Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-06-2012, 02:31 AM   #436
thanks
just saw that there are 2 versions of the revtech, 1055 with high torque rotor and 1052 with broad powerband rotor, what would be best?
will be running on small/med size carpet tracks
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-11-2012, 02:45 PM   #437
how much timing does the 1052 revtech 17.5 motor have out of the box?
Old 10-11-2012, 03:13 PM   #438
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Bappe View Post
thanks
Running a TC on a small/tight carpet track, I would certainly run the HT rotor.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-11-2012, 04:24 PM   #439
Todd Putnam's Avatar
Endbell timing is adjustable. Are you running open timing or fixed (blinky) timing?
Todd Putnam is offline   Reply With Quote
Old 10-12-2012, 02:30 AM   #440
Will run in boosted stock
How much timing does The motor come with as it comes out of The box?
Old 10-20-2012, 12:26 PM   #441
sterling moss's Avatar
Trader Rating: 25 (100%+)
Default 1/12th scale
I run a 1/12 on carpet, 17.5 blinky. The back straight is 65' (basketball court). We generally run a more open/faster layout.
Many guys say they always run the HT 12.5 tuning rotor and a lot of advance.
If this is true, shouldn't I really run less advance for max torque and just gear up till I'm 160F. It seems like a contradiction to crank timing on a torque rotor as some guys have told me they do.
Race Dates 2016-2017
Oct 30 Nov 13, 27 Dec 11, 18 Jan 1, 8, 29
Feb 12, 26 Mar 12, 19 April 2
sterling moss is offline   Reply With Quote
Old 10-21-2012, 09:01 AM   #442
NolanP's Avatar
If you run an open layout why would you want even more torque?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-21-2012, 03:14 PM   #443
John Tag's Avatar
Trader Rating: 41 (100%+)
I would probally start out at 96-98MM(That should be more than safe) roll out with 20* timming. Run the stock rotor you will be fine in 17.5..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 10-23-2012, 09:02 AM   #444
Trader Rating: 17 (100%+)
I just picked up a Revteck 17.5 Maxilla version. Will be running with a brushless hobbies 80A ESC in Blinky/508 mode in my SC10. I have a couple questions:
1. I believe the motor comes with 30* of timing, is that the same with the Maxilla version?
2. How many degress of timing does each timing mark on the can equal? 3*? 8*?
3. Any gearing suggestions? I have a 17.5 with the regular rotor now geared 28/75 with full timing on the can. After 6 min's, comes off at 148*, but I am NOTICEABLY slower than most every other driver. I got that motor used. Once I get this new one installed, I'll be taking it apart to make sure everything inside is good.
Thanks guys!
Snafujg is offline   Reply With Quote
Old 10-29-2012, 09:46 PM   #445
hyperSC82's Avatar
I sent in a revtech battery for warranty a few weeks ago and I still have not heard anything. How long has it taken you guys for warranty from them?
Team Durango DESC410 - Viper VTX10R BE, VST550 4.5
hyperSC82 is offline   Reply With Quote
Old 10-30-2012, 03:21 AM   #446
I waited for almost 2 months,finally owner of the lhs gave me one of his
packs instead. Seems funny to me that they had plenty of packs when i bought it initially,but never had any for warranty. have since gone to another brand with awesome performance and excellent c/s
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 10-30-2012, 08:18 AM   #447
briankstan's Avatar
Would that be the 12.5mm HT Rotor or the 13mm HT Rotor?
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 11-08-2012, 08:35 AM   #448
2xs
x2 - I think I found the answer on page 20...For the 12.3 vs 12.5 rotors. Is the 13mm HT for the 21.5 & 25.5 crawler motors? Either way I ordered a 12.5mm HT and will start there.
2xs is offline   Reply With Quote
Old 11-11-2012, 08:54 PM   #449
omarwashington's Avatar
Looking into getting a rotor. Some info: I have a D3.5 17.5, that I run no boost in TRCR.
I would like to get a HT rotor but need more info.
12.5mm and the 12.3mm and the 13mm rotors, will these work on the D3.5? and why is it that the 12.5 and the 12.3 rotors say D3 on them?
do these numbers mean that the 13mm rotor will have the most torque?
Can someone please explain shimming these rotors?
RCCARS!
omarwashington is offline   Reply With Quote
Old 11-12-2012, 06:14 AM   #450
Jerz616's Avatar
Trader Rating: 49 (100%+)
The d3 and 3.5 use the same rotor. I would stick with the 12.5 HT rotor. I don't believe the 13 is legal in stock classes, but yes it would have more torque.
Shimming the rotor refers to the shims in the front and rear of the rotor shaft. You want just enough shims on the rear to keep the rotor from touching the sensors. Look at the sensor board and you want to see just a little bit of space between the rotor and sensors, prob just a few mm. You will also need to shim the front of the rotor so that when the motor is all together you get just a tad bit of play when you pull on the rotor shaft.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
