Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree7Likes
Old 01-17-2012, 08:29 AM   #256
discgolferlee's Avatar
Trader Rating: 42 (100%+)
just picked up a fantom apex version 17.5 motor from a guy on here. excited to see how it performs compared to the viper 17.5 I have been running. I am running 2wd stock buggy. Mid motor team c tc02c buggy on carpet track. was running the viper geared at 30/80. Any idea on recomended starting point for gearing and timing with this motor. thanks and look forward to trying out this product. been happy with the viper but wanted to try something different.
discgolferlee is offline   Reply With Quote
Old 01-17-2012, 01:42 PM   #257
Redvet79's Avatar
Default 21.5
Originally Posted by Redvet79 View Post
is the revtech 21.5 compatible with a novak esc such as the brush-less GTB. Tower hobbies has compatible with all esc's except novak. I want the motor but don't to buy a new esc.
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXBMBJ
There are a number of problems with this "Tech Talk".
In order to be a ROAR spec motor, it must be sensored, not sensorless.
REQUIRES: Sensorless ESC
COMMENTS: This sensorless design motor works with most racing speed controls
except Novak.
Since this motor is sensored, and approved by ROAR for spec racing, there is no reason that Novak's (sensored-only) escs should not work.
Ordered one will let you know.
Thanks For Your help
See You At The Track
Lost Creek R/C Oakland Mills, Pa.
Redvet79 is offline   Reply With Quote
Old 01-18-2012, 09:43 PM   #258
jordy-15's Avatar
Trader Rating: 17 (100%+)
can any one tell me if the apex rotor will the d3/revtech motors are they they the same or different?
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is offline   Reply With Quote
Old 01-18-2012, 10:29 PM   #259
Jerz616's Avatar
Trader Rating: 49 (100%+)
Mine can be a little hard to turn at times also, butbit doesn't give meca problem.
As far as timing. I run my 17.5 in blinky buggy in my b4.1. I have my endbell timing almost maxed out. About 2 clicks away from max. I run 72/35 for a FDR of 5.3. I come off the track about 130-145 deg.
[QUOTE=AnthonyN;10184018]
Originally Posted by Jerz616 View Post
That center piece was not the problem with mine.
The slot in the stationary portion of the end bell was binding against the sensor connector so it would not slide in either direction. I had to take the whole end bell off and sand the crap out of the slide area. Now the sensor connector doesn't bind with the end bell.
However, after assembling the motor, I found if I tighten the motors main screws too tight (not the timing screws), then I can't easily change the timing. I had to back off a little on how tight the main screws are and even then, the timing is difficult to change. I have to use a allen driver in one of the timing screws to rotate it.
Is it supposed to be that way?
I think I got a lemon as far as being able to change the timing. Something doesn't fit just right.
On a positive note, the motor still ran after I put it together.
Now I need to find out what timing to use for the motor and ESC.
I was using 0 timing on the motor and I think I'm around 50% timing in the ESC (I have to check that). All I know is I had to go to 5.0 FDR just to keep up with everyone going down the straigt away. Temps never got over 120F.
Any suggestions?
Thanks for everyone's help
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 01-19-2012, 04:00 AM   #260
[QUOTE=Jerz616;10194308]Mine can be a little hard to turn at times also, butbit doesn't give meca problem.
So, is it safe to keep the boost at 55%, and then start adding timing on the motor until the temp gets too high. Or, should I start all over with gearing. It's pretty close now, I could just go up two more teeth. Which is better for overall acceleration and top end.
AnthonyN is offline   Reply With Quote
Old 01-19-2012, 08:47 AM   #261
Yes, the Fantom motors are just D3/ReVtech motors with a different sticker. All of the parts are interchangeable.
Serzoni is offline   Reply With Quote
Old 01-19-2012, 11:36 AM   #262
Jerz616's Avatar
[QUOTE=AnthonyN;10194868]
I would start with no boost on your ESC and use the motor timing and gearing to get as close as you can. My revtech didn't like boost from the speedo, got too hot too quick. If you can't get what you want with the motor timing and gearing then just add a small amount of boost at a time..
Just my .02$. though
Ryan Gracey
XRAY XB8'14
Old 01-19-2012, 02:31 PM   #263
Todd Putnam's Avatar
Default REVTECH 6200/70C 'HV' 1 Cells
The new REVTECH 6200/70C 'HV' 1 Cells have arrived just in time for the Snowbirds! These are Super High Voltage Chemistry specifically for Spec racing. Legal for On-Road @ The Birds. HUGE Voltage and Low Internal Resistance...
FOR THE OVAL GUYS GOING TO THE BIRDS: I suggest you grab some of the newest shipment of the 6350/65C 1 cells - These are cycling awesome. We tested some of the latest batch at the CRC New Years Dash last week and they TQ'd 2 classes.
Order while limited supplies last...
www.rcspeedshop.com
Todd Putnam is offline   Reply With Quote
Old 01-19-2012, 10:23 PM   #264
HighLife420's Avatar
Send a message via ICQ to HighLife420 Send a message via AIM to HighLife420 Send a message via MSN to HighLife420 Send a message via Yahoo to HighLife420 Send a message via Skype™ to HighLife420
anyone using 17.5 in 2wd short course? Trying to get some more gearing ideas. Can run as much boost as i can handle, esc and end bell. Thinking of starting around 27/78, however, since the revtech is higher kv than my last few motors, thinking if i should go higher FDR.
Just curious, how much TOTAL timing (ESC and Endbell) can it handle? If anyone has pushed it.
BTW, its a awesome mix of color too (GOOO GATORS!!!)
Dominic "Dom" Chin
TLR 22 (Tekin RS Pro, LRP X12 7.5t, Savox 1258TG)
MIP Pro4mance SCTE (Tekin RX8, Tekin Pro4 4600kv, JR Z9100s)
Ko Propo Eurus (EX10) Limited Edition
HighLife420 is offline   Reply With Quote
Old 01-20-2012, 02:47 PM   #265
Trader Rating: 55 (100%+)
Having a hard time finding a good roll out and timing mark for rev tech 17.5 1/12 blinky class. Any help greatly appreciated
Jamison R is offline   Reply With Quote
Old 01-20-2012, 06:59 PM   #266
With the stock rotor, start at about 3.50 rollout @ 3 tabs of timing, and 3.80 rollout at 2 tabs.
Old 01-20-2012, 07:00 PM   #267
Many of my customers are using them, but gearing depends on layout, and how hooked up the vehicle/surface is. Start conservative, monitor temp, and trial and error from there.
Old 01-22-2012, 11:33 AM   #268
Resqnu's Avatar
Trader Rating: 37 (100%+)
Default Revtech 17.5 for 2wd sct
Does anyone have experience running the 17.5 in 2wd sct? I would like to hear some input on this motor. Also what does the 12.5 high torque rotor do and is it needed? I run a Tekin rs esc.
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 01-22-2012, 11:39 AM   #269
Ive just dropped this in my SC10, right now running 27/78, 3+ notches on the can, full boost on ESC with small amount of turbo (12, 2 ramps).
Good motor, lots of power, lots of top end. Doesnt seem to get very hot. Ive got it to 150 with my current setup after 10mins.
Thinking of trying 27/75. My truck has lots of rip, but need that little bit for the long straight i have.
Dominic "Dom" Chin
Old 01-22-2012, 11:52 AM   #270
Resqnu's Avatar
Thanks. How does it compare to other brands?
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 17 02-21-2017 04:51 PM
