Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree10Likes
Old 07-14-2012, 09:22 PM   #6841
ChadRacing's Avatar
Ran my D3.5 in my 12th scale tonight and wow. The amount of rip I had out of the corners and the speed down the straight. This is a great motor. Now Im looking forward to running a 1cell from you in the car with this motor.
Thanks Again Eric.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 07-15-2012, 07:20 AM   #6842
Any of you guys running 12th blinky care to share your timing settings?
I tested my 17.5 D3.5 in 12th a few weekends ago, but only got to try out a few different configs. I started @ 15* timing on the can and tried 97.5, 99, and 101.5mm rollouts... but couldn't get the motor to produce the same lap times as my Revtech or Reedy. After the racing was over, I upped the timing to 20* and the motor really woke up and lap times fell about 1.5-2 tenths. However, I suffered a bit towards the end of the run with fade.
What are yall seeing as the sweet spot for timing on these for 1S/12th?
JamesL_71 is offline   Reply With Quote
Old 07-15-2012, 08:33 AM   #6843
ChadRacing's Avatar
Im not sure how much this will help but I am running my 12th in blinky but we use 13.5's at my track. I am running it with a LRP SXX esc. The motor is set to 15 deg of timing and a rollout of 83.
The D3.5 you have might need a higher rollout. What are your temps after a 8min run?
Team Durango DEX210
Old 07-15-2012, 07:08 PM   #6844
The motor came off about 8-10 degrees cooler than my usual temps for other motors. I never saw it get above 130F... maybe 128F was the highest.
I do need to get more track time with it, obviously, to test some different rollout/timing combos.
Old 07-15-2012, 07:48 PM   #6845
NolanP's Avatar
130 degrees thats all you push your motors?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 07-26-2012, 05:00 AM   #6846
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Are you running a fairly new racing pack that you could get relaible info offof or the pack u ran last seasona sat a couple months??? cause that might damper the HP... Also u said u started at 15 degrees from stock or u actually went back to neg 15 degrees not 45 degrees? remeber guys cant judge a new product with old or worn out other stuff.. even tires old drried out tires will slow ya down..
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 07-26-2012, 05:50 AM   #6847
Hey Angelo! I was running a fresh OHP pack, < 10 cycles. When I say 15*, I mean 15 on the can... so 45* total.
Ill be running again this weekend and will try the D3.5 again. I have plenty of faith that it will be a fast motor. Just need to find the sweet spot.
Old 07-26-2012, 08:39 PM   #6848
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
D3.5 17.5's will be here Tuesday. The website will be done over the weekend or early next week and products should start showing up there...especially motors. Batteries are on order. Look for some type of Grand opening special on the website for battery preorders.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 07-29-2012, 05:20 AM   #6849
TryHard's Avatar
EA
Good stuff... I'll fling you a mail in a bit
Old 07-29-2012, 11:23 AM   #6850
Blue Screw's Avatar
hey james well howdid u make out over the weekend.. what were ur results...
wann get u hooked up and dialed in with this motor.. what speedo r u running and what battery spec wise? alot can be done with the way u take care of the pack and charge and dis of it
Angelo DAlessandro
NITRO ONROAD
Old 07-29-2012, 11:43 PM   #6851
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I can vouch for James that his packs are about as good as they come. I ran them on my turbo 35 aftger the races and the numbers were just what you'd expect from a fresh OHP pack.
Old 07-31-2012, 08:21 AM   #6852
Tyler Keel's Avatar
I'm ready to throw down some of this power in Off-Road!!
Tyler Keel - AE Region 9 Regional Director
Team Associated | Reedy | Jconcepts | Werks | Airtronics | Avid | Upgrade RC | Factory 1 RC
Tyler Keel is offline   Reply With Quote
Old 07-31-2012, 09:05 PM   #6853
Team EAM
Getting close....so close Im getting excited about it!!
EA
Contact Us
Old 07-31-2012, 09:06 PM   #6854
Team EAM
Default D3.5's
Did someone say D3.5 17.5's? Yes sir...fresh outta the shop and ready!
EA
Contact Us
Old 08-05-2012, 09:08 AM   #6855
Also are you building any mod brushless motors that would be great for Outlaw Sprint on foams. Mostly use 4.5,5.0 and 5.5. Not racing until late Oct. but looking for some new stuff to try.
almxdup is offline   Reply With Quote
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2015 05-10-2017 12:45 PM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 05:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 09:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 07:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 10:48 PM
