Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree10Likes
Old 08-16-2006, 10:02 AM   #4591
LWracer's Avatar
Default Oval Tuning!
Eric,
When tuning a motor for 12th scale oval racing ......could we break in the brushes using a heavy spring (purple) and then switching to a ligter spring
(red & green) for the actual race? Dont lighter springs make more RPM?
Again thanks for your help!
Jeff
LWracer is offline   Reply With Quote
Old 08-16-2006, 10:12 AM   #4592
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by LWracer
Eric,
Jeff
No lighter springs produce more Torque and less RPM. Heavier springs do the opposite...More RPM and less torque.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 08-16-2006, 10:13 AM   #4593
Team EAM
Originally Posted by J.Filipow
EA- Nice article in XRC...very informative, well written and photographed. Thanks for sharing some of your info!
Thanks J....I cant take credit for anything other than the work. Carl did the writing, pics and everything else!! LOL Ive had several guys say they learned a lot from the article that they didnt know....which is good!!
EA
Contact Us
Old 08-16-2006, 10:13 AM   #4594
Team EAM
Originally Posted by Alex_kipper
Hey EA
you got a pm from me!
Have not seen or heard from him....
EA
Contact Us
Old 08-16-2006, 05:03 PM   #4595
LWracer's Avatar
Default C027 and F Brushes
Eric, I just ordered some more of your F brushes for my C027's
Do they work as well in the Monsters?
Thanks!
Jeff
Old 08-16-2006, 05:20 PM   #4596
maxepower's Avatar
Talking Tamiya Speedweek update!
Hey Eric,
Wish you were out here in Tamiyaland USA. so you could help figure out these 23 turn motors for us. Their the Tamiya RR chrome can motors. Torque motor!
Ran "F" brushes and red springs all around and the motor had plenty of rip but after looking at the brushes they were getting discolored a bit from the heat.
Motor coming off hot! Close to 200 F. Running 5.4 FDR. I may wan to back off a little bit just to save the motor. Any other suggestions would be appreciated!Thanks!
Max
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 08-16-2006, 05:51 PM   #4597
POOKYT's Avatar
Originally Posted by maxepower
Hey Eric,
Max
Guys, you may want tot try and take a little off of the trailing edge to reduce the amps and lower the heat a bit. Eric and I did this on our KD's 2 weeks ago and it really helped. Good Luck.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 08-16-2006, 05:52 PM   #4598
POOKYT's Avatar
Thanks!
Jeff
They work great in the Monsters and CO's and ROAR stocks. I have also used them in my C2 and KD 19 turn motors with great results. Hope this helps.
Brant
Old 08-16-2006, 06:05 PM   #4599
Team EAM
Hey Eric,
Max
Hey Max,
You may try what Pooky said. It will drop the amp draw down and temps. You may need to gear up though. If you want call me tomorrow from the track and I'll see if I can help you out some more. Also if you are using a lot of brakes try going to a purple/red spring. It could be that your getting the brushes hot from arching if your using brakes.
EA
Contact Us
Old 08-16-2006, 06:25 PM   #4600
maxepower's Avatar
Talking RE: THANKS AGAIN!
Originally Posted by EAMotorsports
Hey Max,
EA
Yes, your absolutely right! Were running spools so we are using brake at a couple of the corners. I'll try both suggestions. I'll let you know the results or give you a call! On the brushes was that the trailing edge on both the positive and the negative? Or just the positive?
Thanks again!
Old 08-16-2006, 06:29 PM   #4601
POOKYT's Avatar
Thanks again!
Both brushes.
Brant
Old 08-16-2006, 06:33 PM   #4602
maxepower's Avatar
aaaahhaaa!
Thanks!
Old 08-16-2006, 06:36 PM   #4603
Team EAM
aaaahhaaa!
Thanks!
No problem Max...just give me a call from the track if you need any more help!!
EA
Contact Us
Old 08-17-2006, 05:31 AM   #4604
Default thanks
hey EA
I got your email thanks i'll order some batts soon
i'm glad to be part of the EA team talk to you soon.
Pat McCracken
Pat McCracken is offline   Reply With Quote
Old 08-17-2006, 01:30 PM   #4605
Rob Phillips's Avatar
EA, you get my PM?
Nice job on the article in XRC. Have any future plans for more XRC apperances?
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2015 05-10-2017 12:45 PM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 05:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 09:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 07:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 10:48 PM
