Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-10-2011, 08:53 AM   #91
As Gord knows for our WCICS series in western Canada we have made a new class called the ORCA Mini series using the Spark esc and motor combo for Tamiya minis.
My Question is will the Spark esc be sent to ROAR for approval as a non timming esc so it could be used in VTA or Stock touring car classes?
Jeff Cohen
www.rcgears.net, www.carcar.ca
Thanks to my Sponsor: Shred-A-Can Metal Recyclers LTD
www.shredacan.com
chongo is offline   Reply With Quote
Old 09-12-2011, 07:34 PM   #92
Well after some research, I guess you won't know anything until Nov. 1, 2011 at the earliest.
Please let us know the outcome when you find out.
Jeff Cohen
www.shredacan.com
Old 09-12-2011, 11:05 PM   #93
big_gord24's Avatar
Send a message via MSN to big_gord24
Hi Jeff
It is our intention to submit the Orca Q Spark to ROAR for approval after our unfortunate suspension has ended. We'll keep you in the loop.
New Username.... Tiny.24
Please don't PM this account....
big_gord24 is offline   Reply With Quote
Old 10-01-2011, 06:10 AM   #94
hana166's Avatar
Default firmware update
hana166 is offline   Reply With Quote
Old 10-03-2011, 09:29 AM   #95
Default Orca Infinite 6000Mah 3.7V 60C 1-Cell Race Pack
Hello,
Has anyone tried this battery? Specs seems to be fine. How does it run against best batteries?
I would be using it in 1/12th scale spec class in Finland where we run 10.5t motors with no-timing esc.
More info about the battery here:
http://quantumracing-rc.blogspot.com...0c-1-cell.html
Thanks!
http://www.finRC.com
AiR2k is offline   Reply With Quote
Old 10-11-2011, 06:56 PM   #96
I purchased this speedo used. Guy said it worked great. Tried to calibrate to my M11, 2.4 ghZ FHSS-2. Will not calibrate with throttle set in “Rev” position on transmitter, only in “nor”, but calibrates fine that way. I get 2 beeps when held in reverse, go to throttle, get 2 more, than neutral and get a series of chimes. However, motor will then run only intermittently. Motor is fine, I hooked it up to an LRP SXX TC SPec and it ran fine. Tried a 17.5 D3 with the Orca and had the same problems as with the Tekin motor. Tried with 2 separate LiPos and still had the same issue. Recalibrated using a KO radio on 27 mhZ FM, still had the same problems. Am I missing something, or is this speedo just bad? Thanks.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 10-13-2011, 05:55 AM   #97
It looks like your ESC calibrates ok but has problem running. Please send it back to us for some diagnostic. Mailing address is:
250 "H" Street,
Blaine, WA 98230
Attn: TeamORCA USA
Please remember to include your return information and email. We will get back to you ASAP.
Hans
TeamORCA USA
TeamORCA is offline   Reply With Quote
Old 10-13-2011, 08:58 AM   #98
Thanks Hans. Yes, it calibrates, and I can actually program it with the box, just can't get the motor to run. Reset speedo to the defaults last night, changed EPAs on Tx, etc. Still can't get motor to run. Have tried 2 different sensor wires, batteries, etc. I'll get it packed up and shipped off. Have run Tekin, LRP, and HW/SP, was really looking forward to giving the Orca a try.
Old 10-13-2011, 09:46 PM   #99
liteweight's Avatar
Default 17.5 blinky
Anyone could share starting set up for 17.5 blinky, i send pm to Team Orca didn't get any help , Its for high bite indoor asphalt with 80ft straight and tight corners?
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 10-14-2011, 02:36 AM   #100
I'm sorry man! We just got back from IIC!
This is the setup we ran at the IIC( High bite carpet)
Punch 8
PWM 8k
D.B. 14%
initial B. Off
B.F. 700
And we used the ORCA RX2 17.5 motor with option rotor, gear at 3.88
Motor timing 4.5bars
I think you can start with this setup!
Keith Yu
Team Orca USA
Keith Yu
Team ORCA/Team Pro-Spec/Team EAM/Team Yokomo
rcproshop@hotmail.com
Keith Yu is offline   Reply With Quote
Old 10-14-2011, 03:49 AM   #101
Default Where can the ORCA VRITRA VTC MKII be purchased in North America?
Only place the ESC seems available is in the UK and Singapore....very expensive on the shipping....
Would anyone happen to know where this ESC can be purchased in North America?
Appreciate!!
mhavlena is offline   Reply With Quote
Old 10-14-2011, 05:50 AM   #102
Default Where to buy ORCA
I am in Canada, and MuchHobby (www dot muchhobby dot com) has the full ORCA lineup.
I believe that AmpDraw is going to start carrying the ORCA line in the near future.
Regards,
Ian
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 10-14-2011, 07:17 AM   #103
Regards,
Ian
Thanks, but it seems that muchhobby are out of stock and Ampdraw still do not have the lineup.
Does this mean that we (North Americans) are SOL? Purchasing the ESC in the UK can run 350 bucks with proper courier shipping.
Appreciate anyway!!
Old 10-14-2011, 03:54 PM   #104
liteweight's Avatar
Punch 8
PWM 8k
D.B. 14%
initial B. Off
B.F. 700
Keith Yu
Team Orca USA
Thanks Keith i hope this is a better Esc than Tekin which im using for a long time.
"MRH" Carpet racing
"Xray T3 2012"
Old 10-14-2011, 04:08 PM   #105
Bleh, never mind.. was looking in the wrong section on the Orca site for the manual.
Feijai is offline   Reply With Quote
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 10:04 PM
SEO by vBSEO 3.5.0
