Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-04-2011, 07:19 PM   #181
sandsurfer's Avatar
Trader Rating: 20 (100%+)
Send a message via Skype™ to sandsurfer
seaball - Thanks for the response. I just want to fully understand. So, as I look at the end of the motor the "+" is at the right, so, if I rotate the "0" clockwise,as you said, it would move away from the "+", which I would think that would mean less timing, not more. Also, there are 9 lines on the can which you said each one = 5* which would be 45 total + the sensor board set timing of 30 which would make a total of 75* not 58*.
I'm not trying to ba a smart a**, just soooo confused.
The whole reason I am trying to find out is because i'm having issues of losing speed after about 2 min of runtime ( meaning I am probably slower than a VTA car). I think with the timing I have in my tekin and the can timing I may have too much. Sometimes it will run a full 6 minutes with no issues and temps in the 135 range. When it loses speed, temps are not even 100 deg.
Thanks, Gary
sandsurfer is offline   Reply With Quote
Old 10-04-2011, 08:09 PM   #182
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
your thinking is right, but the center of the nine lines is 0, i believe. therefore, it's the 30* (board) +/- 20* (marked), and i'd estimate that the end bell over rotates the scale by another ~8* or so each way.
all said, your issues sound strange to me, but yeah, guys who run that esc (or timing boost in general) tend to crank most of the timing out of the motor. start there and check back in.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-05-2011, 05:07 AM   #183
sandsurfer's Avatar
Thanks again. Light bulb went on in my head right when I woke up, before I even read your last post. Then looked at motor and saw that the line at about 9 oclock is the negative mark. duh. Thanks for the info and patience, I will let you know what happens when I back the timing out.
Gary
Old 10-15-2011, 06:45 PM   #184
ChadRacing's Avatar
Whats the best timming to run on the ReVtech 17.5 motor?
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 10-15-2011, 09:34 PM   #185
bkspeedo's Avatar
I believe most people at IIC running TC Stock (blinky) where running the timing at positive tick 3 (second to last before the +) and a FDR around 3.8/3.7. There were 4 revtech motors in the a-main.
checkout http://rcprogear.com/
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-16-2011, 07:42 PM   #186
kinga's Avatar
Trader Rating: 15 (100%+)
I was running the revtech 17.5 on the weekend and was playing with the timing, I found at the point where it over-rotates past the last timing notch, then hits the"+" symbol the motor rpm goes up markedly. I ran it like this for one run, with FDR of 4, the motor temp was about degrees 80c or 175f. Is that too hot for this motor? THe RPM boost was audibly much higher in the range between the last notch and the "+" symbol.
All in all was impressed and had a lot of torque and top end was as good as the speed passion v3 MMM
I was running with a slightly lower FDR, 3.8, and timing set 3 notches off the top notch and it was running just as hot.
kinga is offline   Reply With Quote
Old 10-18-2011, 03:52 AM   #187
Anybody know who has the Revtech 17.5T motors in stock?
I need two urgently.
Jongo is offline   Reply With Quote
Old 10-18-2011, 08:13 AM   #188
mojoman81's Avatar
Trader Rating: 26 (100%+)
I ordered 1 from fantom and they sent me an email that they would have them back in stock this week . So since they use revtechs trinity should have them in 1st .
G's RC Raceway, Shippensburg, PA
~~~~~ www.gsrc.co ~~~~~~
mojoman81 is offline   Reply With Quote
Old 10-25-2011, 12:30 AM   #189
Chris Adams's Avatar
EA, pm sent!
TEXASEOS.net, SpeedzoneUSA, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2016
Chris Adams is offline   Reply With Quote
Old 10-26-2011, 09:28 AM   #190
VegasHB's Avatar
WOW, they got some 17.5's back in stock at teamtrinity.com. Ordered 9pm pst and got a tracking number USPS priority before I even woke up the next morning. Awesome!!
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 11-11-2011, 09:20 AM   #191
Kenny L's Avatar
Trader Rating: 16 (100%+)
Who is going to Champs?
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 11-11-2011, 09:45 AM   #192
locked's Avatar
I was planning on going, but now I can't make it. Oh well, it's probably best if I spend more than a couple of weeks with my new chassis before going to a big race anyway.
Best of luck Kenny and any other team guys attending.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-12-2011, 07:19 PM   #193
I am, wouldn't miss it! (14th year in a row)
John Warner is offline   Reply With Quote
Old 11-15-2011, 01:22 AM   #194
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Mr Blackstock,
question for you as you r sponsored by lrp are and in some classes like boosted ones u ran tekin like other major driver have u heard anything thing?
reason why i am asking im trying to find some help for a setup for a ssxssv2 for a short track like a50 by 25 in 17.5 boosted?
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 11-24-2011, 11:35 PM   #195
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Hey guys, a couple of Q's...
When you guys say FDR of 3.8, meaning Spur/Pinion = 3.8? Internal ratio is not considered?? Or is it Spur/Pinion x Interal Ratio = 3.8?
I am going to be running a 17.5 with a Tekin RS Boosted. Is 3.8 a good starting point for it?
What temps should I be looking at the 4 min mark??
Thanks.
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Official ReVtech Racing Produts Thread. EAMotorsports Electric On-Road 16 11-07-2016 04:26 PM
SEO by vBSEO 3.5.0
