Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 01-22-2012, 12:05 PM   #271
HighLife420's Avatar
Trader Rating: 49 (100%+)
Send a message via ICQ to HighLife420 Send a message via AIM to HighLife420 Send a message via MSN to HighLife420 Send a message via Yahoo to HighLife420 Send a message via Skype™ to HighLife420
Originally Posted by Resqnu View Post
Thanks. How does it compare to other brands?
best of the bunch...ive used Tekin, Novak, Orion..the revtech trumps them all. Close 2nd would be the tekin. I had to gear up slightly coming from those though, went down 1-2 pinon teeth and up 3 spur teeth.
Dominic "Dom" Chin
TLR 22 (Tekin RS Pro, LRP X12 7.5t, Savox 1258TG)
MIP Pro4mance SCTE (Tekin RX8, Tekin Pro4 4600kv, JR Z9100s)
Ko Propo Eurus (EX10) Limited Edition
HighLife420 is offline   Reply With Quote
Old 01-22-2012, 12:51 PM   #272
Resqnu's Avatar
Trader Rating: 37 (100%+)
Sounds very good. Any idea what to gear at for a Blitz ESE? My current spur is an 83t?
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 01-22-2012, 02:49 PM   #273
Anyone notice their solder tabs wiggle a tad?
I would try to get around a 7.5-8 FDR depending on what is allowed in the class. We can run as much boost as you can handle. If you running blinky stock I would go gear down. Most I know run around 27/75 in blinky stock.
Dominic "Dom" Chin
Old 01-24-2012, 11:58 AM   #274
Trader Rating: 51 (100%+)
Default brushed and brushless 540 motor equivalents!
27t, 19t, 13t, 11t & 8t brushed motors are equal to what brushless motors? Sincerely, Joe
sweetbabyj is offline   Reply With Quote
Old 01-24-2012, 12:02 PM   #275
Mine did that too, i just took some CA and glued them so they don't move.
avink007 is offline   Reply With Quote
Old 01-24-2012, 01:01 PM   #276
Johnny Wishbone's Avatar
Jim Dieter recommended using pliers and bending the tab over a little to tighten the tabs up a bit.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-24-2012, 03:57 PM   #277
Ya, thats what i ended up doing...just a dab.
You mean curl the end over the back side? I never thought of that, pretty good idea actually.
Is there anything wrong with them wiggling a bit? should i open it up and resolder it?
Dominic "Dom" Chin
Old 01-25-2012, 07:51 AM   #278
Resqnu's Avatar
I would try to get around a 7.5-8 FDR depending on what is allowed in the class. We can run as much boost as you can handle. If you running blinky stock I would go gear down. Most I know run around 27/75 in blinky stock.[/QUOTE]
Thanks, I run in stock class were timing is allowed. My sct is a Blitz ESE and spurs are 77t,83t, 88t. My track is indoor clay track, wet/damp, technical with a 80ft straight and lots of turns and jumps (some doubles and triples). I would like starting point setups for blinky with timing and a boosted setup.
Old 01-26-2012, 10:52 AM   #279
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
What is the highest charging amp that a RevTech 65C/6500mah battery can be charged safely???
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 01-26-2012, 05:19 PM   #280
Resqnu's Avatar
Thanks, I run in stock class were timing is allowed. My sct is a Blitz ESE and spurs are 77t,83t, 88t. My track is indoor clay track, wet/damp, technical with a 80ft straight and lots of turns and jumps (some doubles and triples). I would like starting point setups for blinky with timing and a boosted setup.[/QUOTE]
Anybody? Need help with Revtech 17.5 and Tekin rs in Blitz running in class with timing. What's the best settings for technical course with lots of jumps requiring bottom end power?
Old 01-26-2012, 09:54 PM   #281
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
6C is no problem. I charge at 20 amps and have had no battery issues.
Anybody? Need help with Revtech 17.5 and Tekin rs in Blitz running in class with timing. What's the best settings for technical course with lots of jumps requiring bottom end power?[/QUOTE]
I'll have to get billy to answer this as I dont run SCT but I know he does.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-27-2012, 08:01 AM   #282
Resqnu's Avatar
EA[/QUOTE]
Thanks, I just a starting point, especially with gearing
Old 01-28-2012, 10:06 PM   #283
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Default Revtech 17.5 1s with 12.3 high rpm rotor
Would like to get a starting reference point for a Revtech 17.5 (blinky) 1s pancar with a 12.3 high rpm rotor. What is an ideal rollout to start with? Track is 80'x40' in size. Not sure what rollout and timing I should use as a base for testing.
tr1kstanc3 is offline   Reply With Quote
Old 01-29-2012, 02:56 PM   #284
Had a pretty good day racing today with my revtechs.
2wd SCT took 3rd in the Amain. Setup was 26/75, running 2 notches on the can, 50 on esc (5k-15k), 12 turbo and 2 ramps (4 every 1/10th of a second). Pulled off after a qual at 150. The amain i pulled off after 8mins and was 157.
2wd Buggy i had a rough start. On my first practice lap, i came down on the track tubing and hit a giant nail. Broke my shock shaft. I ended up missing the first qual. Took 4th in the 2 qual, was 4th in the Amain and ended up 5th. My buggy was SCREAMING down the straight. Its setup 26/75, 1 notch minus from max on can, max boost (5k-20k) 12 turbo, 2 ramps. Pulled off after my qual and was 142, after my 8min main, was at 151.
How hot can i safely go? I would love to gear down slightly for the huge straight i have.
Dominic "Dom" Chin
Old 01-30-2012, 01:11 PM   #285
Resqnu's Avatar
Default Happy with new Revtech 17.5
Just put a new Revtech 17.5 in my Blitz ESE. Wow! This motor rocks.
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
belewis01
