Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 01-10-2005, 07:51 AM   #1081
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Eric, have you begun your moving, if so, where are you moving to?
And just out of curiosity, when will you do motor rebuilds (as in while you are moving, or after you get there) if you have a ballpark date that would be great.
tc3stocker is offline   Reply With Quote
Old 01-10-2005, 07:55 AM   #1082
AlanLim's Avatar
wow!!!
3 drivers in the A Main STOCK at Novak!!!!
Congratulations!!!
AlanLim is offline   Reply With Quote
Old 01-10-2005, 08:01 AM   #1083
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Hey Guys,
Yes, EA Motorsports had a very good weekend. Furman qualified 10th and ended up 8th. I qualified 2nd and ended up 3rd. Eli qualified 5th and ended up 10th a I believe. Everyone had mad rip all weekend. EA ended up in the B after some rough luck in a very good qualifying run. He was right on pace behind me but tapped a wall and broke. Look for us to be in full force at the 2005 Snowbird Nationals.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-10-2005, 09:44 AM   #1084
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
oh yeah,
ea racers had serious rip all weekend. especially the man himself. great run in the main, eric. i watched as you poked around lap after lap at buran's blocker lines. your patience in the main was to be admired. you and your car, were scary. too bad you didn't get a clean one on in qualifying.
this whole oval racer turned road coarse guy is bogus. now we're all gonna have to figure this motor thing out just to keep up.
nice work eric and all the ea drivers this weekend.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-10-2005, 10:25 AM   #1085
wannabee's Avatar
Originally posted by seaball
oh yeah,
GOOD JOB C-BALL!!
wannabee is offline   Reply With Quote
Old 01-10-2005, 09:56 PM   #1086
Trader Rating: 16 (100%+)
Default F-Brush
Eric,
I usually don't do things like this but this time I must...
Those F-Brushes are AWESOME! WOW! Incredible RIP! They work in Stock TC, Stock 1/12, and in the Reedy Q-Mag 19T. I am very impressed! Thanks again....
You don't think we could keep this a little secret....do you? LOL
Art D.
Advil is offline   Reply With Quote
Old 01-10-2005, 11:54 PM   #1087
Default F-Brush
I ordered a bunch of F-brushes a few weeks back (Must say the order process is excellent ) and decided to try them last weekend.
I used a Fantom 19x1 Hand-Wound arm (not a spec. arm) with the new F-brush instead of my trusty Reedy 767s.
After running in the motor for 10 mins and letting it cool down I was down 10 Watts (5%) on my Dyno (Robitronic), also the motor felt "flat" on the track. Changed back to 767s and the motor was good once more.
Am I missing something or doing something wrong?
vassago is offline   Reply With Quote
Old 01-11-2005, 12:07 AM   #1088
Default F-Brush
I put them in a fresh motor. Broke in at 3 volts for 300 seconds. Checked wear pattern. Run for another 150 seconds. Brushes were fully broken in. Skimmed comm. Reseat brushes for 15 seconds. Put in car and let it rip.
It was awesome on the track.
Spring tension set at 7.0 pos/6.5 neg on a fiddle stick.
Old 01-11-2005, 12:11 AM   #1089
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Default Re: F-Brush
Art,
Thanks for the motor help this weekend. I couldn't believe how much faster my 12th scale car was. Mad rip, tons of straightaway, and it lasted the whole run without falling off. The F-brushes are definately the best ones i've used.
-James
JamesArluck is offline   Reply With Quote
Old 01-11-2005, 05:28 AM   #1090
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
vassago
It could be the springs were to hard for the F-lines,cause they carry a bit more silver then the trusty 767`s
This is a stab in the dark for me cos we don`t have hand wound 19 over here
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-11-2005, 05:50 AM   #1091
Well, spring tension the same as Advil uses (6.5/7 FS) but I'll give it another go. I still have 9 pairs laying around so I'll have to use them
Old 01-11-2005, 06:15 AM   #1092
MR JOLLY's Avatar
vassago
when i had the monsters before the new F line came out, he was using 767`s, so when the new brushe came out it was`nt as simple as change brushe cos we found the 767 spring setup was red/purple & that was to hard for the F-line, we changed to std grn/red combo(monster motor) & they were fine ;;lovely actually!!
When i tries runing the red/purple combo the F-line brushes did`nt perform as i expected, average speed & they faded as the run went on
But on grn/red combo;; speedy,speedy
Hope this helps in your quest for the perfect setup in a motor
Old 01-11-2005, 06:18 AM   #1093
I'll give it a shot tonight and I hope to come back with another success story
Thanks.
Old 01-11-2005, 06:46 AM   #1094
Hi Vassago,
You might also want to consider shortening your break in time, the F-brush is fairly soft and should easily be fully broken in by the 300 second mark. I've been breaking mine in at 2 volts for 300 seconds and they seem to be fine, any more than that and you may just be wearing the serrations out. If you have any more questions let us know!!!
Brandt
Ozwald Bates is offline   Reply With Quote
Old 01-11-2005, 06:54 AM   #1095
MR JOLLY's Avatar
ozwald
you might want to change that `it`s in the can` to
` it`s in the brush` in your sig
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2014 07-15-2016 10:29 AM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
SEO by vBSEO 3.5.0
