Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 05-20-2012, 08:36 PM   #406
cwoods34's Avatar
Originally Posted by hcw5733 View Post
I've been running my Touring Car on a 4.0 FDR on my Revtech 17.5 with a 12.5mm HT rotor. Timing is 3 notches to the right from center. Question is, when you guys temp the motor after a run, do you temp the motor can / end bell itself or internally through the cooling vents?
Reason being that I never bothered doing that until today, when after 6 mins the can temp was 155F but the temp inside (through vent holes) was 170F. Is this reason to worry or should I aim for an "internal" temp of 160F?
I literally run the same motor setup but with about a 3.75-3.8 FDR. After a good 6-minute run the outer can temperature is about 160F. Inside is normally up to 180F, and I have never noticed a drop in performance with those temps (with regards to during the run and over a long period of time).
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-26-2012, 08:26 PM   #407
NofriendsTaco's Avatar
Trader Rating: 53 (100%+)
Hi everyone... just got a Revtech 17.5 and wanted to see what you guys have it geared at in an sc10 2wd. ANy FDR numbers or gearing combos would help. Im running this motor in blinky. thanks for the help.
NofriendsTaco is offline   Reply With Quote
Old 05-27-2012, 09:56 PM   #408
Trader Rating: 163 (100%+)
anyone know the bearing size for the revtech/d3 motors?
cjm1126 is offline   Reply With Quote
Old 05-28-2012, 06:46 AM   #409
Should be 1/8 x 3/8 x 5/32.
Serzoni is offline   Reply With Quote
Old 05-31-2012, 03:36 AM   #410
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Here are the Duo/revtech series rotors spec..
12.3- Dark purple = High Torque
12.3- Purple(Stock) = Broad Power
12.3-Light Blue = High RPM
12.5 - Dark Blue = High Torque
12.5 - Gray = Broad power
12.5 - Pink = High Rpm
The Black rotors are all spec rotors and actually have less magnetic feild then the silver rotors(mod) even though the measure out the same size and can fit in either mod or stock stators.. reason being is that the rotors have different size cores meaning the silver is thicker which creates more mag feild in return more torque and less RPM and more batt usesage... Which it is also illegal at most races..
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 06-04-2012, 07:46 PM   #411
Originally Posted by bpalmer View Post
So i went and spent a good piece of change on a new Revtech pack. It is the 65x65. After charging normally i notice the female barrel connectors inside the pack were coming out of the pack and when you try to push them back in you can hear them arcing back and forth. I am afraid to run this 120.00 pack. yet my lhs cant get a response back from trinity .
What to do ?
almost 7 weeks later still waiting on a replacement..... thankful i was able to borrow a pack to race on.
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 06-04-2012, 07:52 PM   #412
Gundevil-81's Avatar
Hopefully my motor won't take that long to replace.
One Lug Racing
Remember a compeditive racer gives you 2 corners before peeling you, but a courtious racer takes the time to help pick up all the pieces to a Tamiya puzzle off the track so racing can resume
Gundevil-81 is offline   Reply With Quote
Old 06-07-2012, 12:37 AM   #413
thebizz's Avatar
Trader Rating: 52 (100%+)
Default Revtech 4Xs quad 540 4 pole 4800kv 5mm shaft
I sent a few emails regarding this motor. no response. I had a bearing fall apart on the sensor board side and I can't get the housing out. the motor failed on my second 5 min.qualifier and the temp was 120. Any help would be great .
thanks
BRENT SMITH
www.mugenseiki.com
www.mugenracing.com
thebizz is offline   Reply With Quote
Old 06-07-2012, 10:46 AM   #414
When I called them about my motor I was informed that they were moving there office that was taking care of any issues, so that may be the hold up with them. I hope they get it all taken care of by the time I get back from Afganistan so I can run my truck again.
One Lug Racing
Old 06-07-2012, 12:22 PM   #415
Johnny Wishbone's Avatar
thanks
This may help you guys with warranty issues.
http://www.trinityrc.net/wp-content/...y-Warranty.pdf
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-07-2012, 05:32 PM   #416
thebizz's Avatar
got it taken care of thanks
BRENT SMITH
www.mugenseiki.com
www.mugenracing.com
Old 06-07-2012, 07:48 PM   #417
XSLR8's Avatar
Hi guys,just wondering if anyone has a good FDR for a revtech 21.5 boosted running Orion esc, for a medium size asphalt track with a t3 12.
What difference would you make if running a 12.5 high torque rotor as well?
Just trying to get my head around all this.
Cheers.
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 06-12-2012, 09:49 AM   #418
This does not match what the Trinity page says:
http://www.trinityrc.net/shop/index....ry&path=72_103
12.3 - Dark blue = High torque
12.3 - Purple = Broad power
12.3 - Blue = High RPM
12.5 - Turquoise = High torque
12.5 - Silver = Broad power
12.5 - Pink = RPM
However, I ordered a turquoise (12.5 high torque, TEP1112) and it measures 12.3mm, exactly the same as the stock purple rotor. So now I'm real confused. Have they got the wrong description on their site, or did I get a mis-labeled rotor?
Steve S is offline   Reply With Quote
Old 06-19-2012, 04:27 PM   #419
So....here i am over 9 weeks later...still no battery, no word,no return to the email i sent last week.....
Old 06-19-2012, 06:35 PM   #420
Magnet Top's Avatar
12.5 - Pink = RPM
I've had very good luck buying rotors and stators from Fantom. Also, EA ( Eric Anderson ) is very reputable but I am no longer sure if he still distributes trinity / Epic / Revtec products.
Magnet Top is offline   Reply With Quote
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
