Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 02-09-2012, 06:12 AM   #301
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Autocratic View Post
What would be a good start gearing and timing for the 17.5 in blinky on the Durango 210? 2.6:1 ratio. The track I run at really requires low end punch in 17.5 so I would be using the 12.5mm HT rotor eventually, however would start on the standard rotor. I have available 69 and 75T spurs, and up to 35T pinions.
Anyone?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-09-2012, 06:21 AM   #302
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Anyone?
I do not race off road so I wont be able to help much other than tell you that the 12.5 high torque rotor (TEP1112) will help a ton with low end punch and power at the upper end of the rpm range as well. Start off with about 2-3 notches of timing past the large notch in the middle and start 1 tooth smaller on the pinion than the motor you were using before (if it was a 17.5). Most motors all will use the same gear within 1-2 teeth for off road.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-09-2012, 08:18 AM   #303
Jerz616's Avatar
Trader Rating: 49 (100%+)
Anyone?
I run 72/35 in my b4.1 with 1 tick shy of full timing on the motor. It has plenty of low end and top end. I can keep up with the 8.5's on the straight and the motor comes off at 135 after 6 min.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-09-2012, 12:02 PM   #304
Autocratic's Avatar
What rotor?
Old 02-09-2012, 03:30 PM   #305
Jerz616's Avatar
What rotor?
The HT rotor.
Ryan Gracey
XRAY XB8'14
Old 02-09-2012, 04:21 PM   #306
Autocratic's Avatar
The HT rotor.
I'm hoping Mikes has some Revtechs left tomorrow or Saturday. He had a ton of 17.5's on the 4th.
Old 02-09-2012, 04:54 PM   #307
Tyler Keel's Avatar
I will be down at Mikes for the Bigfoot, can't wait to run open up my ReVtech's down there. Our local track is tiny.
Tyler Keel - AE Region 9 Regional Director
Team Associated | Reedy | Jconcepts | Werks | Airtronics | Avid | Upgrade RC | Factory 1 RC
Tyler Keel is offline   Reply With Quote
Old 02-09-2012, 05:14 PM   #308
Autocratic's Avatar
Hoping to run in both the Bigfoot and JC race. Not 100% what class though.
Old 02-09-2012, 05:19 PM   #309
Trader Rating: 55 (100%+)
I really need some help with 13.5 wgt blinky. I have tried different rollouts and timing marks. I run on a small, not very technical carpet track. Any help appreciated. Does the bigger rotor help(12.5mm)
Jamison R is offline   Reply With Quote
Old 02-09-2012, 05:29 PM   #310
Jerz616's Avatar
I put the HT rotor in my D3 and didn't like it. Felt too tight. The brakes came on way too strong even with them turned almost completely off. I think it works best in the 17.5's.
Ryan Gracey
XRAY XB8'14
Old 02-09-2012, 05:30 PM   #311
Jerz616's Avatar
They had a bunch on Monday.
Ryan Gracey
XRAY XB8'14
Old 02-09-2012, 05:32 PM   #312
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
where do we get bearings to rebuild the revtech motor? what size are they?
many thanks!!
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 02-09-2012, 05:34 PM   #313
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
ok have a question.. in 17.5 blinky sedan/rubber tire class is the 12.3 or 12.5 rotor better? what will the gearing difference be? 1-2-3-4 teeth? here is the track i run on.. jeremy
http://www.youtube.com/watch?v=v5NkzZRB9Kk
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 02-09-2012, 06:06 PM   #314
haywood's Avatar
Trader Rating: 48 (100%+)
I have had good luck with my motor setup all season! I am running the purple ring rotor with the open end bell and ceramic bearings. I am running 4 clicks of timing and 4.0 fdr. I haven't tried the grey rotor at all. I am also running a 40mm x 40mm fan.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-09-2012, 06:15 PM   #315
I just picked up a fresh rotor for one of my Revtechs... and the colored ring is pretty crooked on the magnet. There is a dollop of the balancing epoxy on the ring, so Im guessing it was actually balanced.
Without spinning the thing up it is hard to know whether or not it is truly balanced, though.
Has anyone received a rotor like this before?
JamesL_71 is offline   Reply With Quote
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
