Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 06-19-2012, 06:42 PM   #421
NolanP's Avatar
Originally Posted by Magnet Top View Post
I've had very good luck buying rotors and stators from Fantom. Also, EA ( Eric Anderson ) is very reputable but I am no longer sure if he still distributes trinity / Epic / Revtec products.
He does distribute still.
Don't get me wrong hes not warranty but he will sell you a good product/replacement.
See EAMotorsports or shoot him an email @ eanderson76@me
I know he is getting shipments of the D3.5 too.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 06-19-2012, 07:17 PM   #422
PnchoPwr's Avatar
Trader Rating: 18 (100%+)
I'm just looking for advice/assistance on reshimming a rotor in my revtech 17.5. I'm putting in a 12.5 HT rotor, and I just want to make sure I have it shimmed right. Thanks in advance.
Viper R/C Solutions~Pro Line Racing
PnchoPwr is offline   Reply With Quote
Old 06-30-2012, 03:35 AM   #423
idbdoug's Avatar
Trader Rating: 33 (100%+)
Usually 1 or 2 shims
Idbdoug
idbdoug is offline   Reply With Quote
Old 07-20-2012, 01:41 AM   #424
Trader Rating: 43 (100%+)
Just looking for a little advice, can anyone recommend a starting final drive ratio for the Revtech 21.5 in blinky mode, running in an Xray T2? Thanks.
matrix101 is offline   Reply With Quote
Old 07-20-2012, 06:15 AM   #425
locked's Avatar
Depends on the track size. For a small tight track you might find around 4.0 to be good, but for a larger, more flowing track you might want to go down to the low 3s.
Basically the same as 17.5 blinky. Maybe a tooth or 2 difference.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 07-20-2012, 07:03 AM   #426
Thanks, been running a Tekin Redline at around 3.4, just wasn't sure where to start with this motor.
Old 07-21-2012, 10:59 PM   #427
nismomike's Avatar
I may be giving old info, but none the less. I had been running a Reedy Sonic in my SC10 for the last few months and got tired of chasing for more top end without sacrificing low end. So I got a 13.5 RevTech and 12.5 high torque rotor. I'm running a MMP, Spektrum S6040, Futaba 4pl r603gf, and 65c TP 2s. Well I had 1.33 beta firmware already installed. Hooked up the Revtech and it was giving me symptoms like a bad board or sensor wire. Changed wire and nothing helped. Put the stock rotor in, no help. Checked, checked, and triple checked esc on the computer. Re-binded the radio, nothing. It was taking off like I had a ton of punch control in the esc. I would go WOT from a stop and it would take off slow for a few feet, then take off hauling ass. I read about firmware issues with a few different motor/esc combo's. So I loaded 1.32 and now its perfect and very fast. I love it! Stupid beta firmware almost made me crazy today!
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 07-22-2012, 12:06 AM   #428
I have a question and I'm hoping you guys can help. I normally run a 3.8 FDR and full timing in my car and the motor comes off at 150 on the end bell and 135-140 on the can. I wanted to experiment with timing and gearing tonight so I set the timing at one notch above 0 or neutral and tried the 3.8 FDR. Motor came off at 120 on the end bell and 110 on the can. Then I changed to a 3.65 FDR and gave it a run. Same timing. End bell was 200 and the can was 140. Dropped to a 4.0, same timing but now the end bell is 180 and the can is 140. Is this an indicator that I may have damaged the sensor board? How about the rotor? I have heard weak or damaged rotors can heat up even on low timing and high FDR.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 07-25-2012, 10:11 PM   #429
Update
dropped the FDR to 4.1 tonight and gave it a run. Motor got to 175. I tore the motor down and couldn't see any obvious issues. Motor is clean, timing board looks ok. No damage. Bearings are in great shape...like new. I did notice the rotor was out of balance. Tried another stock rotor and the temps still got to 175. Put in a Novak ss and temps dropped all the way to 105. I'm really leaning towards timing board but I was hoping to get more opinions here. The motor is still very strong and is giving me some great lap times. It does go flat around 160 though but I expect that.
Thanks.
Serpent S120 13.5
Old 08-29-2012, 10:29 PM   #430
Trader Rating: 57 (100%+)
Never could find the correct answer for this question so finally figured it out myself. It appears the stock screws are made of leftover crayons or very spoiled cheese.
Whats the full size of the timing plate screws?
Answer - 2.5x6mm
PROMODVETTE is offline   Reply With Quote
Old 08-31-2012, 02:13 PM   #431
NolanP's Avatar
Originally Posted by 6376vette View Post
Update
Thanks.
Try tapping the bottom part of the motor the pinion side on a table to set the bearing back into place. But also your speedo change is interesting. You dropping 70 degrees switching speedo's?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 08-31-2012, 02:22 PM   #432
Magnet Top's Avatar
The Novak SS is a motor , not an ESC ( "speedo" )
Magnet Top is offline   Reply With Quote
Old 08-31-2012, 02:47 PM   #433
NolanP's Avatar
Gotcha sorry not familiar with the Novak line at all. Well just make sure the bearings are straight by tapping the pinion side of the rotor against a table it should align the bearings if they are out of place. Typically though its a sign that a bearing is not spinning properly. Meaning that something is not aligned properly.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 09-05-2012, 03:24 AM   #434
short question, is the 17.5 revtech only for blinky or does it work in boosted too?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 09-05-2012, 05:09 AM   #435
NolanP's Avatar
I have not personally run it boosted. But all motors will work in boosted. When you run boosted just gear accordingly and make sure the temps don't get to hot. Less than 160 degrees on that motor.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
