source was off 17 days sorry about that!! Lol
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
Old 01-20-2013, 05:18 PM   #493
fastharryDOTcom's Avatar
Originally Posted by EAMotorsports View Post
Two weeks ago people were saying they were announcing it last week. Last week it was this week...now its Jan 1st.
No offense but your not helping anyone by spreading rumors and propaganda on here. Unless you have a press release from ROAR stating the above it does not one any good to speculate and listen to rumors started by other manufactures.
EA
Where there is smoke..there's fire..ROAR pulls the motor...Here's your press release...
http://forums.radiocontrolzone.com/s...d.php?t=268130
visit fastharry.com We are always updating the site with new cars and cool rc stuff.
old user name "fastharry"Posts: 2,845 Original join date 2001..HPI Challenge Winner.
fastharryDOTcom is offline   Reply With Quote
Old 04-02-2013, 11:10 PM   #494
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Can anyone recomend a bearing puller and press for replacing motor bearings. Thought I would ask here since its a Revtech motor I want to replace bearings in. Also what creamic bearings will fit Trinity/Revtech motors. Part #'s would help if you have them! Thanks
Josh-n-ya is offline   Reply With Quote
Old 04-04-2013, 07:54 AM   #495
Josh-n-ya's Avatar
Found everything on Fantom site!
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 16 11-07-2016 04:26 PM
SEO by vBSEO 3.5.0
