Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 12-18-2005, 08:10 PM   #3436
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Jeff Werner
The Tekin takes it down to .5 correct? IB's are OK past the .9 range if you are going to race them right after using on the tray?
Jeff
It takes them down to .7 at 2 amps then down to .5 at a half amp I think. Yes you can take IB's down below .9 as long as you charge them as soon as you take them off the tray. If you store them anytime at all with below .9 they will loose runtime. Even traying them before charging I have lost around 20 seconds from the labels...But the voltage goes way up and IR's go down. I had a pack last night that the labels were 404, 1.203, 1.8AIR. Those were 6 weeks old. Cycle last night at 35 amps came out to 389, 7.30 (as a pack) 10.7 AIR as a pack. Pretty stout!!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 12-18-2005, 08:19 PM   #3437
Stevietd14's Avatar
Send a message via AIM to Stevietd14 Send a message via Yahoo to Stevietd14
Originally Posted by EAMotorsports
Discharging them at 30 amps is better for them in my opinion. I would look at the Integy Reactor discharger. It has a 5.4 volt cuttoff and it sells for around 30.00USD. I would NOT put them on a tray after you discharge to 5.4 though. Only tray them right before you charge them just untill the lights go out then straight to the charger.
The new Tekin discharge tray is great!! Been getting 45-4600mah into a packs that are from September.
EA
Are you saying it would be best to discharge them(In my case with a zero-thirty 0-30) right before a charge or right after a run?
Not sure if this would be the correct place but I do have a couple EA packs so I guess this could classify this post for here.
Thanks in advance
Steve
Stevietd14 is offline   Reply With Quote
Old 12-18-2005, 08:20 PM   #3438
Team EAM
ONLY Put them in a tray right BEFORE you charge them. Never after you have discharged them to .9 per cell.
EA
Contact Us
Old 12-18-2005, 08:38 PM   #3439
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks in advance
Steve
You CAN put them on the ZeroThirty after you run BUT ONLY UNTIL THE LIGHTS GO OUT. After that store them, then before you run those packs again you CAN put them back on the ZeroThirty BUT ONLY FOR A FEW MINUTES, then charge immediately... HTH
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-18-2005, 08:41 PM   #3440
Team EAM
If you do that though once the lights go out you will be at 0volts....And you will use runtime.
EA
Contact Us
Old 12-18-2005, 08:47 PM   #3441
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
EA,
The Roar stock motor worked well for me this weekend. It was one of the two race motors I relied on. I was running 767's but it was killing me to put new brushes in every run. Anyway, I got TQ and 1st in 12th scale stock A main in the NorthWest Carpet Champs. EJ and I had a great battle in the final.
Thanks,
Chris.
crimson eagle is offline   Reply With Quote
Old 12-18-2005, 09:13 PM   #3442
JayBee's Avatar
EA
Eric you actually will not be at 0Volts. The ZeroThirty doesn't discharge like that. It discharges at 30 amps until the lights go out, then your cells are around .90Volts approx.; to get to zero the ZeroThirty discharges at a significantly lower rate UNTIL it reaches zero and holds them there. It takes a good 3-4 hours to reach 0Volts...
Old 12-18-2005, 09:21 PM   #3443
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
It does zero them jaybee, check the link : http://integy.automated-shops.com/cg...55105260687.17
i'm pretty sure it does 0 them when the lights go out totally. The discharger doesnt have any smarts and just sucks voltage out of the cells without regard for voltage.
v0rtex is offline   Reply With Quote
Old 12-18-2005, 09:27 PM   #3444
Team EAM
I guess yours must be different from mine. Because as soon as the lights go out on mine its at pretty much less than 1.0v for the entire pack. There are no diodes in the tray to stop it from not doing it. And with it discharging at 30 amps there is NO way it can take 3-4 hours to get to zero volts.
EA
Contact Us
Old 12-18-2005, 09:57 PM   #3445
JayBee's Avatar
My BIG mistake guys ... I was getting it mixed up with my INDI Zero 6S which discharges at 6A then drops down to take the packs to 0Volts...Sorry if I screwed anyone up
Old 12-18-2005, 10:59 PM   #3446
MPrincip's Avatar
You got PM..
MIKE PRINCIPATO
TEAM ASSOCIATED/REEDY(1986-2005)
PROLINE RACING
MPrincip is offline   Reply With Quote
Old 12-19-2005, 09:09 AM   #3447
TeamButter's Avatar
Send a message via AIM to TeamButter
TTT
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 12-19-2005, 09:24 AM   #3448
BritRacer's Avatar
Well I am a new convert to EA.
I have bought several other tuners motors, some local, some national and was very happy with them. Then I was surfing the for sale section on here and picked up an EA Roar.....WOW.....i checked it on my motor master, which I really only use to measure change, not absolute numbers, but this motor was off the chart compared to the others....
then i put it in my 12th scale!!! My warm up lap people were checking that I didnt have a 19t in
Just put my first order in for a couple on monsters, really looking forward to running them and seeing how they compare.
BritRacer is offline   Reply With Quote
Old 12-19-2005, 05:51 PM   #3449
TryHard's Avatar
EA
Cheers Eric,
I'll look into grabbing one of the integy dischargers. On a tight budget at the moment. Hopefully later in the next few months I'll be moving jobs (actually starting my career)... more money burnt on RC :P
Could only just about afford the two packs of IB's this month... but boy were they worth it Deffiently don't want to screw them up by not looking after them properly.
Later
Ed
Old 12-19-2005, 06:54 PM   #3450
rayhuang's Avatar
Happy Holidays Eric!!!
Youve been a true asset to the World of RC racing!! Wish your family a Merry Christmas for me!!
Ray
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2014 07-15-2016 10:29 AM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
SEO by vBSEO 3.5.0
