Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-18-2006, 08:33 AM   #4996
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
LOL@Ray!
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-18-2006, 12:31 PM   #4997
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
EA
got my present today (fit`s lovely nice karma man
right i better get some good results @carpetwars now
Also have you read the PM re;;eastbourne track in Uk (darren simpson boss man ???
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 10-19-2006, 11:08 AM   #4998
rayhuang's Avatar
Eric-I had three racers at practice last night ask if your bringing batteries and motors to sell at the Halloween Classic. So please bring a lot
Ray
Old 10-19-2006, 12:24 PM   #4999
Send a message via AIM to mush104
hey eric wat brushes and springs are you running on your komodo and co27 and whats the best roll out youve found to work best on these motors.
mush104 is offline   Reply With Quote
Old 10-21-2006, 07:53 PM   #5000
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
What performance difference do you get by using the brush jig on your site? What spring combo do you recommend when using F brushes in a CO27 on a tight carpet track? Also what gearing/rollout would you start at for a CO27? I am running a T2 on a tight carpet track
Fantom Racing Team Manager
AChupp2 is offline   Reply With Quote
Old 10-22-2006, 10:18 AM   #5001
1M
1M's Avatar
Trader Rating: 33 (100%+)
Default CO27
I have been running the C0 27 with purple springs and a vertical slot in the middle of the F brush. Racing on a small Dirt Oval (110race line) and having great results.
http://www.dirtoval.com/forums/showthread.php?t=18997
Thanks to Eric for the support.
Bob
1M is offline   Reply With Quote
Old 10-22-2006, 11:15 AM   #5002
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Eric- Team Drivers: Going top be running some stock truck at an upcoming large event and want to get your thoughts on which stocker to run and what setup do offroaders like? I have some EA Monsters and a New CO27. Just getting setup for the big event.
Jeff
Jeff Werner is offline   Reply With Quote
Old 10-22-2006, 11:21 AM   #5003
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
For the KD's we run F's, 767's or XXX brushes. Red/Purple springs. The brush selection depends on car and driver. If the car is not very good or the driver hits a lot of stuff then we go to XXX brushes to keep from burning them up and falling off.
C027 we run F brushes and Red/red on the springs. Most of the time full face brushes but at times will take .010 off the brush....depending on track conditions and driver preference.
Start the KD at around a 1.10 roll out and the C027 around a 1.12-1.15.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 10-22-2006, 11:25 AM   #5004
Team EAM
A hole in the face of the brush will give more pressure in the center of the brush on the comm. When you run a larger hole you will generally need to go down on the spring tension just a little. F brushes with a full face and large hole work well and sometimes .010 off the trailing edge. On a tight track I would start around a 1.10 rollout.
For the motor setup on a tight track I would run F brush, .010 off the trailing edge and a large hole. Red/red springs. Larger track I would run a full face with purple/red springs and go up 1-2 teeth.
EA
Contact Us
Old 10-22-2006, 11:35 AM   #5005
Team EAM
Jeff
Hi Jeff,
For offroad I am not really sure on setup as I dont race it much....But I would run F brushes or 767's and red/purple springs. Its all pretty much the same setup for all 6 cell classes. Oval and 12th scale is really the only setup differences and its springs.
EA
Contact Us
Old 10-22-2006, 03:35 PM   #5006
EA
What spring combo would you run on a CO27 with a full face F brush without the hole?
Old 10-22-2006, 03:55 PM   #5007
Jeff I've been running EA's motors all season here. THe CO27 on the 2 smaller more technical tracks. Monsters on the larger tracks. They have performed excellent. What truck are you running? I run a 16 tooth pinion with the stock spur on my T4 with the Monster. With the CO27 I run a 18 tooth pinion with the stock spur.
Batteries are the key in stock offroad. If you have good batteries and EA motors you'll be fast!
Let us know how you do.
Paul
http://www.paulwomble.com
pwomble is offline   Reply With Quote
Old 10-22-2006, 05:06 PM   #5008
Team EAM
I would start with red's. IF the bite is really high then go purple/red. The excessive load will cause the motor to arch more and is the reason to go stiffer on the springs.
EA
Contact Us
Old 10-23-2006, 01:48 PM   #5009
Alex C's Avatar
Trader Rating: 50 (100%+)
Eric,
If you have a chance check your e-mail @bellsouth, requesting information.
Good Luck to all of the Drivers that are attending this years Halloween Classic.
Regards,
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 10-23-2006, 03:21 PM   #5010
EA, you have a email
Pat McCracken
Pat McCracken is offline   Reply With Quote
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2014 07-15-2016 09:29 AM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 05:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 09:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 07:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 10:48 PM
