Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-26-2006, 08:06 AM   #4156
tonyp126's Avatar
Send a message via AIM to tonyp126 Send a message via Yahoo to tonyp126
Originally Posted by EAMotorsports
Hey Jon those KD's are fast arent they? I ran one in FL this past weekend and it was fast... My car just sucked eggs!!
EA
Hey Eric, what was your FRD this weekend with the KD19? I ran mine at a 6.63 and it wouldn't go. Thanks.
Team Schumacher EA Motorsports Team Trinity/TRC TQ Cells P-DUB HDimaging.net
tonyp126 is offline   Reply With Quote
Old 04-26-2006, 08:09 AM   #4157
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Hey Tony I ran it from 6.25 to 6.75 and it was best around a 6.4. It got hot at all the gear ratio's but fell off at 6.25, didnt fall off at 6.4 and never ran good at 6.75.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 04-26-2006, 08:52 AM   #4158
tonyp126's Avatar
EA
I assume you ran F brushes. What springs? I'm going to try it again this weekend at Speedline.
Old 04-26-2006, 09:44 PM   #4159
Team EAM
Hey Tony yes I ran F brushes and a purple/red spring combo. Springs need to be a little stiffer because of the higher rpm.
EA
Contact Us
Old 04-26-2006, 09:45 PM   #4160
Team EAM
Default KD-19, Monster's, C027's and 4200's.
I've got C027's on the site now and the KD-19 turns, Monsters and 4200's will be up on the site Friday. Should have some more 3800's in about 2 weeks.
EA
Contact Us
Old 04-27-2006, 06:42 AM   #4161
Send a message via AIM to GroffBall
Wes,
My 415 will be on its way today, Good Luck at TCS, that goes for you too EA.
No more tamiya for me.
GroffBall is offline   Reply With Quote
Old 04-27-2006, 06:18 PM   #4162
maxepower's Avatar
Unhappy Too hot to handle!!!!!!
Eric,
I've ran your CO27 at the Tamiya track and it was a missle! I went club racing this past week and geared it wrong for that track. The motor got real hot!
Internal temp was around 200F and external was 180F. Can this motor be saved and if so what do I need to check to make sure it's still good.
Or am I spinning my wheels so to speak! Is the motor toast?
Thanks in advance!
Max
P.S. Hope to see you at the R.R.O.C.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 04-27-2006, 06:31 PM   #4163
Team EAM
Hey Max,
I would just take it apart and rebuild it and see if it will still pull good amps. If the amp draw is real low then the magnets are shot. I can fix that with the zaper though.
EA
Contact Us
Old 04-28-2006, 12:21 AM   #4164
maxepower's Avatar
Hey Max,
EA
The motor still pulls good amps after I changed the brushes and cut the comm.
It just seems like it doesn't have the same power that I had when I first ran it!
I put "F" brushes, still seems down on power. Should I change the springs? Can the springs loose tension if they get too hot? Can the amrmature itself have been somehow damaged from the heat?
Inquiring minds want to know!
Old 04-28-2006, 07:59 AM   #4165
Team EAM
Springs can loose tension if they get very hot...But it usually takes a few times before they do... The arm will only go bad if the insulation is melted off the wire and it shorts out. When this happens the motor smokes, stops running all together and the wires turn crusty black.
EA
Contact Us
Old 04-28-2006, 09:24 AM   #4166
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
local club last night in the UK
carpet/rubber
5-6 guy`s using EA motors & cells
i was the only sponsered guy in there & i was 8th (via microtech)
top 3 used EA roar`s with F-line`s aswell
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 04-28-2006, 01:52 PM   #4167
mutley001's Avatar
Hey Eric,
Any dates for when your IB 4200's will reach us in the UK? I'm in need of a new pack or 3! Just gonna order a KD19 from Microtech too as they have just got your shipment.
EA motors are doing really well at the local club at the mo as Colin has probably told you and those CO27's are really fast!
Keep up the good work!
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 04-29-2006, 09:10 AM   #4168
Team EAM
Paul the 4200's will be shipped out early this week to Microtech. The numbers are awesome on them too
EA
Contact Us
Old 04-29-2006, 09:12 AM   #4169
Team EAM
Default In Stock NOW!!
KD-19 (Komodo Dragons), Epic C Stock (C027 stocks), Epic M Stock (Monster stocks) are all in stock. 4200's will be up on the site later this week and a few 3800's are still on the site.
Newest batch of F brushes are in and they are good!! Ran a set of them in a KD-19 last weekend 6 runs and still had serrations left
EA
Contact Us
Old 04-29-2006, 11:10 AM   #4170
hey Eric...do you know when your 3800 batts will be in stock?...wanted to buy 3 or 4 for the reedy...let me know...
HEWITT is offline   Reply With Quote
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2014 07-15-2016 10:29 AM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
SEO by vBSEO 3.5.0
