Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree37Likes
Old 11-05-2005, 08:51 PM   #3136
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hey Eric you should have an email from me as well
trackdesigner71 is offline   Reply With Quote
Old 11-05-2005, 09:22 PM   #3137
NOZ69's Avatar
Could some one help me out with a prob i`m having with my EA Motorsports 27T, it`s got me beat...
The first meet i used it it SCREAMED for the first heat (IB3600 & 6.92 to 1 ratio), 2nd heat it started off really good (about 10 laps) then lost power & eventually stopped (battery OK). Took the springs off & moved the brushes seemed to fix it for the Final. When i got home completly stripped & cleaned & tested fine.
Today (2nd time used) the same prob but this time using matched IB3800`s for the 1st heat...2nd heat really slow (like when your battery dumps) only about 2 laps. For the final i used a Nosram 3600, no probs just pulled on the brushes b4 starting.
One thing i did notice after using the IB3800`s the comm had gone a blackish colour & after using the Nosram 3600 (no cut between) it went back to the copper colour.
To me it seems to be a sticky brush....BUT WHY Oh yeah it has the out of the box "spring/brush" combo.
Sorry for the longish thread
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 11-05-2005, 11:01 PM   #3138
mini-dub's Avatar
Trader Rating: 16 (100%+)
It sounds like a hung brush like you said. Use a comm stick to clean out the inside of the brush hood and make sure the brush slides freely inside it. Try cleaning the outside of the brush with motor spray on a towel. Make sure there's no solder from soldering the brush on thats inside the brush hood and maybe contacting the brush.
I've never seen a comm turn black and then go back to copper . Maybe it got so hot after turning black it turned a rainbow/silver color. When my comms do that it can be hard to tell if it either got really discolored or not at all when it's still in the can. Was the motor getting very hot during your run?
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 11-05-2005, 11:09 PM   #3139
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
EA- You've got mail.
I ran my EA QM 19 turn motors today at the SoCal GP. Awesome power from the motors as well as the awesome batteries. Bad tire choice stuck me in the B main but I checked out with a race time fast enough to put me in the top of the A.
Thanks Eric.
Jon Kerr is offline   Reply With Quote
Old 11-06-2005, 12:04 AM   #3140
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Cheers
sticky brush is that ,it causes black comm
when you put 36`s in more then likely the brush wasen`t sticking so it `cleaned` then comm for you
you only need a nats bit of dust in that brush chamber for it to stick
also make sure the brush briad comes from the middle of hood then loop round to where it is soldered
nothing to do with spring/brush combo re;;burnt comm
1 test for sticky brush in hood when you clen it up
pull brush braid out straight ,then push the brush into the hood by the braid only , braid will fold onit`s self if brush gets stuck (get me )
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-06-2005, 02:06 AM   #3141
NOZ69's Avatar
Yeah... i made sure it was spotless, motor spray & cleaned the hoods with cotton buds (no comm stick).
The motor wasn`t running hot
I`ve been thinking about it all afternoon & the only thing i can think of that was the same both meets...was that i cleaned the car with the air compressor after the 1st heat....SO may be i`ve blown some sh!t into the brushes.
Next meet i`ll tripple check the brushes B4 each heat. As it`s been very frustrating..as B4 this i`ve been up the pointy end.
Thanks for the help
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 11-06-2005, 03:17 AM   #3142
polesitter61's Avatar
I had this same problem with a Monster stock of my own, not EA's. It ended up having a bad wire in the armature. It was broke but not all the way, it would run fine for a few laps until the motor warmed up and then the wire would expand and seperate, then the motor would slow down till it stopped. Not saying that this is your problem but something to think about.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 11-06-2005, 06:37 AM   #3143
rcracenut's Avatar
Trader Rating: 52 (96%+)
I would check to see that the shunt(wire coming from the brush to the hood) isnt pressed tight to the hood which can happen when adjusting the gear lash and using the endbell to turn the motor. I have seen this happen to alot of guys who dont think to check the shunt after adjusting the lash.
____________________________________________
1 Corinthians 10:31 ...whatever you do, do it all to the glory of God.
S&N Trackside Hobbies
Innovative Hobbies and Raceway
Clark RC race park
rcracenut is offline   Reply With Quote
Old 11-06-2005, 06:36 PM   #3144
1M
1M's Avatar
Trader Rating: 35 (100%+)
Ran my Dirt modified Saturday night with a new G11 pro and EA Monster stocks Tqed and finished first at Radio Hill Raceway in Dundee, NY
http://www.dirtoval.com/forums/showthread.php?t=13920
1M is offline   Reply With Quote
Old 11-06-2005, 07:26 PM   #3145
POOKYT's Avatar
Good run man! What kind of servo are you running with that G-11 speedo?
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-06-2005, 08:49 PM   #3146
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
EAM Team T shirts are on sale now on the site. I only have Medium, Large and X large left in blue and black.
Batteries and motors are on the way this week. Will update as soon as they are ready for sale.
SXT has been added.
Also have some Turbo Dyno slave motor arms from DC Motorsports. Best money you can spend if you are a Turbo dyno owner. Rebuild your slave motor once a year with this!!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-07-2005, 06:10 PM   #3147
Team EAM
PRS gears are back in stock.
116, 118, 124, 126, 128. Smaller ones are still on backorder.
EA
Contact Us
Old 11-09-2005, 04:55 PM   #3148
Team EAM
Hey Guys,
Just got the newest date code's in of IB cells and thought I would post a picture to clear up some false information that some people are giving out.
These were also measured WITHOUT cutting the shrink off of the NEG end of the cell which is about .1mm thick. So you can see that the IB's are below ROAR specs. These one was on the longer side from what I measured out of 30 cells.
And before you say I fuged the measurments I can tell you now that is not the case. I have no reason to do that. I just dont like guys spreading false information on the Internet.
EA
Contact Us
Old 11-09-2005, 04:59 PM   #3149
John Tag's Avatar
Trader Rating: 42 (100%+)
EA dont forget about me...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 11-09-2005, 05:01 PM   #3150
Team EAM
Door prizes?
EA
Contact Us
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2015 05-10-2017 12:45 PM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 05:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 09:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 07:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 10:48 PM
