Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-16-2012, 08:32 PM   #346
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by pchroma24 View Post
For what its worth, ... We were disallowed from running them in blinky/stock classes at the Birds who I understand observe the ROAR rules...
Not sure who told you that. I ran them in every class and had no issues. In Oval you could not run them in the SPEC TOUR Classes as TOUR dissallows them in the those classes.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 02-25-2012, 11:18 PM   #347
rocketron's Avatar
Trader Rating: 16 (100%+)
The lighted parts are not legal per ROAR rules. They are not original equipment and therefore not SPEC. If they are not on the approved motor and tuning parts list that ROAR publishes then it is not legal. This applies to all motor manufactures equally.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 02-26-2012, 12:17 AM   #348
Team EAM
Thanks Ron for clearing it up for ROAR races!
EA
Contact Us
Old 02-28-2012, 05:02 PM   #349
avs
avs's Avatar
EA
hi EA, so i finally got to trying a revtech in 1/12 17.5 blinky. i am used a duo2 and d3 at max timing and 95-100 on rollout.
just dropping in a revtech with max timing and 97, seemed to fade a bit early on, and to bog a little. i re-read everything i could here and didn't get a clear picture on where to go.
compared to duo2 or D3 do i want to try more/less timing and/or more/less rollout?
Tony Shimko
avs is offline   Reply With Quote
Old 02-28-2012, 05:39 PM   #350
Autocratic's Avatar
Trader Rating: 26 (100%+)
What size are the timing plate screws on the Revtech?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-28-2012, 07:15 PM   #351
Redvet79's Avatar
2.5 mm I believe
See You At The Track
Lost Creek R/C Oakland Mills, Pa.
Redvet79 is offline   Reply With Quote
Old 02-28-2012, 07:44 PM   #352
Try backing the timing off to the 2nd to last hash mark... and dropping the rollout to 95mm. If that works better, bump up the timing to the last hash and slowly up the rollout.
Ive found that the stock rotor has a pretty small window (~2mm) for rollout before it starts to get sluggish. But it works great once you find the sweetspot.
JamesL_71 is offline   Reply With Quote
Old 03-01-2012, 05:45 AM   #353
avs
avs's Avatar
ok, thanks for the info.
so in comparison with the D2 or D3, the revtech 17.5 tends to want a little less timing and less rollout.
Tony Shimko
Old 03-01-2012, 07:51 AM   #354
Definitely less rollout. Ive found that the timing sweet spot seems motor dependent. I have run 2 Revtechs in 17.5 12th over the past 3 months. One of them liked a lot of timing... right @ the last hash, but anymore than that and it would start to fade considerable halfway into a run.
The other motor just wasn't happy with anything above the 2nd to last hash. It was just as quick as the other motor, just had a different sweet spot.
Old 03-04-2012, 01:00 AM   #355
anyone know where I can get replacement sensor board for a Trinity D3??
I live in the UK but I am willing to get it from the USA if need be?
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 03-04-2012, 11:00 AM   #356
mojoman81's Avatar
Try here http://www.trinityrc.net/shop/index....ory&path=72_86
G's RC Raceway, Shippensburg, PA
~~~~~ www.gsrc.co ~~~~~~
mojoman81 is offline   Reply With Quote
Old 03-07-2012, 08:00 AM   #357
Default REVTECH 4XS 4-pole motor 4800kv
What would be a capable 1/10 ESC for this bad boy?
http://www.amainhobbies.com/product_...8-Shaft-4800kV
Due to their size, I try not to go the 1/8 ESC route if possible.
niner is offline   Reply With Quote
Old 03-07-2012, 03:24 PM   #358
mojoman81's Avatar
http://www.amainhobbies.com/product_...C-w-SmartSense
Old 03-22-2012, 04:19 PM   #359
evochick's Avatar
What rotor should come in the revtech roar spec motors ??
I picked up a 21.5 today and from what i can tell is the 12.5 high rpm rotor
not exactly a good rotor for blinky touring car. I was under the impression it came with one of the mid strength rotors
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 03-22-2012, 04:35 PM   #360
Johnny Wishbone's Avatar
Beth.
What colour is the rotor ring?
Gary Lanzer
Team VBC HK
Team R1WURKS
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 16 11-07-2016 04:26 PM
SEO by vBSEO 3.5.0
