EAMotorsports discussion thread
#3706
STOCK MOTORS!!!!
Originally Posted by EAMotorsports
EPIC Based "M" stocks are back in stock.
EA
EA
What would be a better stock motor for the Tamiya track here in Aliso Viejo.
Epic type "M" or the type "R", I know if you gear it properly they will both work but if you had to make a choice, which would it be?
Inquiring minds want to know!
This question is specifically for Eric to answer!
Thank You!
TTLocal!
#3708
Team EAM
Originally Posted by maxepower
Hey Eric,
Thank You!
TTLocal!
Thank You!
TTLocal!
Hey Max,
If you are running on the layout (I know it can change a little but not much) as the Reedy race then the "R" stock will be better...It has more rpm with a little less torque but it is also more tricky to gear...If you miss it by more than a tooth then it will get hot and fall off. The "M"stock will be better if the track is a little smaller or has some 180's in it...It has more torque and will pull those heavy rubber tires better.
I ususally use a monster everywhere I go...Its hard to beat it in anything...But the C027 may change that
EA
#3709
Hey Eric,
Thank You!
TTLocal!
Thank You!
TTLocal!
[pre]
Best Heat Lap/Time for GT-2:
JUAN AVEYTIA with 19/5:01.33
-- GT-2 - A Main --
Pos Car Laps time name
1 1 19 5:03.94 JUAN AVEYTIA
2 6 19 5:08.50 JOHN HOUDA
3 9 19 5:08.75 RUDY RODRIGUEZ
4 5 19 5:15.37 TRAVIS LAWRENCE
5 3 19 5:16.64 GEORGE LIN
6 4 18 5:07.22 ANTHONY QUEROL
7 8 18 5:11.12 ARTHUR VALBUENA, JR
-- 2 --- DNS --- IAN AQUINO
-- 7 --- DNS --- JOEL NAVARRO
-- 0 --- DNS --- CRAIG RICHTER
-- GT-2 - B Main --
1 1 19 5:03.52 CHRIS LIM
2 2 18 5:00.73 KEVIN COLE
3 3 18 5:05.15 JARON BANDY
4 4 18 5:06.55 ROD BANDY
5 5 18 5:07.42 ALEX LAU
6 8 18 5:09.16 FRANK MASI
7 7 18 5:14.24 GENE BRANAGAN
8 0 17 5:06.21 ROBERT WHITE
-- 9 --- DNS --- JOSH TRAN
-- 6 --- DNS --- MICHAEL WONG
[/pre]
oh yah.. i only completed one qualifier
#3710
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
maxepower
monster =point & squirt
Type -r ;;roar = fast & flowing
#3712
EA,
Just wanted to stop in and give you some props because Billy Spence was fast!!!!!!!! This weekend at the Southeastern Classic.
Next time you talk to melton ask him to tell you his secret way to open a corona bottle.
KT
KT
#3713
Originally Posted by Mark G
question for the eamotorsports guys i was thinking on buying ur stock motors but just thinking is there a way to see the numbers of the motor befor i buy it ? just like in the hobby shop they let you see the numbers on the cann
#3714
KT's right, Spence was ballistic. My car was very fast aswell, but after breaking my very hooked up T2 in the first Q, I had to scramble and put my FK05 back together and try to get it set up. I suffered from rear end that just wouldn't rotate, but it was fast, very fast.
#3717
Monster stocks are in stock now....
EA
EA
Had a friend use that Reedy QM I sent you a few months back....
It looked to be the fastest motor out there....Those XXX's are the bomb for that motor...It gets faster and faster each and every run...just skim the comm and rebreak in the brushes for 5 mins at 2v....
I think I love this motor...Can not wait to see the Checkpoints and the Newer Trinity 19T....
Bring them on....
-Shookie <>
#3719
i had to switch out the axles to the tamiya ones. had to use 5x9 bearings instead of the X-Ray 5x10... and drilled out the tamiya hubs so the hinge pin would fit.
