Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-11-2011, 07:22 PM   #31
hanulec's Avatar
Trader Rating: 27 (100%+)
Quick update for everyone -- I'm going to be out of town for two weeks but shipping will continue to go on.
Also -- there is a new product in the works -- a metal replacement to the TOP Photon steering bellcrank -- you know, the remaining piece that we all break. If the product is cost effective it will be made. Hopefully I'll have an update on this potential new part over the next two weeks...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-16-2011, 07:21 PM   #32
hanulec's Avatar
Side Piece Racing Mira Outdrives within a Yokomo BD-5 w/ 50mm ECS
Originally Posted by ddd2k View Post
I had the same problem before so I end up using xray C-hub and steering block which I also converted to xray ECS to eliminate the chatter. The car width is the same.
here's some pics
Originally Posted by kschu View Post
ur outer arm pin still remain the same ?
Originally Posted by pcar951 View Post
+1 ?? did you drill the arms or sleeve the pins? Looks great!
I drilled it to have a better play...I think the yokomo pins are 2mm only, also the xray ECS uses C plastic blades for the outdrives, I run mod with the yokomo so the steel outdrives doesn't last long. The spool is by TOP and the outdrives is by someone that makes it here in the US which I found it on this forum also. This car has a lot of corner speed and I like so much than my Xray T3 2011 in terms of handling.
Originally Posted by masterhit View Post
Awesome info, thank you very much for putting that up. Does it matter which length of X-Ray ECS's are used?
Thanks!
Mike Slaughter
Both 52 and 50mm will fit but I can feel when the car bottoms down the 52 seems has some resistance on corners...the 50mm is the perfect fit.
Old 03-16-2011, 07:27 PM   #33
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default ohh yearrrhhh
love it...
I'm getting a set of these for my TC6...finally a solution that works...
Made in USA. big plus for me.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 04-04-2011, 07:37 PM   #34
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I have used side piece outdrives since day one which was sometime in January and have blown 2 blades total racing weekly indoors. I used to ruin multiple blades every race day with small wall taps.
Now I run Xray Ecs's and the Sidepiece outdrives and never worry about blades anymore.
No blade failures this weekend at the East Coast Race of Champs at horsham where I tqed and won Super Stock touring and Mike Haynes finished 2nd both of us with Sidepiece outdrives. He runs them in his TCX with a rear yokomo geardiff.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-15-2011, 08:49 PM   #35
hanulec's Avatar
Side Piece Racing is rolling 5 dudes deep at The C-Squared race tomorrow at The Coliseum
The Coliseum at HobbyTown USA
As a side note -- I'm still looking into how to make an aluminum replacement to the remaining part of the TOP steering bellcrank. The challenge is finding a way to make the sawtooth inexpensively.
Mira Outdrives supplies are getting low -- but there is a new batch coming on the way!
Old 04-17-2011, 02:19 PM   #36
hanulec's Avatar
We had a great time yesterday at The Coliseum's C-Squared race. Side Piece Racing equipped cars took the TQ & Win in both 17.5 and 13.5 Touring Car classes with Larry Fairtrace in 13.5 with his TOP Photon and Mike Haynes in 17.5 with his HB TCX. It was great to see all of the TOP Photon runners at The C's running Mira outdrives too.
Old 04-17-2011, 02:21 PM   #37
hanulec's Avatar
Quick reminder to everyone -- PLEASE only use the XRay 305241 Drive Shaft Replacement Plastic Cap 3.5mm blades within your XRay ECS Drive Shafts. The Mira Outdrives were designed entirely around this size of blade. The smaller (incorrect) 3.0mm XRay blades will wobble excessively within the outdrive and break every run!
Old 04-26-2011, 09:25 PM   #38
hanulec's Avatar
I just received my second manufacturing run of the Mira Outdrives ... and they look as good as the first.
I haven't posted an update on the TOP Photon steering bellcrank part as I've still been looking at a way to make it inexpensively... but I haven't given up on it (yet)
I believe I'll be creating an Outdrive that fits the XRay spool... now all I need is a final 3d drawing and a new product name
Old 04-29-2011, 02:09 PM   #39
R Dodge's Avatar
When can you send some to MD?
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy★
R Dodge is offline   Reply With Quote
Old 04-29-2011, 04:07 PM   #40
hanulec's Avatar
we need some drawings first... everyone will see them first here. its been a crazy week...
once the drawing is done-done and the order is in it will take roughly 5 weeks to get the newly manufactured product back. lets see how next week goes...
Old 05-02-2011, 04:42 AM   #41
hanulec's Avatar
Side Piece Racing had a good weekend at Jackson. There were drivers in contention for the win in 17.5, 13.5 and Modified. In 17.5T there was Ron Goetter in 2nd & Jerry Perez having a little first few lap drama finishing a strong 5th:
+ YouTube Video
In 13.5T I took down the win, and Steve Walter taking 6th:
+ YouTube Video
In Modified Larry Fairtrace and Mike Haynes had a great battle going until Larry had an issue (not with a Side Piece Racing product, of course). I on the other hand was just trying to not visit my friendly neighborhood wall at the end of the back straight:
+ YouTube Video
Old 05-11-2011, 05:35 PM   #42
hanulec's Avatar
Quick note to everyone with Mira outdrives -- it is important to make sure that your outdrives are tight on your spool. loose outdrives cause the plastic spool to wear out faster than usual...
Old 05-11-2011, 06:36 PM   #43
KHoff7's Avatar
Fj, any plans at all for a Tamiya spool to Xray driveshaft cups?
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 05-11-2011, 06:52 PM   #44
hanulec's Avatar
Hi Karl -- unfortunately i don't have any plans for that. I'm still working on the XRay versions. Unfortunately, when I looked at the Tamiya spool, they make it very hard to implement something like this as the bearing is used to hold the cup onto the spool... and that makes for a very thin spool cup. If you have any other ideas I'm open to hear them.
Old 05-28-2011, 11:54 AM   #45
ByteStream's Avatar
Any news on the Xray version of the outdrives?
Looking to pick some up that would fit 50mm ECS.
ByteStream is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Horsham RC Carpet Racing 2010-11 Al Sodano Racing Forum 2116 09-26-2011 04:28 AM
Team Poor Boy Racing Poor Boy Racing Racing Forum 941 01-11-2011 04:45 PM
Lawrence Oval Racing plipitkc Kansas/Missouri Racing 628 02-28-2010 08:04 PM
