Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-28-2012, 09:13 AM   #286
Super Moderator
Slo_E4's Avatar
Trader Rating: 58 (100%+)
Originally Posted by hanulec View Post
The Nikita outdrives are longer than XRay stock so that shims are not required.
Yea I know that... The reason I ask is I have about 5 packs in on them, and one is bent already. I thought I read in a thread that a shim will help this not happen with 50's...
Slo_E4 is offline   Reply With Quote
Old 04-28-2012, 06:32 PM   #287
hanulec's Avatar
Trader Rating: 25 (100%+)
the mentioning of a shim is for the Mira outdrives used in TOP Photons.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-29-2012, 08:12 AM   #288
hanulec's Avatar
Two Seis Fans worked really well yesterday when running 13.5t blinky touring car in my new Photon EX. One fan mounted behind the motor, and another blowing on the Tekin posts (and the motor)
Old 04-30-2012, 08:34 PM   #289
hanulec's Avatar
I found one last set of Nikita outdrives -- and updated my inventory accordingly. I'm still in conversations with my machine shop about when the version 3 Nikita's will be produced. Hopefully they will be available this month (May).
Old 05-01-2012, 09:08 AM   #290
Trader Rating: 54 (100%+)
Whats the difference in the updated version? I just ordered a set.
Jamison R is offline   Reply With Quote
Old 05-01-2012, 09:44 AM   #291
hanulec's Avatar
Yes.. you nearly ordered the last set until I found one more while putting your order together.
The v3 design won't support 52mm shafts (by design.. it could work depending upon your arm spacing). The other change I'm keeping a secret until mine our out so no one steals the design...
I heard from the machine shop today. I hope to receive the new hotness by end of week.
Old 05-01-2012, 10:56 AM   #292
Super Moderator
Slo_E4's Avatar
I just grabbed that last set.
Old 05-01-2012, 08:19 PM   #293
hanulec's Avatar
Thanks for your order. Just packed it up... will be out the door in the morning. Hope you'll like what you see.
Mira Outdrives for the TOP Photon (or other 40T pulley touring cars) continue to trickle out the door. The biggest mover continues to be Seis Fans and Nikita Outdrives (when in stock..)
Old 05-04-2012, 10:51 AM   #294
Super Moderator
Slo_E4's Avatar
Just wanted to say thank you very much for the replacement. I actually cracked it trying to fix. .... Ready to check out the v3!
Old 05-06-2012, 04:35 PM   #295
hanulec's Avatar
Happy Seis de Mayo everyone!
While there wasn't a lot of drinking yesterday many of us where hung over today from practicing after weekly club racing in preparation for the Reedy race. My 13.5t tc is a missile..and a cool missile due to my Seis fans.
No update from the machine shop.. hopefully I'll hear something soon.
Old 05-07-2012, 09:56 PM   #296
TryHard's Avatar
Were the Seis wired up direct to the the ESC? or off a receiver pack? I note on the site it says 7.4v isn't supported... it's just I'd be plugging it in direct to the V3 ESC output plug, so batt voltage into the fan.
Old 05-08-2012, 03:22 AM   #297
hanulec's Avatar
Hi Ed.. my Seis fans where wired into the receiver. Two fans into one set of Terry plugs. I used to not believe in running motor fans at receiver voltage but these fans spin very well at 6v. Unfortunately these Seis fans are the best alternative I can find to everyone's beloved Geisha fans which will no longer be produced by the manufacture (trust me... I tried for 7-8 months).
I hope you give them a shot. They would look good in your awesomatix.
Mike
Old 05-08-2012, 07:35 PM   #298
TryHard's Avatar
Mike
Cheers Mike, I'll put an order in soon, once I've sorted out moving job/house/country again for the second time in two years...
Regards
Ed
Old 05-11-2012, 06:31 PM   #299
hanulec's Avatar
Still no good news from the machine shop around the Nikita V3 manufacturing run. I'm trying to see what is possible to get before the Reedy Race. I'm making my maiden voyage to the Reedy this Memorial Day weekend.
If anyone doubts how good my Seis Fans are -- please stop by at the Reedy. I suspect you'll find them in many of the touring cars out there -- form Invite to 17.5t blinky.
Old 05-11-2012, 06:41 PM   #300
Magnet Top's Avatar
Hi Mike,
I still have a Geisha that only failed because one of the wire leads pulled off the circuit board. Is it futile to try to solder another lead onto it ? Has anyone been successful doing that ?
It appears that the case is spit in two pieces and bonded together ? Can it be split and re bonded with CA ?
Or, can one safely drill the back of the bearing assembly to gain access to the solder lead ?
Anyway, will be good to see you at the Reedy. I met you at IIC long ago, will be fun to mix it up in 17.5... I'll be one of Pesky A700's looking to make mother Russia proud !
Jake D.
Magnet Top is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Horsham RC Carpet Racing 2010-11 Al Sodano Racing Forum 2116 09-26-2011 04:28 AM
Team Poor Boy Racing Poor Boy Racing Racing Forum 941 01-11-2011 04:45 PM
Lawrence Oval Racing plipitkc Kansas/Missouri Racing 628 02-28-2010 08:04 PM
