Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree24Likes
Old 04-18-2005, 11:24 AM   #2041
TeamButter's Avatar
Send a message via AIM to TeamButter
TTT
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 04-18-2005, 12:57 PM   #2042
maxepower's Avatar
Originally posted by TryHard
ok, what should i be looking for on the shimming? How is the best way to adjust it? Is there a certain amount of play I should be looking for? Or is it a case of run it and see (unfortuantly I don't have a dyno... so dificult to compare numbers)
Are the teflon shims suppose to work best? I put the comm in without any shims and see where the the comm center it self and add shims accordingly! Correct me if I'm wrong!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 04-18-2005, 03:40 PM   #2043
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default Shimming
yep sounds good
make sure you screw down the endbell ,cos the magnetic field changes as the retaining ring is pulled up
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 04-18-2005, 05:57 PM   #2044
maxepower's Avatar
Default Re: Shimming
Originally posted by MR JOLLY
yep sounds good
There should be some play! When the motor heats up there will be some expansion, so if you have"0" play you may actually cause binding when the motor gets hot!
Old 04-18-2005, 07:42 PM   #2045
ghoppa's Avatar
Trader Rating: 50 (98%+)
Butter,
YGPM....
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 04-18-2005, 07:56 PM   #2046
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Default Shimming
I hold the motor in one had and pull down on the shaft with the other then let it go and see if the arm moves up or down. It should center itself. Sometimes you cant get a small enough shim to make it perfect but as long as its close it will be ok. If its off any I put the extra shim to the top. Because when the motor turns for some reason it tends to pull down (toward the pinion).
I dont reconmend teflon shims...Ive seen to many come apart and get hung in a motor in the middle of a race.
Some may have noticed that I went back to the standard size shims on the last bathc of motors...This was because I was out of them and so was Trinity...(not because I am cheap!!!)...but Ive got them back now and everything I have shipped in the past 3 weeks has the small alumn/brass shims in them again.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-18-2005, 07:59 PM   #2047
Team EAM
Default Website and orders
Ive updated the website with stock of PRS spur gears for TC's. I have 96-116 in stock and they fit any TC with standard spacing mounting holes (Yokomo, HPI, Asc, XRAY, RDX, Etc).
Also I screwed up last night and broke my bit on the lathe so orders wont be shipped out till Thrusday at the earliest unless you got a notice on your order today....I had a lot done over the weekend and the only ones that didnt get done were from last night and today. I got 3 bits and an extra lathe on the way...so no more of those problems!!
Thanks again
EA
Contact Us
Old 04-18-2005, 08:02 PM   #2048
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
EA if u need my lathe it still has the HUDY dia. bit in it and cuts perfect. I'll overnite it tomorrow if u need me to- just call. I doubt one day will do much good but if something happens with what u got coming, LMK.
BigDogRacing is offline   Reply With Quote
Old 04-18-2005, 08:56 PM   #2049
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default New website address
just a reminder guys... EA has a new URL. its at www.teameamotorsports.com (please update your signatures)
i just remembered to update mine just now. BigDog?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-20-2005, 11:28 AM   #2050
Default New Customer
I just placed an order for an "Epic Roar Stock". I was running Paradigm motors, but have been unable to contact them for a rebuild or purchase. From what I have read and heard, I am hoping to be impressed. I need this motor for a large asphalt on road track. Also, does anyone have a good starting ratio? 64 pitch/96 or 100 tooth.
svines1972 is offline   Reply With Quote
Old 04-20-2005, 12:00 PM   #2051
Assuming you're running TC and if the track is really big I'd start it off around 6.90 with rubber tires. I've been running the ROAR stock on my local track which is pretty big and gearing it around 7.00-7.10, I think you'll be pleasantly surprised by EA's motors.
Ozwald Bates is offline   Reply With Quote
Old 04-20-2005, 12:05 PM   #2052
raving-monkey's Avatar
Send a message via MSN to raving-monkey
with you lot saying running on large tracks..try around 6.9....it sounds fairly low to me.
with stocks over here people tend to run around 6ish....on medium sized tracks.
is it to do with temp?
raving-monkey is offline   Reply With Quote
Old 04-20-2005, 12:55 PM   #2053
Default New customer
Yes, I am in Southern California, summer is approaching. Track temps last year wer around 140.
Old 04-20-2005, 01:03 PM   #2054
Most of the "big" tracks in the U.S. would be considered small to medium by UK standards .
Old 04-20-2005, 01:14 PM   #2055
Hebiki's Avatar
yup!
i met someone on here who races in the UK. i told him the track i race is fairly "large" 160 foot straight... and he told me the track he raced on was 100 meters for the straight.
(160 feet = 48.768 meters)
Hebiki Design Works
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2015 05-10-2017 12:45 PM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 05:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 09:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 07:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 10:48 PM
